5 string neck thru bass - Buckeye burl + Mahogany
Discussion in 'Tele Home Depot' started by lbridenstine, Aug 19, 2014.
  1. lbridenstine
    lbridenstine Friend of Leo's
    Kalamazoo, MI
    Funny story too, he named the bass "Big Wu" because people kept telling him the bark area at the butt end looks like the Wu-Tang Clan symbol and apparently some people started chanting "Big Wu" during his band's set. :lol:
  2. paulmarr
    paulmarr Tele-Meister
    Adelaide, Australia
    Extremely impressed with the whole guitar Lisa ... If you could pump out 50 of these bad boys you could buy a house with the proceeds ... I could see a $4k price tag on it!
  3. lbridenstine
    Kalamazoo, MI
    That'd be nice! I wish I could.
  4. Mojotron
    Mojotron Poster Extraordinaire
    Seattle
    You should - WOW - awesome work!! That is amazing.
  5. lbridenstine
    Kalamazoo, MI
    Thank you!
  6. lbridenstine
    Kalamazoo, MI
    Videooooo
    Youtube turned the video kind of dull and grey... I'm hoping it's just some glitch that clears up on its own. Definitely doesn't look like that on my computer.
  7. twocup
    twocup Tele-Meister
    Walkersville, Maryland
    Sounds and looks fantastic! You are amazing! Can't wait for your next build.
  8. R. Stratenstein
    Loganville, Ga.
    Just absolutely fabulous. It sounds as good as it looks, which is beyond words!
  9. lbridenstine
    Kalamazoo, MI
    Thank you both!
  10. JebDude
    JebDude TDPRI Member
    Minnesota
    Beautiful bass. And he plays a LOT better than I can. Nice tone on that B.
    JB
  11. lbridenstine
    Kalamazoo, MI
    Thank you! And yeah, he's definitely better than me too.
  12. orangedrop
    orangedrop Friend of Leo's
    New York
    Hmm,
    Sounds pretty darn fine over the iPad driver, which is my acid test for a decent mix.
    Will check this out on the mains after D/Ling the audio later.
    Like that your friend used a small diaphragm condenser to record with.
    I take it this is an omni?
  13. lbridenstine
    Kalamazoo, MI
    He provided the amp and the playing, my other friend and I did the recording and video. That's our Rode NT5 (it's a cardioid), which sounds pretty great on everything. We actually sold all of our mics except for our pair of NT5s because those are the only ones we ever use anymore.
    We mixed in a bit of the direct out from the amp too.
  14. orangedrop
    New York
    NT-5
    Thanks for that Lisa!
    For a KM-84 knockoff, and a pair of em for less than half the price of a single old used original, they are a heck of a deal.
    Michael Joly at Octavamod is making capsules for those that really sound great, and are priced affordably.
    Not that you need to upgrade, but if you ever did want a bump in getting closer, check out the sound files.
    BTW,
    While the cardioid capsule will sound bassier because of the proximity effect, an omni capsule should have better low end extension so you get those very low notes recorded.
    Then you can EQ things any way you like if the mix needs it, or if it just sounds good.
  15. hemingway
    London, UK
    Extraordinary. I imagine this might bring you in a ton of business?
  16. lbridenstine
    Kalamazoo, MI
    Well, a bunch of his friends are asking, but who knows if anyone is serious about it. I kind of doubt it.
  17. lbridenstine
    Kalamazoo, MI
    Well... I thought I was done, but he sent me this picture last night and said the finish is blistering on the truss rod cover. Does anyone know what would cause this? I thought it looked like it got burned or something. He said it suddenly appeared within the last day.
  18. philspeed1
    philspeed1 Tele-Meister
    brisbane
    Cant remember what finish you used but i had some problem with clear laq.,over a shelack on my 336 build i ended up doing a lot of sanding back. Fortunatly before the build was finished. Still not sure why.
  19. lbridenstine
    Kalamazoo, MI
    I used water based lacquer (Target EM6000) over Mirror Coat Epoxy. I emailed Target and they told me it was fine to apply over epoxy as long as I sanded to a certain grit, which I did.
    What kind of problems did you have?
  20. philspeed1
    brisbane
    I had used shelaque to lay down the sunburst all went well. I let it dŕy a coupe of days did a light sand and applied the clear coats it was a while ago but i think when I was rubbing down blisters started to appear. It basicly started to delaminate from the shelaque not a good look I had used shelaqur flacks not sure if i would try that again
    . May be moisture has gotten in between layers on your finish or oil off your hands.
