5e3 Fat switch mod.
Discussion in 'Shock Brother's DIY Amps' started by fakuverymuch, Jan 22, 2013.
  1. fakuverymuch
    fakuverymuch Tele-Meister
    First solder a 100K resistor in series between the negative Cathode bypass cap lead (the far right one by the preamp section C3) and ground. Now solder a wire to the connection between C3 and the 100K resistor. This wire goes to the center terminal of the soon-to-be "fat" switch. Wire one of the outer terminals of this switch to a nearby ground connection (input jack would be great).
    When this switch is open, C3 sees 100K between the cap and common ground and therefore C3 does not effect the gain of the circuit. When the switch is closed, C3 sees this ground connection through the switch and the gain of the circuit goes
    way up.
    Has anyone here tried this mod? It was recommended to me by Rob Hull from Tube Depot.
    Any thoughts you may have are appreciated.
  2. fezz parka
    fezz parka ---------------------------
    One thing a 5e3 doesn't need is a fat switch.
  3. Phil_tre
    Phil_tre Tele-Holic
    677
    Oct 31, 2010
    Eastern Canada
    +1
  4. Badside
    Badside Tele-Meister
    Yeah, fat is probably not the right term, this is more of a gain boost switch, except it works by limiting gain when off, so "on" is the stock sound.
    You could put another smaller cap (say .68uF) straight from the cathode to ground (would not go through the existing cap or that 100k resistor) on top of doing the switch as described. In "off" mode, you'd get more of a high-mid emphasis (tighter, less fuzzy gain), in "on" mode you'd get the stock (fat) sound.
  5. muchxs
    muchxs Doctor of Teleocity
    Aug 14, 2004
    New England
    That's an anti- fat switch.
    Resistor in series with the cap takes the cap out. The unbypassed cathode resistor is thin sounding compared to the bypassed resistor.
    Switching the 100k out restores the amp to its stock condition. Hey, ho! Sounds "fat" compared to the modded version. :rolleyes:
    Pick a sound you like and hardwire it. Buy a Boogie if you want to diddle with switches and knobs.
  6. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Mar 12, 2005
    Fullerton, CA
    Go for it. You might like it in the OFF position, and in the ON position it goes back to stock sounds. Badside also gives you another cap/tonal option with this kind of switch.
  7. LeroyBlues
    LeroyBlues Tele-Holic
    928
    Apr 23, 2008
    Michigan
    The only switch you need on a 5e3 is the on/off. Well, maybe the standby too.
  8. fakuverymuch
    Thanks for the input folks.
    Now I see...it's really a less gain switch. I think some of you have got it right. The amp doesn't need any more switches. I am always adding bells and whistles to my gear, only to find out later that I hardly ever use them. I never learn.
    When I actually used to play gigs I had FX that where almost never used. Just strait into the amp and touch controlled seems to be the best.
    I wish I could get a no fat switch for my wife's derriere.;)
  9. stingray_65
    stingray_65 Tele-Meister
    210
    Aug 30, 2008
    blissfield michigan
    Hey,
    Try this, you need a center off SPDT switch, a .68uf 50V axial cap, a 2uf 50v axial and a 10uf axial cap. You can get all this stuff from your local Radio Shack.
    Yeah! I said Radio Shack! LOL! .The .68 you can get off the fleabay for a couple buck. this whole mod costs about $10.
    Any how This is my favorite mod for Tweeds in particular, but I add this circuit to nearly every amp I build.
    The cathode bypass cap (25uf 25V on your 5E3) not only effects the gain in the pre-amp, it also sets the frequency response. Remember those early amps weren't designed by rock and roll engineers, they were lifted straight out of text books as general purpose audio amplifiers. Not bad ones either.
    Any how they tended to lean toward the high fidelity side of things. The 25uf value passes a pretty wide audio spectrum. A lot wider than the frequency response of a musical instrument speaker and a WHOLE lot wider than a guitars frequency spectrum.
    Combine that wide band pass with a higher gain, and it sounds REAL good with a single coil pickup, especially the tele's with their lip stick covered neck pup and steel surrounded brass backed bridge pups.
    I can't tell you how many times I've seen on other forums people looking to mod their tweed for a LesPaul or their Strat with a hot Humbucker. They get real dark and muddy.
    So lets look at another design, from across the pond, that kicks ass with a LesPaul. It is almost a joke where Marshall got his inspiration for his designs. A Fender Tweed as we all know. One of the minor design changes that evolved was to lower the cathode bypass capacitor value to .68uf.
    Now the pre-amps band pass is much narrower, closer to the speakers abilities to reproduce, closer to the frequency range of a guitar, and much less GAIN. Now play your LesPaul in that and the humbuckers wider frequency response is narrowed and emphasizes it's punchy mid-range, It's hotter output is tamed a bit by the pre-amps lower gain.
    I attached a modified 5E3 layout that is real simple and easy to follow.
    If you have a 4 input amp, you can remove the #2 low input jack and mount the switch there to try it out, if it doesn't work for you, just change it back.
    How the circuit works is when you run capacitors in parallel, their uf values add up.
    A .68 is mounted to the board in place of the 25uf25V cap. depending on the cap, .68's can be either polarized or non polarized, so be aware if there is a polarity and orient it just like the 25uf.
    Next mount the switch. A wire will go from the center post of the switch to terminal (eyelet or turret) that has a wire going to pin 3 of V1.
    Now you want to mount a 2uf cap (this WILL BE polarized, the + goes to the switch) to either post on the switch and the other side to the ground on the input.
    Mount the 10uf cap the same way on the other post. I use a 10 instead of a 25, they are smaller and easier to mount and STILL pass way more band width than necessary,but a 25 will work just as well too.
    Here is where the stuff happens. The switch is a center off, so when the switch is in the middle, just the .68uf cap is in circuit and gives a Marshally Bright kind of sound.
    Flip the switch, and the 10uf cap value is added to the .68 and you get that great Tweed sound.
    Flipped the other way and its a middle of the road kind of setting that REALLY shines on hot wound single coils.
    The 5E3 is one of the greatest sounding amps (IMHO) but is some what limited to guitars that sound good played through them.
    This mod adds LOTS of versatility, especially if you have more than 1 guitar.
    You can also still jumper your inputs from lo 1 to hi 2.
    Ray
  10. Telenut62
    Telenut62 Poster Extraordinaire
    Oct 29, 2008
    Eugowra, Australia
  11. fakuverymuch
    Holy crap Sting Ray....
    Now this sounds a lot more interesting than the other mod. IN fact more interesting than most of the 5e3 mods I have seen on the net. I have the switch, just have to locate the caps. I think I may very well give this one a shot.
  12. Telenut62
    Oct 29, 2008
    Eugowra, Australia
    Does this mod suffer much from popping when the caps are first engaged?
  13. Fatknuckle
    Fatknuckle Tele-Holic
    981
    Jun 28, 2012
    Gainesville FL
    I have done similar mods on 18-watters with the 0.68 and 25uf caps, using DPDT push/pull switches on a 500k tone pot. That doesn't require another hole in the chassis or sacrificing an input. There is not as much pop as there is always a cap engaged on either setting. I have heard some talk of putting a resistor across the switch to eliminate the "pop", but I am not sure how that would work. I am interested in this setup as well.:idea:
  14. stingray_65
    210
    Aug 30, 2008
    blissfield michigan
    I've never noticed any pop ever, and I am VERY critical of my builds.
    Ray
  15. stingray_65
    210
    Aug 30, 2008
    blissfield michigan
    I really love the tweeds. There aren't many mods tho that you can make to them without loosing the "tweediness".
    It's such a simple circuit, its a lot like a baseball bat. You start changing things too much on a tweed circuit and it stops being a baseball bat and starts to be more like a golf club, or what ever.
    This mod is more for versatility without having to "tone sculpt" a lot of coupling caps and what not, and it does it pretty well. (IMHO)
    Ray
  16. JohnnyCrash
    Mar 12, 2005
    Fullerton, CA
    I have a 1uF I can switch on via a pot pull-switch (located on the Bright channel's Volume pot). Takes up no extra room on the front or rear panel. More gain and more Marshally type of midrange when on. When off it's stock 5E3. I also have a VVR pot (with a power switch) as the Power ON switch.
    The only extra hole I had to drill on the chassis was a switch for SS (which also adds larger filter caps) or 5Y3 rectifier (stock) on the bottom of the chassis.
  17. stingray_65
    210
    Aug 30, 2008
    blissfield michigan
    IF you wanted to add a shunting resistor to eliminate POP. you would need 2 500k resistors. even 1/8W would work.
    Simply land both at the center post of the switch and the other end of each to the outer posts.
    The idea is that the capacitors will be already "trickle charged" before they are engaged.
    Ray
  18. fluid69
    fluid69 Tele-Holic
    755
    May 13, 2010
    usa
    Thats really insightful ray
    "If you want rules, read the IRS tax code. If you want to build guitars, make some sawdust." -Colt W. Knight
  19. Fatknuckle
    981
    Jun 28, 2012
    Gainesville FL
    Thought I had heard something similar, but with 1-meg resistors. Would that be adverse?
  20. Badside
    As long as it's high enough to effectively take the cap out of the loop (anything at least 10 times higher than Rk would do) without leaving the cap hanging (which would make it pop when you switch it back in)
