4 way switch wiring problem
Discussion in 'Just Pickups' started by 120BPM, Jan 3, 2007.
  1. jim_pridx
    jim_pridx Tele-Afflicted
    Oct 1, 2008
    WI
    Hi Phil,
    Yes, the wire is directly soldered to the actual metal pickup cover. You might want to do a search for this on TDPRI, for someone at one time had some excellent images of the actual pickups. Generally speaking, though, and this won't apply to all pickups, but there's usually a very small wire that connects the cover to the pickup wiring that comes out of the bottom plate. That wire is cut so that the cover itself becomes isolated from the rest of the assembly. Then, it's grounded as we've discussed. If you could post some photos of the pickup or let us know what kind of pickup it is, that could be helpful, too.
    Jim
  2. piphey
    piphey TDPRI Member
    7
    Jan 6, 2009
    uk
    just tried that way - soldering direct to the cover. works fine until i ground the other end of the wire to the volume pot - then i lose the bridge pickup out of position 4 (same as position 3). not noticed a wire from the pickup to the cover. stock pickups on japanese 95 model.
    phil
  3. jim_pridx
    Oct 1, 2008
    WI
    Works fine until you ground it? Something is weird, and it sounds as though the cover ground hasn't been lifted from the main ground lead within the pickup. Without seeing the pickup, it's hard for me to tell, but perhaps someone who's familiar with those pups will pipe in here.
    Jim
  4. piphey
    piphey TDPRI Member
    7
    Jan 6, 2009
    uk
    aha - just cut the small wire jim and it seems to be sorted!! still a little noisy until you touch the strings on hi gain settings on the amp but i guess this is normal for single coils? excuse my ignorance but i've always been a humbucker man.
    phil
  5. jim_pridx
    Oct 1, 2008
    WI
    Ahhh.....so you found the wire and got it going. Great! Single-coils will be noisy, but I've found shielding to help quite a bit. It's not a cure-all, but it helps. It also sounds as though you may have some other grounding issues, but it could be the environment you're playing in, too. It probably isn't the pickup if you have to touch the strings to make it more quiet.
    I was a humbucker guy for a long time, too, so it's quite all right. Surprisingly, you may just find the fourth position on your Tele to be very "humbucker-like." It seems that some really enjoy that position and others don't, but I'll use it when I really want the Tele to sound a tad bit more like a Les Paul. Enjoy!
    Jim
  6. doombie22
    doombie22 TDPRI Member
    6
    Jun 20, 2008
    michigan
    the switches i got from stew mac for a strat mod i was doing didnt work at all, for the mod i tried. i bought a load of oak grigsby (sp) switches and all is right with the world. i still haven't got around to mapping out the stew mac switches.
  7. piphey
    piphey TDPRI Member
    7
    Jan 6, 2009
    uk
    hi jim
    yeah i think i may have a grounding issue somewhere. any ideas?
    phil
  8. jim_pridx
    Oct 1, 2008
    WI
    Hey Phil,
    It could be any number of things. If you're playing through an amp in an old house, the old electrical wiring can often times be the culprit. Even an electrical cable to your amp could be the culprit....or the amp itself.....or something a little haywire in the guitar. You really just have to question all the possible sources for any possible interference and track them down one by one. Still, in the end you may never find it. Sorry I can't help you much here.
    Jim
  9. piphey
    piphey TDPRI Member
    7
    Jan 6, 2009
    uk
    thanks for your help jim. just noticed you're in wisconsin. i'm from the uk but was working in racine last year. should have called round with my tele!!
    cheers
    phil
  10. jsganz
    jsganz TDPRI Member
    18
    Jul 16, 2009
    upstate NY
    I just hooked up an All-Parts 4 way switch to my the Stuart Blackguard
    pickups that arrived last week. Everything was fine except for the typical
    problem of the neck pickup always being on. Thanks to Deaf Eddie's postings
    I found the cause. On position #1, the ground for the neck pickup wasn't getting disconnected.
    I had to pry the one tab up just slightly on the underside of the switch to solve it. Now it works perfectly.
    I have "groundus interuptus" on the neck pickup when selecting only the bridge pickup. :rolleyes:
  11. lerpierre
    lerpierre NEW MEMBER!
    France
    Hello everybody,
    First of all this is a great place to get advice here, I found many answers to my questions. I am currently building a Telecaster project from several parts I gathered.
    I want a 4-way switch and I want to use a single-coil format humbucker as Bridge pickup with a Push/pull pot.
    I did not find any diagrams online for this setup. All I could find was 3-way switch + bridge HC + neck SC and 4-way switch + 2 single coils.
    Pick-ups are both Seymour Duncans.
    I was thinking of mixing two SD diagrams which are "Tele with 4 way switch" switch part and 1 HC + 1 SC & Push/pull for the rest. Yet I'm not sure it'll work. Can anyone help?
    Thanks a lot,
  12. Spearsmusic
    Spearsmusic Tele-Meister
    229
    Dec 3, 2009
    Thundertown
    My HW1 has the 4way/Bardens love it! and Talking about some output when u switch to Parallel holy smokes my leads get so big, and full. Sometimes they sound like 80's power metal solos lol. Maybe its time to drop the Metal Zone and find another distortion.
  13. Deaf Eddie
    Deaf Eddie Friend of Leo's
    Sunny San Diego, CA
    It works.
  14. Two Steps Back
    Two Steps Back TDPRI Member
    45
    Sep 25, 2009
    Hawaii
    Eddie, or anyone for that matter, when you wire up the 4 way switch, you have the two wires that are jumpered along the lugs of the switch and then on (1) to the vol pot lug and (2) to ground. When you wire these up, do you find it best to just use one wire for each of these, with the insulation stripped enough to contact both lugs on the switch? Or do you run a wire from the switch to the vol pot and another short jumper from lug to lug on the switch? Just about ready to try my hand at wiring and looking for last minute tips.
    I like the idea of one wire for each (seems tidier), but I'm not sure the bare wire between the lugs is a great idea.
  15. cc9cii
    cc9cii Friend of Leo's
    Feb 24, 2009
    Sydney
    If the bare part(s) of the wire won't short against anything, then go ahead and do that (Fender does). Otherwise (i.e. if there is a risk of them touching something) insulate or run separate wires.
  16. jonesy333
    jonesy333 Tele-Meister
    119
    Nov 15, 2009
    Indiana USA
    Slightly off topic but I just wired up the 3 way switch in my Tele and used the flip-flopped Series mod on the middle position so I have bridge/bridge-neck-series/neck. I have used the 4 way switches in my Tele many times but find the 3 way easier for switching fast on stage. I also like the more powerful series setting over the weaker parallel setting so I don't miss it. The series is also quieter an punchier with a lot more "Bark".
    BTW Great posts Deaf Eddie, I always love reading them and have learned a lot form what you have to say. You really know your stuff Sir.
  17. dannew02
    dannew02 Friend of Leo's
    Apr 2, 2010
    Erin Prarie, WI
    Thank you to everyone who shared their knowledge above, it helped a lot. But I can't seem to find any info about doing this mod if you DON'T have a covered neck pickup. Specifically, using a p90 instead of the stock Tele pup.
  18. guitarman_59
    guitarman_59 TDPRI Member
    43
    Sep 16, 2006
    Island
    Thanks Deaf Eddie for explaining this 4 way switch wiring. I started another thread before finding this one. :D
  19. AndyinLiverpool
    AndyinLiverpool TDPRI Member
    4
    Dec 24, 2011
    Liverpool
    Hello all
    I'm new here - please be nice.
    Can anyone help with a diagram for a 4 way switch with a humbucker bridge pup (with a coil tap switch), single coil neck pup, 2 tone pots and a master volume?
    I'd be most grateful.
    Thanks in advance.
  20. Telejonf
    Telejonf TDPRI Member
    3
    Feb 17, 2012
    Sydney Australia
    I bought a tele from a friend with the 4 way switch setup and it worked great....then I decided to put a Duncan Little 59 humbucker in the bridge. Now I have a loud buzz that only disappears if I touch the neck pickup or control plate. Any words of wisdom or solutions? The neck pickup is a Seymour Duncan Alnico II (I think)
