Join TDPRI Today
2010 TDPRI $210 Challenge-????Caster
Discussion in '2010 TDPRI Tele Build Challenge' started by Jack Wells, Mar 2, 2010.
Thread Status:
Not open for further replies.
  1. Jack Wells
    Jack Wells Doctor of Teleocity
    Oct 19, 2003
    Albuquerque, USA
    Bought this piece of 8/4 hard maple yesterday.
    ......[​IMG]
  2. jrich99
    jrich99 Tele-Afflicted
    Sep 28, 2009
    AZ
    Can't wait to see what you come up with.
  3. Trigger_Hare
    Trigger_Hare TDPRI Member
    32
    Feb 10, 2005
    Nova Scotia, Canada
    And the plot thickens! I don't see myself doing anything but hitting refresh on my browser for the next two months. I'm excited you've joined the fray.
  5. winny pooh
    winny pooh Friend of Leo's
    Jan 24, 2006
    South London
    should be a good one
  6. robt57
    robt57 Telefied
    Feb 29, 2004
    Portland, OR
    Maybe I should just beg out now... :D
  7. Bluej58
    Bluej58 Tele-Holic
    944
    Nov 23, 2008
    Marseilles, Ill USA
  8. krauser2
    krauser2 Tele-Afflicted
    Jan 26, 2009
    SC
    you do good work....and are the reason I completely decided to change colors on my USACG BUILD.....this will be epic, I knows it already
  9. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    Don't expect too much guys. Still searching for an idea.
  10. fendorst
    fendorst Banned
    378
    Jun 18, 2009
    usa
    build a telecaster with it.
  11. tuuur
    tuuur Friend of Leo's
    Nov 12, 2006
    the Netherlands
    Yeah! Fendorst has the right idea!
    Serious though Jack, I'm glad you joined! This should become an entertaining and educational thread to say the least.
  12. robt57
    robt57 Telefied
    Feb 29, 2004
    Portland, OR
    My light bulb lit bright today, decide on some details. Changed the mantelcaster to the mental caster, just could not edit the OP / Thread title... ;)
  13. Dababy
    Dababy Tele-Meister
    395
    Jan 30, 2009
    Northeast Ohio
    Haha! You're reputation precedes you and now you have to live up to it!
    Even if you built a run-of-the-mill tele (which you never do), I'd still be interested because you write some of the most informative, interesting threads.
  14. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    Determining Body Wood Cost.
    I purchased an 8 ft piece of 8/4 hard maple ~ 8 in. wide. Actually it was a little less than 8 in. wide and less than 2 in. thick but they write it up as a 2x8. In theory I could get three bodies from this board. However there is checking on each end of the board. I've chosen to allow 3 in. waste at this end.
    ......[​IMG]
    Here are the two pieces that will make up the body. By joining the common edge in the center, you get a less visible joint line.
    ......[​IMG]
    Cost Calculation:
    2x8x(16+19)=560 cu. in.
    560/144=3.89 board feet.
    3.89 x $4.36 = $16.95 + 5.94% tax = $17.96
  15. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    My career hasn't allowed me to do any work on this project until today. I start by taking off some of the excess width from the boards which will make up the body blank.
    ......[​IMG]
    After running them through the jointer we're ready for the glue-up.
    ......[​IMG]
    Clamps in place.
    ......[​IMG]
    Glue squeeze-out wiped away.
    ......[​IMG]
    Since this wood measures just a hair over 1 3/4 in., I've decided not to run it through the thickness planer.
    ......[​IMG]
    Instead I'll use the belt sander and orbital sander to smooth it out.
    ......[​IMG]
    I attach the template to the blank with two screws ......... one in the bridge area and the other between the neck pocket area and neck pickup cavity area. Then I trace the shape and cavity outlines.
    ......[​IMG]
    ......[​IMG]
    A trip to the bandsaw................
    ......[​IMG]
    .... yields this.
    ......[​IMG]
  16. crispy king
    crispy king Tele-Meister
    102
    Jul 23, 2008
    North East UK
    Looking good so far.
    Is this going to be a standard tele, or have you got something more exciting in mind?
  17. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    I always rout my body shapes using 'downhill routing' as depicted in the following diagram making several shallow passes.
    ......[​IMG]
    This is as far as I could get with the template.
    ......[​IMG]
    I had dropped the bit into the collet as far as it would go. After removing the template there still wasn't enough bit to finish the job so I raised it in the collet about a half inch. There's still plenty of shaft in the collet.
    ......[​IMG]
    As you can see, now the bit can be raised high enough to finish the job.
    ......[​IMG]
    Body shape routing completed. The remainder was done in three passes. Some in earlier threads have spoken in a negative manner about my 'downhill routing' technique and some have actually said it caused tearout. I think they may be a little unclear on the concept or are inexperienced in the use of routers. Here we have a 1 3/4 in. body made from hard maple with no tearout.
    ......[​IMG]
    Hmmmm............. Let's see........... you can buy a standard Tele. Why build something you can buy? It won't be a typical Tele but don't expect something too exiting either.
  18. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    Predrilling cavities with a Forstner bit.
    ......[​IMG]
    Here's a little trick for getting your control cavity depth correct. Lay a piece of 1/4 in. material alongside the body and adjust the bit depth until it touches it.
    ......[​IMG]
    Cavities done. Next up ............ neck pocket.
    ......[​IMG]
    My neck pocket template attaches with the same screw holes as the body template so indexing is automatic. Since this template is only 1/4 in. MDF, it's good to have a pattern bit that's only 1/2 in. long.
    ......[​IMG]
    First router pass after predrilling the neck pocket.
    ......[​IMG]
    Neck pocket routing complete. It measures 0.630 in. deep ....... close enough.
    ......[​IMG]
    Enough for today. Now it's time for Lost.
  19. fraxs
    fraxs TDPRI Member
    56
    Jan 18, 2007
    Syracuse, NY
  20. CJFearn
    CJFearn Tele-Holic
    As my Old Man would've said: If I didn't know better I'd say it looks just like a guitar! Nice going Mr. Jack!
  21. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    Here's my set-up for drilling the jack hole. One could probably make a simple jig for doing this job. In fact, I seem to remember that Ed Hawley designed just such a jig.
    ......[​IMG]
    Well, this step in complete. Here's the outside...........
    ......[​IMG]
    ...... and here's the inside.
    ......[​IMG]
Thread Status:
