1961 Stratocaster build
Discussion in 'Tele Home Depot' started by preeb, Mar 15, 2009.
  1. melomanarock
    melomanarock Tele-Holic
    541
    Jul 5, 2010
    Argentina
    Great.. It was something that just got me thinking.. Thanks!
  2. cap217
    cap217 Tele-Holic
    585
    Jan 8, 2011
    Cleveland
    Old thread but one of the best. 2 questions:
    -Why do you pre nitro your decals? Is this something I can/should do to the F logos I install?
    -How did Fender paint their necks? Was the whole heel covered by a "holder or stick" or were the mounted by the truss rod screw and the whole neck painted?
  3. Sterling Sound
    Sterling Sound Tele-Meister
    343
    Oct 18, 2009
    The Hague
  4. Greg M
    Greg M Tele-Holic
    909
    Sep 4, 2003
    Virginia
    Great looking Strats Gil! You're staying busy huh? :D
  5. devoewoolf
    devoewoolf TDPRI Member
    11
    Apr 12, 2008
    Salt lake Cty,Utah
    Hello preeb,thank you for your sharing and expertice, and I like the way you deal with some of the cantancorous reponses shows a lot of class and heart.thank you.Question...you seemed to have no problem using Freshly arrived Brazillian fboards with no curing or adjusting time to your build,doesn't that worry you?Thank you again Bill Woolf
  6. preeb
    preeb Poster Extraordinaire Vendor Member
    Sep 10, 2008
    Sonoran Desert
    The BRRW is pre CITES certified and is very old and dry. No issues whatsoever.
  7. devoewoolf
    11
    Apr 12, 2008
    Salt lake Cty,Utah
    That was fast..thank you
  8. alanstclair
    alanstclair TDPRI Member
    3
    Nov 29, 2011
    portugal
    Hi Gil,
    You must need a time machine to answer some of the questions from your old posts, but if you are up for it,back to 2009.......:
    Could you tell me how much you reduce the nut end of your radiusing jig to attain the even edge thickness of the fingerboard? This has always baffled me when I radiused boards with a block or a more recently on a CNC...once you cut the taper on the board it MUST be a different thickness at the nut end to the body end.
    So I guess that using your trick you are effectively making a compound radius! :)
  9. preeb
    Sep 10, 2008
    Sonoran Desert
    That is correct.
    When doing the radius the normal way measure the thickness difference and use that delta to drop the nut end swing arm lower (longer arm length).
    t guitar floyd likes this.
  10. alanstclair
    3
    Nov 29, 2011
    portugal
    Thanks Gil,
    In your procedure, the fingerboard is already tapered, so the difference in thickness is visible to measure, but radiusing a pre tapered board would need a calculation, I guess.
    Best run some tapered test blanks and record the measurement....or always taper before radiusing!! Bingo!
  11. t guitar floyd
    t guitar floyd Tele-Holic
    747
    Feb 4, 2016
    sw US
    Just saw this thread for the first time and am amazed at your work! Thanks for sharing. Is the Sonoran Desert where you live now? Anywhere near Tucson, Arizona?
