Join TDPRI Today
4 way Switch -- Please help
Discussion in 'Tele-Technical' started by djevans, Jan 21, 2013.
  1. djevans
    djevans Tele-Meister
    120
    Dec 13, 2012
    NC
    I am in the middle of a telecaster rebuild and have wired my plate in reverse and have tried to do the Fez Parka mod as well. (see picture)
    Anyway - the pickups work correctly in all positions, but the series position (position 1 - all the way back because its reversed) doesn't seem any louder or different than the normal fender parallel (position 3). In fact, the parallel actually may be a little louder than the series.
    Did I do something wrong? Please help.
    thanks
    David
  2. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Dec 19, 2011
    Merseyside UK
    The neck hot pup connections are not right on the switch.
  3. djevans
    120
    Dec 13, 2012
    NC
    Tuxedo:
    Could you please elaborate - what exactly is wrong? Thank you in advance for your time.
    David
  5. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    When you reverse the plate, you normally would not reverse the switch. The switch and its selections should be facing the same direction as standard.
  6. djevans
    120
    Dec 13, 2012
    NC
    Koko:
    I want the positions to be as listed on the picture. All the way back series, then bridge second from back then parallel second from front then front neck pickup. As I have drawn and labelled them in the picture - do i have them wrong?
  7. djevans
    120
    Dec 13, 2012
    NC
    Still looking for detailed help
    i realize that this involves walking through all the connections, but I can't find where I went wrong.
    Just to be clear, i have reversed the control plate so the bottom of the picture is toward the bridge. and I am calling position one the one with the switch lever all the way back toward the bridge.
    i want the positions to be series, bridge, parallel, neck.
    do i have it wired right?
  8. LarsOS
    LarsOS Tele-Holic
    633
    Oct 24, 2011
    Norway
    Did you notice the difference between your graphic and Tuxedo's?
  9. djevans
    120
    Dec 13, 2012
    NC
    OMG -- so sorry - I thought that his picture was just mine recopied. I DO see the difference.
    Thank you so so much.
    David
  10. djevans
    120
    Dec 13, 2012
    NC
    I think it is positioned like the standard - am I wrong?
  11. djevans
    120
    Dec 13, 2012
    NC
    Tuxedo - In your picture, it seems to me like the second position ( the one second from the back of the guitar) doesn't control anything. No circuits connected and it is supposed to be bridge only. Is this right?
  12. djevans
    120
    Dec 13, 2012
    NC
    If I am reading this right it is set as
    Series
    Neck
    Parallel
    Bridge
    ...and I wanted
    Series
    Bridge
    Parallel
    Neck
  13. LarsOS
    LarsOS Tele-Holic
    633
    Oct 24, 2011
    Norway
    So turn the switch around, and swap the neck hot with the bridge hot.
    You also may - or may not, it depends - need to lift the ground of the bridge pup, in the same way you've probably/hopefully already done with the neck pup.
  14. djevans
    120
    Dec 13, 2012
    NC
    You also may - or may not, it depends - need to lift the ground of the bridge pup, in the same way you've probably/hopefully already done with the neck pup.[/QUOTE]
    If I turn it around and switch the hots wouldn't that put the series last:
    Neck
    Parallel
    Bridge
    Series
    My original still seems right to me (see above) in concept -- I just can't figure out why its not working.
    To my ears it sounds like:
    1.Parallel
    2.Bridge
    3.Series (loudest, most full)
    4.Neck
