4 Rustkaster steel body Telecasters !
Discussion in 'Tele Home Depot' started by The Crash Cowboy, Aug 31, 2016.
  1. The Crash Cowboy
    The Crash Cowboy Tele-Meister
    280
    Aug 31, 2016
    The Netherlands
    Beautiful Tungsten Inert Gas point welds. If the steel closes tight, it melts together without adding steel.
    I'll close the welds later, using MIG (or maybe also TIG ...).
  2. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
  3. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    ... and now Rustkaster 0002 is almost closed with TIG tack welds.
    This week I'll finish the wood core of Baritone Rustkaster 0003, so I can weld the sides to that one next week.
  4. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    Putting the template of the Baritone Tele to the wood block that will be the core of the body. I gave the template a little 'tilt', to route directly a little angle in the neck pocket; the Stetsbar that will go on the guitar needs it. Normally you place a shim in the pocket, but as I can route anything I want I don't need that shim.
    MoMo_the_Peach likes this.
  5. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
  6. MoMo_the_Peach
    MoMo_the_Peach TDPRI Member
    79
    Sep 26, 2016
    Any particular reason to have the centre wood block offset to the left?
  7. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    I wil saw out the center part today; reason of the offset now is finding the best part of the wood, without irregularities. There will be no wood where the stars are.
  8. adamkoop
    adamkoop Tele-Meister
    161
    Feb 18, 2016
    Halifax
    These are awesome !
    Gives me all kinds of bad ideas .. and that's a good thing.
    Also, my father's parents were Dutch, they came to Canada after the way .. so I suppose that makes us 50% brothers ?
    The Crash Cowboy likes this.
  9. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    We're all brothers here !
    And the baddest ideas are mostly the best. Like 'Why not make a steel body rusty guitar ?'
  10. adamkoop
    161
    Feb 18, 2016
    Halifax
    Exactly ! The company I work for has a lot of fabrication equipment .. and they make a lot of parts out of sheet aluminium and copper, i wonder if I could sweet talk them into make me some body panels
  11. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    Aluminium welding is very difficult ... and I guess copper needs to be soldered.
  12. rainbowbear998
    rainbowbear998 Tele-Meister
    111
    Jul 11, 2016
    Sydney, Australia
    I know it wouldn't be as nice, but copper could be spot welded, couldn't it?
  13. adamkoop
    161
    Feb 18, 2016
    Halifax
    You might be able weld copper, but it would probably make more sense to braze it.
    My thoughts in either case would have been to use a wood form for the sides and screw through into it
    The Crash Cowboy and bparnell57 like this.
  14. bparnell57
    bparnell57 Poster Extraordinaire
    Feb 10, 2014
    Philadelphia, PA
    A brazed copper tele would be epic...
  15. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    I sawed the sides of the wood core of the Baritone to fit, and painted it black with Hammerite, to protect the wood from the steel and to make it 'invisible' when looking trough the star pattern.
    Next, I drilled the holes in the top to screw the body to the wood core. They're not everywhere, cause the Stetsbar will be between them.
    bparnell57 and Mat UK like this.
  16. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    Some small stuf, some mistakes ...
    Engraving the serial numbers free hand. Needs some more work ...
    Cutting the holes in the back to install and reach the electronics. There will be cover plates on them.
    Budget Tele (only a volume pot):
    Baritone (3 way switch and volume pot):
    The Workshop:
    Countersink drill:
  17. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    I used to build electric starter motors for diesel trucks. The coils were copper and sometimes would need to be fused. Spot welding did well as far as holding together, but it did tend to pit the surface. Brazing does good, but it tends to bubble up and look ugly. Silver Solder works great on copper, it holds strongly and flows beautifully for a great finish.
  18. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    Slow progress: I attached and fitted the steel body parts of the Baritone to the wood core. Wednesday I can start welding the sides to it. For that I still had to drill the screw holes in the back, and do some filing on the wood of the sides of the neck pocket.
  19. The Crash Cowboy
    280
    Aug 31, 2016
    The Netherlands
    Oh, and last week I routed some cover plates and a pickup cover. I had to learn to use the machine first, so it was very time-consuming, and the result needs some shaping and finishing.
