Join TDPRI Today
72 Thinline Pickups?
Discussion in 'Just Pickups' started by b2187101, Apr 3, 2011.
  1. b2187101
    b2187101 Tele-Meister
    394
    Mar 24, 2008
    Liberty Center, Ohio
    I just got a 72 Fender Thinline, love it. What exactly are Wide-Range pickups? I have a 2009 MIM Strat that has, I belive, Ceramic magnets. A Squier Tele that has some transplanted TexMex pickups...Alnico magnets? So what's in a Wide-Range pickup?
    Thanks.
  2. Jim622
    Jim622 Tele-Meister
    I have the same guitar - reissue. Great axe.
    This is out of the The Fender Telecaster book by A. R. Duchossoir. They were designed by Seth Lover, who went to Fender from Gibson. The magnetic material is Conife. Both pups are the same, the wire is 42 Ga. Polysol, 10,000 turns, DC resistance is 10,600 - both coils, Inductance is 4.85, and something called the Q-factor is 2.87. Thats all there is. I know no more, except I'll be cremated with that axe.
    Jim
  3. b2187101
    394
    Mar 24, 2008
    I should have stated "Re-issue". I have a 2007 Thinline. Are the pickups basically the same?
  5. johmica
    johmica Tele-Meister
    332
    Mar 10, 2011
    berea kentucky
    Nope. The originals had the CoNiFe pickups, and Fender stopped production of those pickups I think in '79, but someone may correct me on that. Somewhere between '79 and '81, anyway. Too lazy to pull up Wikipedia right now and check my facts . . . Anyway, we'll say '79, and in that year, Fender moved production of the thinline, custom, and deluxe (all WRHB-equipped guitars) to Japan, where the pickup was equipped with different magnets and internal makeup. It is said (note the vaguaries) that the Japanese WRHB was a bit hotter than the original American made pup. Again, not gonna be able to pull the year out of my hat, but at some point, I want to say early '90's, they moved production of these guitars to Mexico. This is most certainly what you have, a Mexican-made Thinline re-issue. These pickups are basically standard humbuckers placed in the larger WRHB casing, and then the casing is filled with wax. Again, I'm basically regurgitating some Wikipedia I read a while ago, so I recommend checking out the entry yourself and correcting in your mind all my misrememberings . . . Love the pickups, though, and love the teles equipped with them. In the process of building a left-handed tele Custom with original '72 pickups right now . . . Hope I've been helpful.
  6. Thundersleet
    Thundersleet Tele-Afflicted
    Jan 29, 2009
    Wisconsin
    The magnetic material is CuNiFe not CoNiFe.
  7. johmica
    332
    Mar 10, 2011
    berea kentucky
    Right. Darned Periodic Table!!!!
  8. b2187101
    394
    Mar 24, 2008
    Dang... now I'm google searching for Japanese made Wide range humbuckers :(
    Is it me... or can NO guitar player just leave well enough alone? I mean, strings, pickguards, pickups, now my thing is EL84s. Is it me? Really?
  9. johmica
    332
    Mar 10, 2011
    berea kentucky
    Ah, you'll be able to leave well-enough alone, once it's PERFECT!!!!! Then you'll move on to the next guitar (and yes, I know this all too well . . . )
  10. laird
    laird Tele-Holic
    741
    Jul 8, 2009
    Palm Harbor, FL
    The Japanese WRHs are much hotter than the Mexican ones. They use ceramic bar magnets and have about 12.5K DC resistance across the windings. Stock they can get a little 'thick' sounding, and do better with 500K volume pots.
    I run a Japanese WRH in the bridge with a MIM in the neck, both with Telenator's "Mod 1" Alnico II magnets. The pickup mods are priceless, and the difference in character between the two pickups makes my '72 Deluxe a much more versatile guitar.
    -Laird
  11. b2187101
    394
    Mar 24, 2008
    I have found that Lollar(?) makes a wide range pickup? Is this supposed to be the same as the original 72 or hotter like the Japanese?
  12. Staggered Mag
    Staggered Mag Tele-Meister
    402
    Sep 23, 2008
    New England
    Jason is making a Wide Range Pickup copy, he is not using CuNiFe magnets. I believe they are in the vintage power range, with a slightly hotter overwound bridge position pickup.
  13. Telenator
    Sep 19, 2005
    Vermont
    There is only one source for a true vintage WRHB repro that uses the correct magnets, and meets all the important specifications. Telenator.
    The sole manufacturer of CuNiFe WRHBs in the world.
  14. BritishBluesBoy
    BritishBluesBoy Former Member
    Oct 19, 2006
    Brooklyn, NY
    ^^this^^
    His pickup mods are DEFINITELY worth checking out too. I have his Mod 1 in one of my guitars and it is a huge improvement over the stock reissue pickup...
  15. keef84
    keef84 TDPRI Member
    63
    Apr 13, 2009
    NC
    I am awaiting a lollar regal for the neck of my 72 ri custom. It was pricey but hopefully it captures more of the original sound.
  16. Telenator
    Sep 19, 2005
    Vermont
    It will sound better than the stock pickup.
  17. Wally
    The difference in the magnet material is what makes the original CuNiFe WRHB's from way back when worth $700 or so on the market....so I am told.
    I do know that I like what that pickup does in the neck position. I just sold a '75 Custom with orignal pickups...the neck p-up sounded great.
  18. RockerDuck
    RockerDuck Friend of Leo's
    Jan 29, 2010
    Marietta,GA
    My 72 RI sounds great stock. I changed the pickguard just to be different.
  19. Telenator
    Sep 19, 2005
    Vermont
    I find the stock WRHBs sound OK if you're playing alone, or recording with a fair amount of gain. In a band mix however, they just lack some of the necessary qualities that would otherwise allow the guitar to assume it's place in the mix. A live band sound is very different from a "playing alone sound" or even what you'd use for recording.
    I'm not saying they're necessarily bad pickups, just that they have their strong points and weak points like anything else.
