5E3 1/4 power switch?
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, Jun 13, 2018.
  1. Uncle Daddy
    Uncle Daddy Tele-Holic
    656
    Sep 26, 2015
    Maldon, England
    Has anyone tried Robrob's 1/4 power switch on a 5e3?
    https://robrobinette.com/5e3_Modifications.htm#Quarter_Power_Switch
    I've found the resistors to be a bit large to comfortably fit inside the bottom of the chassis, so was thinking about mounting them on the back wall, next to the P/T, and using the redundant ground switch hole for the selector. That'd mean 5 wires running up to the switch. To simplify that, I've moved a couple of connections, and was just looking for confirmation that this would be ok, being a bit of a newbie.
    Thoughts, please?
    Prophetsnake likes this.
  2. Works for me.
    D'tar likes this.
  3. Tapatio
    Tapatio Tele-Meister
    152
    Jun 13, 2016
    New Jersey, USA
    This is mine. This was my first build which is why it's kinda sloppy. I have added a few mods and have had no issues. It was really hard to find the space, but I got the resistors in somehow. The signal in your layout will be routed close to the power supply side of things, but since everything has already gone through the amplification stages, I don't think you will have any hum or noise issues. Please post results!
    The 1/4 power mod works well, but don't expect it to deliver bedroom levels at above 3 or 4. It's still loud! I feel the difference much more in a larger space.
    Prophetsnake, twr102, robrob and 2 others like this.
  4. Uncle Daddy
    656
    Sep 26, 2015
    Maldon, England
    My tiny brain is struggling to understand how this works. According to Robrob, the 8ohm resistor is in series with the speaker. Won't that affect the signal to the speaker, as there's no bypass for it? With the switch in the position shown in the diagram, does the current take the path of least resistance, and thus bypass the 8ohm resistor?
  5. symbiotic
    symbiotic TDPRI Member
    Current then passes through the closed switch, which is in parallel with the 8-ohm resistor.
  6. Wyatt
    Wyatt Tele-Afflicted
    Nov 3, 2004
    Simple answer? Yes.
  7. timewaster1700
    timewaster1700 Tele-Meister
    260
    Feb 17, 2016
    Utah
    How does it sound with the 1/4 power switch? I’m very interested in this
  8. RustySterling
    RustySterling Tele-Meister
    262
    Jun 4, 2018
    Carmichael, CA
    Hum! I wonder, would this mod work on a 5F2A or a 5F1? Imagine a Tweed Princeton or Champ at just over 1 watt. I think that would likely be bedroom volume.
  9. jhundt
    jhundt Doctor of Teleocity
    Mar 23, 2003
    Netherlands
    I made a thing like that in a box; copied it from a Fender design, on an Eric Clapton amp I think. I did not find it particularly useful, and after trying it out I put it in my box of things I don't use. The difference in volume wasn't enough to make the amp any more useful at home levels.
    I would suggest mocking it up in an external enclosure and trying it out, before going to all the trouble to incorporate it inside an amp build.
    Anode100 likes this.
  10. jimgchord
    jimgchord Tele-Holic
    708
    Apr 3, 2018
    victor,ny
    1 watt is very loud. Hardly bedroom volume
  11. timewaster1700
    260
    Feb 17, 2016
    Utah
    Interesting I would have thought cutting the power to 25% would be a dramatic change.
  12. Uncle Daddy
    656
    Sep 26, 2015
    Maldon, England
    I tried an L-pad attenuator in a Champ I built. That worked well enough, albeit with a little treble loss at low speed.
  13. jhundt
    Mar 23, 2003
    Netherlands
    no, power in an amplifier is deceptive. It has to do with how we perceive sound and volume. The classic example is the difference between a Deluxe Reverb and a Twin Reverb. If you put the 20-watt Deluxe through the Twin's speakers, it will be ear-shatteringly loud - almost as loud as the 100-watt Twin.
    Outlaws likes this.
  14. FenderLover
    FenderLover Friend of Leo's
    Jun 11, 2009
    Minnesota
    Change the 8 ohm to 16 ohm, and the 16 ohm to 12 ohm for 1/9th power (11%) and 8 ohms total load.
  15. timewaster1700
    260
    Feb 17, 2016
    Utah
    That's an excellent idea!
  16. Prophetsnake
    Prophetsnake Tele-Meister Silver Supporter
    253
    Aug 2, 2016
    ireland
    I have a Vox AC4 with a an attenuator onboard. You can select 4W, 1w, or 1/4W. 1/4 watt is still pretty loud.
  17. timewaster1700
    260
    Feb 17, 2016
    Utah
    Is the attenuation done just with resistance like the above mod? My Weber Mini mass has a voice coil assembly I think or something along those lines that's supposedly supposed to make it mimic more of the loading of a speaker rather than just straight resistance. Sounds great whatever they did.
  18. claes
    claes Tele-Holic
    705
    Aug 20, 2007
    sweden
    Intresting. Have a 5f1 and a 5f2A and going to try it (ec has it in the vibrochamp to).
    Wondering if you could have lower values in a 5watt (20 or 15) and preserv more tone?
  19. Prophetsnake
    253
    Aug 2, 2016
    ireland
    I think it's just resistors, though it's been a few years since I had it open. It works very well, I have to say.
    I also have an attenuator I use for my other amps. A Carl's amp Super Soak. It was cheaper than buying the componenets and building one myself and it works well enough.
    timewaster1700 likes this.
  20. timewaster1700
    260
    Feb 17, 2016
    Utah
    Thanks for posting. I want to build a 5E3 stock but I'm awefully tempted to put this switchable 1/4 power mod (but probably higher values for lower than 1/4)
