4 way wiring with revers wound neck ?
Discussion in 'Telecaster Discussion Forum' started by djangoRobinson2, Feb 6, 2013.
  1. djangoRobinson2
    djangoRobinson2 Tele-Meister
    115
    Dec 30, 2012
    newcastle
    Hi, Ive been struggling with my new 4 way wiring for a while now, turns out I have a reverse wound neck pickup lol, Its been wired up as shown in the SD website. So my question is, what do I swap around to compensate the reverse wiring? Cheers dave
  2. sjtalon
    sjtalon Poster Extraordinaire
  3. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
  4. sjtalon
    Try that first, it may not be you have to re-wire it. You HAVE to separate that cover jumper from the coil for 4 way's to work right.
  5. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    can you explain, what is the cover jumper?. I have a ground from the neck cover to the body, but it just kills every thing when attached . thanks
  6. LarsOS
    LarsOS Tele-Holic
    633
    Oct 24, 2011
    Norway
    You need to isolate the pickup cover from the coil. Snip, snip.
  7. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    ok, got that done and is taken care of the grounding issues, however positions 1 and 2 are both pups together for some reason where as 4 sound a little more nasal . The neck is much hotter. Basically I got neck in position 1?
  8. sjtalon
    Please describe again. Confusing you say you have neck on 1, then both on 1 ???
    # 1 is switch all the way back, BRIDGE only and so forth.
    Take a paper clip or screw driver and tap on the pickups in EACH position and note what is engaging.
    When you flip from 4 to 2, you should notice the tap on 4 being a little darker.
    Sometimes the slot in the cover plate is not long enough for the lever to travel all the way. Loosen the switch screws and try it. You can file the slot out if need be.
  9. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    position 1 and 2 are the same, with both pups engaged. position 4 is a little more nasal.
  10. Deaf Eddie
    Deaf Eddie Friend of Leo's
    Sunny San Diego, CA
    Gotta do this: unground/reground the metal cover
    That will probably cure your selector issues.
    If you have a phase issue (thin and nasally tone with both pups on), simply reverse the hot and negative leads ON THE 4-WAY - leave the cover connected to ground.
  11. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    Already done it and I swapped the wires round for the reverse wired neck pup. I appreciate all the help I can get, but please read the rest of the thread just so you know where its at , cheers dave
  12. Deaf Eddie
    Sunny San Diego, CA
    I read the whole thread, thank you. You might want to read this post where I explain the function of the 4-way mod, and perhaps read through that thread.
    The cause of your 1 & 2 throws being the same (both pups on) is almost certainly because the neck pup has another path to ground, besides through the switch. This is most commonly caused by not having completely isolated the cover's ground from the pickup's negative (aka ground) lead. The "clip, clip" post above, and my unground/reground doc are trying to help you make sure that you understand the concept and get this done correctly.
    Your second issue:
    IF you are always getting a thin and nasally tone when both pups are playing, then your neck pickup is connected out of phase with the bridge pickup. I don't care if it's "reverse wound" or whatever, if it SOUNDS out of phase, it IS out of phase. The one and only fix is to reverse the hot and negative leads on the switch, regardless of what other data you have in hand. BUT...
    If your wiring is all correct, and the tone is fine with both pups playing - but the pickup sounds "nasally" when you are certain it is playing by itself, sometimes an inadequate ground can thin out the tone of a pickup... so, this might be a different grounding issue, or it might be related to your "alternate path to ground" dilemma.
  13. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    cheers,I've got the clip done and as far as I know I've got the pup ground running to the switch and the cover ground running to the body. But to be honest it was like that before I don the clip aand added the cover ground. will check!
  14. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    I read your article, where it says the neck pup is connected directly to the vol, is that in standard 3 way wiring, because nothing is connected directly in 4 way ?
  15. Deaf Eddie
    Sunny San Diego, CA
    Uh... Read the post again, and I hope it will answer your question, because I'm not quite sure what you are asking.
    The short version:
    With the standard 3-way, the pickup hots are switched by the 3-way pickup selector. Their negative (aka grounds) leads are both connected directly to ground.
    With the 4-way mod, the neck pup's negative (aka ground) lead is switched by the pickup selector, it is NOT connected directly to ground.
    In the 4-way mod, the neck pickup's hot lead is connected to the volume pot, unswitched. Yes, it goes through several jumpers along the 4-way, but if you trace the path, you can see that it is always connected to the volume pot - never switched.
  16. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    Got it, so Its actually just cancelling the neck puo cheers
  17. djangoRobinson2
    115
    Dec 30, 2012
    newcastle
    well I've been up all night testing. I've got it exactly as in the diagram shown in post 2. and I get position 1 and 2 both pups out of sinc, position 3 and 4 both in sinc ? lol
  18. sjtalon
    By out of sinc you mean not per the diagram ??
    You did try it with the switch screws loose right ??
    Check the lugs on the switch, could be one is bent and not disengaging with the wiper. They twist easy, and that can happen when you solder the wires on or stuff everything in the cavity.
