6 metres of sumfink
Discussion in 'Tele Home Depot' started by Mat UK, Dec 18, 2016.
  1. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
  2. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    Feb 17, 2009
    London, UK
    Fretboard skimmed, just needs trimming then it's ready for glue up
  3. Mat UK
    Feb 17, 2009
    London, UK
    In the blink of an eye (or a couple thousand) the fretboard is now glued...
    ... trimmed, routed and headstock transition sanded
    It came out a treat. I actually managed to remove truss rod channel masking tape this time, I stuck a couple of strips of neoprene to the caul as advised by Marty, and the glue joint came out nice and tight. *sighs with relief*
    On a side note, reading up on the 'horrors' or silicon, I managed to find this non-silicon based sealer product at my diy shop. Used this to anchor the truss rod...
    AND I also stuck a piece of rosewood in my veneer press... it's destined for the jag headstock
    brownale99, richa, Barncaster and 2 others like this.
  4. John Nicholas
    John Nicholas Tele-Afflicted
    Jun 26, 2014
    Poughkeepsie, NY
    Looking really good Mat!!
    Mat UK likes this.
  5. Mat UK
    Feb 17, 2009
    London, UK
    Cheers :)
  6. Mat UK
    Feb 17, 2009
    London, UK
    And thanks also (forgot to respond)
  7. Mat UK
    Feb 17, 2009
    London, UK
    Glued the veneer on last night. Seemed to go ok, used too much glue again - so much squeeze out!
    No pics of clamping but this was what I was met with this morning!
    I was a bit worried, the glue didn't squeeze through the grain on the ebony veneer...
    So I cracked on with some careful trimming and sanding and ended up with this
    I also noticed that on the low shoulder the veneer wasn't clamped firmly enough which resulted in a gap - you may be able to see in this pic
    So I'm going to stick some glue in there tonight and clamp it tight - if it's willing. I will sand it flush after that.
    There was a thick line of glue where the transition ends - it sanded out ok, but is still visible, it also revealed a small depression, which is odd, once I give this a proper final sanding hopefully it will sand out! Ho hum
  8. richa
    richa Tele-Afflicted Ad Free Member
    Apr 23, 2016
    Most problems can be solved with enough glue. :)
    Very nice.
    Mat UK and Barncaster like this.
  9. Barncaster
    Barncaster Poster Extraordinaire
  10. Mat UK
    Feb 17, 2009
    London, UK
    Thanks chaps
  11. Mat UK
    Feb 17, 2009
    London, UK
    Made myself a depth stop for my saw this morning. Came out nice.
    I'm waiting for an aluminium radius beam in order to continue with the necks. I've got a couple of wooden radiuses blocks, but the ebony fretboard surface isn't level (where the twist was routed out before glueup) so I figured the long beams will give me more control... tick tock, hurry up beam
  12. John Nicholas
    Jun 26, 2014
    Poughkeepsie, NY
    Looking really nice Mat!!
    You will like the longer aluminum radius beam much better then the shorter wooden ones. Far more accurate!!
  13. Mat UK
    Feb 17, 2009
    London, UK
    A little bit of tidying to the headstocks - here they both are: kindred spirits
  14. adirondak5
    adirondak5 Wood Hoarder Extraordinaire Ad Free + Supporter
    Oct 24, 2009
    Long Island NY
    They both look great Mat
    Mat UK likes this.
  15. MM73
    MM73 Tele-Afflicted
    Feb 24, 2015
    South Lyon, MI
    Those necks look fantastic!
    Mat UK likes this.
  16. Mat UK
    Feb 17, 2009
    London, UK
    Thanks gents :)
  17. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Jumping on the cart a bit late here, but those came out beautifully, Mat. Great work!
    Mat UK likes this.
  18. Mat UK
    Feb 17, 2009
    London, UK
    Thanks Mr Stratenstein
  19. Davecam48
    Davecam48 Friend of Leo's Gold Supporter
    Dec 31, 2009
    Queensland Australia
    What Herb, Mark, and Rick said!!!:D
    DC
    Mat UK likes this.
  20. Mat UK
    Feb 17, 2009
    London, UK
    Cheers Dave
