24" scale neck on a 25.5" scale body?
Discussion in 'Other Guitars, other instruments' started by ValveFan, Feb 2, 2013.
  1. ValveFan
    ValveFan Tele-Meister
    452
    Feb 19, 2012
    North Idaho
    There's a frankenstein guitar on ebay that consists of a "standard" 25.5" scale strat style body bolted up to a 3/4 scale (24") neck. Will the intonation work out correctly with that combo? It's a Squier Showmaster body and a Duo-Sonic neck. I'm not all that serious about buying it but it made me curious.
  2. TheFullMonty
    TheFullMonty Tele-Holic
    515
    Dec 27, 2012
    Arizona
    Not unless he moved the bridge back an inch and a half. Which I imagine would be quite difficult with the trem routing in place for a 25.5" neck.
  3. TheFullMonty
    515
    Dec 27, 2012
    Arizona
    Disregard that information. I just woke up from a nap and I'm not in my right mind.
  4. ValveFan
    452
    Feb 19, 2012
    North Idaho
    Well, I can't remember the last time I was in my right mind...
    So, are you saying it will intonate correctly, or you don't know? I appreciate you taking the time to reply in any case.
  5. twiggymac
    twiggymac Tele-Holic
    669
    Jan 17, 2012
    Massachusetts - United States
    SHOULD be a conversion neck, which means it SHOULD be okay
  6. JasonRobert
    JasonRobert Tele-Holic
    if there is a picture of the whole guitar, in a birds eye view (ie looking straight down).. then you could print off the picture, then measure with a ruler from the nut to the 12th fret. Then measure from the 12th fret to the point the string goes over the bridge (or where the string first touches the saddles). as long as the picture is taken fairly straight, the two measurements should be roughly the same. If they are miles out, then the intonation will be wrong.
  7. AussieAndrew
    AussieAndrew Friend of Leo's
    Nov 7, 2012
    Vic AU
    Forget it and keep looking.
    Andrew.
  8. CrisHendrix
    CrisHendrix Tele-Afflicted
    Feb 11, 2011
    Plano, TX
    For it to work the bridge would've had to have been moved, or they wouldve had to use a conversion neck (24.75" I think, & I don't think fender makes conversion necks, I think warmoth does)
  9. Nick JD
    "Conversion" necks are basically just the same as capoing the first fret.
    The headstock is brought down 1.5"
  10. benderb9
    benderb9 Tele-Holic
    986
    Mar 3, 2011
    St Petersburg,FL
    I had put a 24.75" Mighty Mite neck on a body routed for a Fender scale 25.5" neck and had to cut out the front of the pickup route to get the bridge in the right place. I'd suspect that you's have to cut a lot of real estate out of that Strat body to make it work.
  11. crazydave911
    Feb 23, 2010
    East Tennessee
    Rondo sells them all the time.....................full size strat body with a conversion neck. It works...............no big gig ;)
    LINK
  12. AussieAndrew
    Nov 7, 2012
    Vic AU
    I just measured the distance between the nut & 12th fret, then the saddles & 12th fret. Major discrepency. About 2 1/2 frets worth.
    It's just a short scale neck on an unaltered full strat body. Intonation will still be lacking.
    Andrew.
  13. CrisHendrix
    Feb 11, 2011
    Plano, TX
    If the rondo does work they could just be making the body with the bridge moved up
    The problem is using a standard full scale fender body with a non-conversion short scale neck, something has to give
  14. crazydave911
    Feb 23, 2010
    East Tennessee
    It's just a shorter neck...............that's all............on this one at least :)
  15. AussieAndrew
    Nov 7, 2012
    Vic AU
    Yeah, it'll work but it wont be very useful as the intonation/harmonics will be out. The centre of it's scale won't be at the 12th fret, it'll be closer towards the body at say, the centre of the 13th fret for example. :(The exact distance between the nut & 12th fret needs to match the distance between the saddle & 12th fret (exactly) for correct intonation. Give & take a poofteenth for the thickness of each string-the very reason why saddles are adjustable.
    I 'spose it'd be OK for someone just starting out (playing open chords). It all depends on how fussy one is ~ I'm sure most stringslingers are pretty fussy. I am. :)
    Cheers,
    Andrew.
