Join TDPRI Today
1978' Left Handed Custom - Bridge Pick up swap?
Discussion in 'Tele-Technical' started by grime99, Feb 8, 2013.
  1. grime99
    grime99 TDPRI Member
    6
    Feb 1, 2013
    BOSTON, MA
    Hi All,
    My 78' Custom is going in for a neck restoration and I've got a couple issues I'd like to take care of while she's in. (new bridge/saddles)
    But what I need advice on is switching the bridge pick up. I've never been 100% happy with it on its own. It sounds really thin. Mids and lows are really scooped. I use the neck humbucker the most, and occasionally both.
    My question is what bridge pickup would pair well with the original 78' humbucker? I don't want to swap the neck too. So I need a single coil that plays nice.
    I'm not looking for twang as much as a sustained chime and shimmer.
    Any help from this knowledgeable group would be greatly appreciated.
  2. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    I'd say something like the Duncan Donahue would be a great match. The highs are less pronounced and it's got some girth to it, but still sounds like a traditional Tele pickup. It pairs well with a humbucker.
    I'm not sure I've ever heard a Tele bridge pickup that had character you could describe as chime and shimmer, not without some good effects. Have you?
  3. grime99
    6
    Feb 1, 2013
    BOSTON, MA
    Thanks Koko Tele,
    I think my description is lacking. The chime and shimmer is the end result I would like (I'll use some subtle effects to get there.) Just looking for a PU that will serve as a platform to get there, and also pairing well with my original humbucker.
    What you describe is what I'm looking for and a more accurate description.
    Thanks!
  5. grime99
    6
    Feb 1, 2013
    BOSTON, MA
    Bump,
    Any other suggestions?
  6. The String King
    The String King Tele-Afflicted
    Mar 6, 2006
    England.
    I think Kokoteles point is that Tele bridge pickups arent generally associated with what you require.
    May I suggest a Tele sized P90? The lower output versions have a nice mid response without being too treble-y. Should pair well with a bucker, although I assume they are wide range humbuckers which are quite dark.
  7. grime99
    6
    Feb 1, 2013
    BOSTON, MA
    Thanks string king,
    I admittingly do not often use language very well :)
    I think Kokoteles definately clarified what I was looking for, was just wonderin if there are any other options for my custom (wide range / single coil)
