Join TDPRI Today
5C3 vs 5E3
Discussion in 'Shock Brother's DIY Amps' started by RollingBender, Mar 18, 2017.
  1. RollingBender
    RollingBender Tele-Holic Vendor Member
    688
    May 14, 2011
    SW Minnesota
    Most recent organ salvage is a Hammond M2. The amp in this one is an AO-14 and uses octal preamp tubes. PT is noted on the original schematic as putting out 340-0-340. Any pros or cons using the iron from this for a 5c3 rather than a 5e3?
  2. RollingBender
    688
    May 14, 2011
    SW Minnesota
    Left to right...
    5U4
    6BA6
    6V6
    6V6
    6SN7
    6SC7
    6SK7
    6SJ7
    347v off the PT at idle.
  3. tubeswell
    tubeswell Tele-Afflicted
    Jul 1, 2008
    NZ
    Perfect for either (if it also has a min 2A 5V winding and a min ~2A 6.3V winding)
  5. RollingBender
    688
    May 14, 2011
    SW Minnesota
    With the tube compliment, wouldn't it be safe to assume that it would meet those levels?
  6. tubeswell
    Jul 1, 2008
    NZ
  7. RollingBender
    688
    May 14, 2011
    SW Minnesota
    My $9.99 5E3 chassis arrived and there is no way the PT from this AO-14 is going to fit
    I pulled the PT from an AO-29 instead. I had to open it up just a bit but it looks like it can be made to work.
    This one measured 323-0-323 with 115 at the wall as installed and running before I removed it from the Hammond chassis.
    Any chance the OT from the Hammond would be suitable for the tweed deluxe?
  8. tubeswell
    Jul 1, 2008
    NZ
    It'll be low with a 5Y3, but a 5AR4 will give it some extra kick, or SS diode rectification. A pair of push-pull cathode biased 6V6s sound best in a tweed deluxe circuit running into an 8k (plate-to-plate) load with a 250R shared cathode resistor, if the plate voltage is between 340-360.
