5 way Oak Grigsby switch wiring
Discussion in 'Tele-Technical' started by kreg, Jan 10, 2014.
  1. kreg
    kreg TDPRI Member
    6
    Jan 10, 2014
    France
    Hi,
    I'm thinking about wiring my tele with a 5 way Oak Grigsby switch, to keep the vintage sound, and add the modern ones, to obtain something like this :
    1: bridge
    2: bridge & neck in series (fatter tone than parallel and more output)
    3: bridge & neck in parallel (classic middle position in 3 way switch modern wiring)
    4: neck
    5 neck - No tone (position 3 in vintage wiring. The sound is darker and the output level is lower. I read somewhere it was used for bass lines before they were electrified. Very particular but I love this sound)
    I draw a schematic (thank the pictures from Acme Guitar Works and Seymour Duncan), but I'm not sure it works.
    Please, could you check and let us know if it works?
    Thanks
    kreg
  2. waparker4
    Nov 9, 2011
    Philadelphia, PA
    Looks like it works except the tone control is not disabled in position five
  3. kreg
    kreg TDPRI Member
    6
    Jan 10, 2014
    France
    Thanks Waparker!
    I agree with you, in position 5 the tone is not physically disabled.
    Actually, I tried to follow this wiring diagram to draw mine :
    http://support.fender.com/service_diagrams/telecaster/010-6200A_SISD.pdf
    This is my current wiring, and the position 3 is exactly that I tried to reproduce in my schematic, in the 5th position.
    If I understood the Fender diagram, in position 3, the neck PU is linked to :
    - the 1st lug of the volume pot
    - and in parallel, the 0.1µF capa (itself linked to the ground).
    The tone pot appears not physically disabled, but it does not work in this position.
    Do I miss something?
  4. kreg
    kreg TDPRI Member
    6
    Jan 10, 2014
    France
    Hi!
    Just to tell that I tried this wiring, and it works, even the position 5.
    Actually, there is a very little variation of the tone when I turn the tone pot.
    It is because I wired the tone input lug to the vol output lug like the 50's Les Paul wiring, instead of volume input. I tried classic tone wiring to check.
    kreg
  5. Davo17
    Davo17 Friend of Leo's
    I really like 50's wiring on the tele.
    BTW, you could use a no-load tone control (or make your own) and it can bypass the tone in any position, I like that for series tones.
  6. kreg
    kreg TDPRI Member
    6
    Jan 10, 2014
    France
    Thanks for this idea. Actually, I my dark sound come backwhen I roll off the tone pot.
