'72 Tele Deluxe Mod
Discussion in 'Tele-Technical' started by frick584, Nov 29, 2012.
  1. frick584
    frick584 NEW MEMBER!
    2
    Nov 29, 2012
    NW OH
    I am looking for opinions and input on a possible project/purchase.
    I have long been infatuated with owning a '72 Telecaster Deluxe. Aesthetically it just does it for me, from the Strat-style headstock to the pickguard, four knobs and location of the pickup selector.
    That being said, I've come to learn that I definitely prefer the sound of single coil pickups, like I had in my old Highway One Tele which I foolishly let go a few years back.
    In my research I've found these adapters that will allow a single coil PUP to fit in a humbucker cavity as found in Gibsons. Problem with these is they clearly won't work with the humbucker set up you'll find in the '72 Deluxe.
    I'm looking for ideas or options without going to far overboard.
    One thing that does come to mind is this. Using a regular humbucker sized mounting ring (perhaps from a les paul) as a guide I could drill new holes in the pickguard so that the above mentioned single coil adapter mount could be screwed into place. I have no idea what lies underneath the pickguard or if these new screws would have any wood directly underneath to screw in to.
    Any thoughts?
  2. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    There's not any wood underneath the edges of the pickguard to screw down the mounting rings.
    A much better bet is to get a custom pickguard that's cut for the standard pickups and fits the 72 Deluxe shape. I won't cost you too much, it will definitely work without any fuss, and will look far cleaner.
  3. CustFan
    CustFan TDPRI Member
    65
    Jun 17, 2011
    Hants, UK
    The new style WRHBs have access to the coils via the connections on the underside of the pickup. As an option before doing anything else you could try re-wiring the pick-up as a single coil (or switchable between humbucker and single coil). I'm sure I saw details of this mod somewhere - possibly on the 72' Custom Club (in the Guitar Owners Club section). I think people have played around with this mod (although obviously it would be the neck pick-up only in the case of a '72 custom).
    What this may not give you is the output you'd get from a stock Tele single coil (or after market replacement). Coil spliting both pickup potentially gives you quite a range of possible tones. Push pull volume or tone pots may be the route to go if you do coil split.....
  4. winny pooh
    winny pooh Friend of Leo's
    Jan 24, 2006
    South London
  5. frick584
    2
    Nov 29, 2012
    NW OH
    Thanks for all the input!
    I should have also mentioned that this project would most definitely be done to the Squire version of the guitar and that p-90's or humbuckersized p-90s aren't really what I'm after but I appreciate the ideas.
    I think the pick guard option my be the best way for me to go. Found a place in the States that can do it relatively cheap, at least affordable to a guy like myself..
    Thanks again!
  6. losergeek
    losergeek Tele-Afflicted
    Jun 28, 2010
    ottawa
    I got a custom pickguard from these guys with the switchhole removed for my 72 Deluxe mod and they were great. Really helpful and a good price. Pretty sure they'll do whatever you need, including putting single coil holes in a 72 pickguard
    http://www.wdmusic.com/pickguards.html
