5/16 forstner bit for ferrules
Discussion in 'The DIY Tool Shed' started by Jake Nelson, May 19, 2019.
  1. Jake Nelson
    Jake Nelson Tele-Meister
    Bemidji, MN
    Where are you guys getting your 5/16 forstner bits for drilling string ferrules?? none at stewmac or lmii and not sure the how good the china made ones are on ebay. what do you guys use?
    I don’t think i want to use a brad point because the back of the guitar is douglas fir (last one i’ll be making out of fir) and if the bits aren’t perfect they wander with the grain.
  2. RodeoTex
    Nueces Strip
    I recently got a full set from Rockler for $36.
    1/16 to 1/2".
    fenderchamp likes this.
  3. guitarbuilder
    DrASATele and jkingma like this.
  4. schmee
    schmee Poster Extraordinaire
    Last I got was at the local hardware store. Ace.
  5. guitarbuilder
  6. dogmeat
    dogmeat Tele-Holic
    Alaska
    Festool..... but bring money. on the other hand, you won't have to spend time sharpening it
    Flakey likes this.
  7. Jake Nelson
    Bemidji, MN
  8. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    Are you using a drill press or hand held drill?
    I have no problem using brad points in a drill press for ferrules.
    RodeoTex likes this.
  9. Jake Nelson
    Bemidji, MN
    Drill press for sure. the fir is vary brittle so i think i’ll go with the forstner right off.
  10. bullfrogblues
    Southeast Florida
    If the bits are sharp, either the brad point or forstner will do a very good job.
  11. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    What Marty said...
  12. telemnemonics
    Whether brad or forstner, the bit just needs to score and cut the perimeter before hogging out stock.
    Some forstenr bits hog out at the same time as they slice the perimeter, and will cut clean until they grab and tear.
    I sharpen either type if I want clean cuts!
    (Unless it's new, good quality and sharp)
  13. Jake Nelson
    Bemidji, MN
    Well I got all my parts lined up so I drilled my ferrule holes today. Nice day to work inside here in Minnesota as its raining.
    went well, had fun, not too much fuzz so i’m glad i waited for the forstner bit, i was too skeptical about using brad points.
    John Nicholas and eallen like this.
  14. bullfrogblues
    Southeast Florida
    Just for giggles I used my 5/16" brad point in a hand held drill and made these. I haven't beveled the edges or made a larger countersink. But just to show that brad points work well, too, if that's what you have. I know it's not a very good pic, but it shows a fairly clean cut.
