5F6a mods help needed
Discussion in 'Shock Brother's DIY Amps' started by capohk, May 14, 2019.
  1. D'tar
    D'tar Tele-Afflicted
    WNY
    No tubes(rectifier), no vdc at rect p8 is normal. 329vac+329vac=660vac:)
    I think you are ready for the next step in your startup procedure.
    muswell_hillbilly likes this.
  2. robrob
    United States
    Do you not have the rectifier tube in place? You must have it installed to get any DC voltage out of the rectifier socket pin 8 (cathode).
  3. capohk
    capohk TDPRI Member
    Hong Kong
    Yes. Thank you. One of the most challenging things about building something like this for the first time is confronting one's own ignorance, so please know that all your help is very much appreciated.
    Moving forward, with the rectifier in
    Filter caps measure 420VDC
    DC Voltage at preamp 1 and 6:
    V1 416 both, V2 416 and 420 respectively, V3 418
    So then move to preamp tubes in.
  4. capohk
    capohk TDPRI Member
    Hong Kong
    Heater ac is too low. massive readings on V3 pin 2, 7 and 8 and V2 pins 7 and 8
    Lightbulb limiter behaves as it should do. Readings above are without it in circuit.
  5. robrob
    United States
    I assume the heater voltage is pin 4 to ground and pin 5 to ground which is good. Measure pin 9 to pin 5 to see the full heater voltage.
    You're ready for the power tubes.
  6. capohk
    capohk TDPRI Member
    Hong Kong
    Full voltage chart with all tubes installed and no lightbulb limiter. I've highlighted what doesn't match your values, Rob. I've clearly got something wrong. I'm going to go over all of the pin wiring again.
    At full volume, you can just hear the guitar coming through the speaker faintly but it's very quiet. I've tried a couple of different sets of preamp tubes.
  7. capohk
    capohk TDPRI Member
    Hong Kong
    Pin 2 to pin 8 voltage is 5.5VAC
  8. Nickfl
    Nickfl Tele-Afflicted
    A clear picture of the phase inverter wiring is in order.
  9. 5F6Animal
    5F6Animal Tele-Meister
    Beaumont CA
    Yes, a very clear picture And a meter check of your plate/dropping resistors.
    BTW, I’m so happy to come back to a thread like this after a lengthy hiatus.
  10. D'tar
    WNY
    Disconnect nfb
    Ohm grid to cathode on each triode of v3
    Ohm grid to ground on each tr iOS ode of v3
    Pics of presence pot wiring and v3 may help
  11. capohk
    capohk TDPRI Member
    Hong Kong
    NFB disconnected[​IMG][​IMG][​IMG]
    Sent from my SM-G9700 using Tapatalk
  12. capohk
    capohk TDPRI Member
    Hong Kong
    grid to cathode both 1Mohm
  13. capohk
    capohk TDPRI Member
    Hong Kong
    grid to ground shows open circuit both triodes ie infinite resistance with no power.
  14. Tom Kamphuys
    Tom Kamphuys Tele-Meister
    The Netherlands
    That's not ok. It also implies that cathode to ground is infinite.
    Check your tail resistor and presence pot.
    capohk likes this.
  15. Tom Kamphuys
    The Netherlands
    Is the housing grounded?
  16. capohk
    capohk TDPRI Member
    Hong Kong
    the chassis is grounded. plate and cathode pins make the speaker crackle when I meter them to ground
  17. capohk
    capohk TDPRI Member
    Hong Kong
    presence pot checks out fine according to the layout specs. tail resistor measures 10.3K
  18. D'tar
    WNY
    What layout has been followed? Perhaps an under the board jumperwire from the ltpi tail to the nfb injection point is missing? Can we see the PI components.
    Using your meter. One lead on v3 cathode, take readings at every connection back to ground... Throuh the 470r, thru the 10k etc. The resistance will be the sum of the resistors in series. When you lose the reading you should have found your issue.
    capohk likes this.
  19. capohk
    capohk TDPRI Member
    Hong Kong
    Found it. Pulled all of the pots and jacks out so I see the back of the circuit board. Turned out the wire connecting the end of the tail resistor to the top of the nfb resistor had broken off. Resoldered and all this lovely sound came out of the speakers. Thank you to those who pointed me in the right direction. Now to finish off the cabinet and set the bias...
  20. capohk
    capohk TDPRI Member
    Hong Kong
    It's been said before, but the resources and help you guys provide is absolutely invaluable. Big thanks to you all.
