65 Fender Reverb Unit 6G15 blowing fuses
Discussion in 'Pedal/Effects Owners Clubs' started by grolan1, Mar 6, 2018.
  1. grolan1
    grolan1 Friend of Leo's
    Somewhere in the middle of the flippin country
    Just picked this baby up.... my first guess is 50+ year old caps... ouch!
    tce63 and D'tar like this.
  2. sliberty
    sliberty Tele-Afflicted
    East Brunswick, NJ
    Those caps certainly hav to go. They’ve all bubbled/breached. Tubes could also be the cause, so after replacing caps, test without tubes installed. Then add them back one at a time, and see how that goes. Maybe gig also be rectifier - diodes are cheap - you could replace them too.
  3. Silverface
    Lawndale CA
    PLEASE - do not turn that unit on until it is properly serviced.
    Just as with vintage amps I advise all buyers of vintage Fender tube reverb units to budget an additional $150 for service unless proof of recent service is supplied.
    If the fuse had held on a bit longer you could have cooked your power transformer. Then you'd be paying the normal service cost (generally up to $150 for new filter caps and possible tubes) PLUS replacement of the PT, PLUS the reduction in vintage value.
    IMO all vintage tube gear needs to be inspected by a qualified tech prior to use even if some kind of proof of service is provided. I see a huge amount of lousy work - but mostly I see vintage gear that's all original. Most owners do not understand that filter capacitors have a service life of just about 15 years - less if used a bit and then stored for long periods.
    Please don't take any more =chances with that one - get it in to a good tech right away!
    corliss1 likes this.
  4. grolan1
    All fixed and working as designed. Never tried personally to turn it on.. went straight to the tech for standard/needed service!
