4-way Switch Options - Is one better/more useful?
Discussion in 'Telecaster Discussion Forum' started by BCblues55, Mar 11, 2019.
  1. honeycreek
    honeycreek Tele-Afflicted
    OH
    As others have said, I think it matters most what you use the most. I like bridge only and neck only and use them most of the time. I therefore like them at the end of the throws.
    BCblues55 likes this.
  2. Shuster
    Shuster Tele-Afflicted Silver Supporter
    Forth Planet from the Sun
    Is one better/more useful? ,,, ask this Guy;)
  3. BCblues55
    BCblues55 TDPRI Member Gold Supporter
    Charlottesville, Virginia
    This is great! Thank you for sharing!!
  4. ct_anthony
    ct_anthony Tele-Meister
    germany
    With a normal 4-way switch (make before break) and series/parallel next to each other you will short all signal to ground when switching between these two... this might result in unnecessary loud plopp...
  5. Guitarteach
    I wired mine to singles at either end. I prefer the single coil neck tone over series and want it accessible.
    Fast PU changes in a gig get me all the classic sounds by slamming it to the ends.
    That, combined with a flipped plate, makes it far more useful and practical than stock. I was always knocking the switch.
  6. sjtalon
    sjtalon Doctor of Teleocity
    Upper Peninsula of Michigan
    Ubetcha !
    I didn't make it, just copied it, so kudos to the originator !
  7. dobrojoe
    dobrojoe Tele-Meister
    England
    Always use the 5-way...
    Bridge
    Bridge and Neck out of phase *series*
    Bridge and neck parallel
    Bridge and neck series
    Neck
    Use bridge and neck series the most.
  8. BCblues55
    Do you have a diagram for that? I imagine it's pretty versatile!
    Thanks!
  9. sjtalon
  10. danpan
    danpan Tele-Meister
    South Dakota
    I have an Oak Grigsby switch in one of my Teles that I got from Stew Mac and I found it to be quite good. It is a very positive feeling switch. I purchased one from Amazon a couple years ago however, that came from Allparts. It too, was supposed to be an Oak Grigsby. I don't know if they have done a design change or not, but it didn't look or feel like the one I received from Stew Mac. In fact, it was junk and I ended up throwing it away. Has anyone else had a similar issue??
  11. SPUDCASTER
    Grangeville, Idaho
    The Fender Oak Grigsby that I purchased had some bent contacts.
    That was fun until I figured that out.
    Then the switch is real limp feeling through the positions and wiggled side to side cuts out.
    I just kind of deal with it. It does work, but I wouldn't purchase another one.
  12. BCblues55
    I’m really intrigued by the
    Neck
    Parallel
    Series
    Bridge
    option sjtalon’s diagram showed. Single-pickup positions on the ends, lower-output position next to the neck, and higher-output position next to the bridge. I’ll wire it up this weekend and let you know how it goes!
