1967 Goya amp head
Discussion in 'Glowing Bottle Tube Amp Forum' started by Tomm Williams, Sep 3, 2017.
  1. Tomm Williams
    Tomm Williams Tele-Holic
    681
    Jun 11, 2016
    I'll check in the morning but mine has the 8417 power tubes and I believe 4 12ax7's?
    jimash likes this.
  2. Tomm Williams
    681
    Jun 11, 2016
    Ok mine has a pair of 8417's, three 12ax7"s and a 7247. The 12ax7's are original Guild branded tubes made in Holland
  3. charlie chitlin
    Spring City, Pa
    Very sanitary wiring.
    Cool!
  4. Silverface
    Mar 2, 2003
    Lawndale CA
    I thought that might be the case. Most of the ones I've seen are fairly simple.
    The "project" one I'm slowly working through isn't here at the moment, but it has split chassis (separate preamp and power amp) with (as I recall) 2 x 6550, 1x 12AX7, 1 x 12AU7, 1 x 7199 & 1 x 0A2 in the power amp and one each 6GF7, 12DW7 & 12AX7 in the preamp. Plus one power and one signal umbilical connecting the chassis with wiring split between terminal strips and true point-to point. No known schematic making it great fun.
    The initial reaction of a couple tech buddies upon first looking at it was "know anyone with a boat that's lacking an anchor?" :confused:
  5. brookdalebill
    Nov 15, 2009
    Austin, Tx
    So, how does it sound?
  6. Tomm Williams
    681
    Jun 11, 2016
    I did some more research today that showed a remote chance Hagstrom might have had a hand in this?
    Any opinions ?
  7. Tomm Williams
    681
    Jun 11, 2016
    I haven't received it yet, it's going to the shop before I can fire it up.
  8. Tomm Williams
    681
    Jun 11, 2016
    I didn't know any of the Thunderbass's used that two section design.
  9. Silverface
    Mar 2, 2003
    Lawndale CA
    there are a few others around but none with 9 tubes.
  10. brookdalebill
    Nov 15, 2009
    Austin, Tx
    Oops, sorry.
  11. Dacious
    Dacious Poster Extraordinaire
    Mar 16, 2003
    Godzone
    I have a sneaking decision a Western importer may have lobbied a name change to Guyatone. I worked on an early 70's Twin Reverb clone that looked dead-on the same sort of PCB. And I've seen a small Noval-pin EL84ish powertube amp combo with knobs and multiple controls that look like those. IIRC it used oddball preamp tubes and possibly a 6BM8 somewhere.
  12. Tomm Williams
    681
    Jun 11, 2016
    The orderliness of all the wiring reminds me of my West German Klemt. I've seen the inside of a few amps and they usually don't look this precise. Whoever built this appeared to have high standards.
  13. Twang Banger
    Twang Banger Tele-Meister
    210
    Apr 7, 2011
    Jacksonville, Fla
    Didn't Julie Andrews play one in the Sound of Music?
    jimash likes this.
  14. Tomm Williams
    681
    Jun 11, 2016
    Correct
  15. Tomm Williams
    681
    Jun 11, 2016
    I should have it Tuesday and then it's headed to Skip Simmons. I'm hoping he recognizes something in the construction
    Right now I'm leaning Guild
