5E3 troubleshooting
Discussion in 'Shock Brother's DIY Amps' started by 26and385, Oct 17, 2017.
  1. 26and385
    26and385 TDPRI Member
    Red Sox Nation
    Hey amp gurus, looking for some troubleshooting help on my tweed kit. This is the TubeDepot kit. The kit went together easily enough, I followed all of the start-up checks and got good sound when I did the first power up with tubes. It sounds great and I'm very pleased with the results. However, after a bit of warmup I frequently get a mild pop followed by static that can get progressively worse, sometimes leading to total loss of sound. Usually an immediate power-down and restart will eliminate the issue, but only for another 5-10 minutes before it comes back. My first thought is a heat issue, since I get noise-free sound before the issue occurs. However, I did check DC voltages and have them attached here. My biggest concern is what I believe to be excessive voltage on the filter caps and some of the tube pins. Also, I'm reading 0.0V on pin 7 of V1. I've also poked around with the chopstick to look for bad solder joints, haven't found anything yet. I tried another set of tubes, with a 12AY7 in V1 instead of the stock 12AX7, and the issue remains. Voltage chart is shown below, with both sets of tubes. I can also take detail pics if you let me know which areas you want to see. Thanks in advance for your help!
    V1 JJ ECC835
    1 181.0
    3 1.5
    6 175.0
    7 0.0
    8 1.4
    V2 JJ ECC838
    1 179.0
    3 1.3
    6 218.0
    7 3.0
    8 49.0
    V3 JJ 6v6S
    3 394.0
    4 359.0
    8 23.0
    V4 JJ 6v6S
    3 392.0
    4 360.0
    8 23.0
    V5 JJ 6234S
    Cap1 399
    Cap2 358
    Cap3 275
    V1 Electro Harmonix 12AY7
    1 129.0
    3 2.1
    6 130.0
    7 0.0
    8 2.1
    V2 Mullard 12AX7
    1 165.0
    3 1.3
    6 202.0
    7 2.8
    8 45.5
    V3 Mullard 6V6GT
    3 397.0
    4 353.0
    8 22.0
    V4 Mullard 6V6GT
    3 396.0
    4 352.0
    8 22.0
    V5 Mullard G234
    Cap1 404
    Cap2 352
    Cap3 256
  2. corliss1
    Lansing, MI
    Looks like you're using a GZ34 rectifier instead of the standard 5Y3. Was this a conscious choice? That would explain higher-than-expected voltages.
    clintj and D'tar like this.
  3. D'tar
    D'tar Tele-Afflicted
    WNY
    The only thing that jumps out on your voltages for me is the phase inverter grid. Make sure thats a 1M grid leak.
    A NOS 5y3 is a good thing IMO.
    What does your 6v6 cathode resistor measure?
  4. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    Don't worry about pin 7 V1. It should be zero.
    Pin 7 V2 cannot be measured directly with any accuracy. Pins 6 and 8 look good, So I wouldn't worry about pin 7.
    I'd swap your rectifier tube. Do you have another amp you can grab a tube from? Aside from that, check for loose connections.
  5. Nickfl
    Nickfl Tele-Afflicted
    How good are you soldering skills/ how likely is a bad solder joint? It kind of sounds like a solder joint that is ok until it gets hot.
    Chopsticking won't necessarily reveal a bad solder joint, sometimes they seem fine until you pull on them with needle nose plotter an then they break. You should be able to pull on the joint pretty good without it beaking if it's done right.
  6. robrob
    United States
    It does sound like a bad solder joint. Poke all the solder joints with a chopstick with the amp up and running. You could even have a dry eyelet (no solder).
  7. Fiat_cc
    Fiat_cc Tele-Holic
    Melbourne, Australia
    Not that it will likely have any relevance to the outcome here, but I’m curious about why you left pin 2 out if all of your preamp tube voltage readings?
  8. Commodore 64
    Commodore 64 Friend of Leo's
    Kent, OH
    Been there done that. Probably a solder joint somewhere (or dry eyelet) as robrob mentioned. I've had both!
    Similar symptoms. Both time were filter caps for me.
