1960 Center Volume 5G12 Brown Concert
Discussion in 'Amp Central Station' started by rw4951, Oct 7, 2018.
  1. rw4951
    rw4951 TDPRI Member
    11
    Jan 8, 2012
    Coeur d'Alene, ID
    I recently picked up this really cool 1960 Concert. It's an early one, s/n 00488, making it one of the first 500 Pro, Bandmaster or Concerts made (they all used the same chassis & circuit board). It has all of the early brown 5GX series hallmarks:
    Pinkish-beige Tolex
    Tweed Oxstripe grille cloth
    No round-over on top of cab
    Center volume controls
    Lighter brown face plates
    5 preamp tubes
    Pulse Adj. hole on rear panel
    RCA speaker jack
    Early style brown foot-switch
    The best part is that these 5G12 Concerts used the same transformers as the Tweed Bassmans, which were being made concurrently. I've noticed that a lot of these early Concerts have "replaced" transformers. I can only guess that the iron usually winds up in a Tweed Bassman restoration. This one has all original iron.
    Going to be doing a restoration this one, as well as documenting the 5GX circuit for a few upcoming builds. Will post a few pics along the way...
  2. BobbyZ
    BobbyZ Doctor of Teleocity
    Jan 12, 2011
    Snellman MN
    That is one seriously cool amp.
    Expecially for only $296.40. :)
    theprofessor likes this.
  3. Axis29
    Jan 2, 2007
    La Quinta, CA
    Kermit bought himself one sexy amp! (So did @rw4951!)
  4. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Jul 10, 2014
    Meiners Oaks CA.
  5. John E
    John E Tele-Afflicted
    Connecticut
    I had one and stupidly sold it. It was just a great GREAT sounding amp, and the vibrato was to die for. So trippy and cool sounding. Damn I miss that amp, good luck with it.
  6. schmee
    schmee Friend of Leo's
    Jun 2, 2003
    Wow, that's a great find. Got the alnico Jensens too!
  7. rw4951
    rw4951 TDPRI Member
    11
    Jan 8, 2012
    Coeur d'Alene, ID
    Kermit dropped about $2400 for this rig, adjusted for inflation...
    theprofessor, BobbyZ and Axis29 like this.
  8. rw4951
    rw4951 TDPRI Member
    11
    Jan 8, 2012
    Coeur d'Alene, ID
    The amp came with a Dec '59 and Jan '60 P10R, and (2) Jan '61 P10Q's. All (4) have bells. Research so far indicates that these early ones would have had (4) P10R's from the factory.
    The R's are original cones. The Q's have been reconed with some generic cones. Will send the Q's to Weber for correct ribbed, curved seam cones, PVC and felt dust covers.
    RoscoeElegante likes this.
  9. dannyh
    dannyh Tele-Afflicted
    Jul 1, 2005
    North Texas
    Wow, great amp! Congrats!
  10. Old Tele man
    Old Tele man Friend of Leo's
    May 10, 2017
    Tucson, AZ
    The capped PULSE ADJ. was meant for adjustment of TREMOLO amplitude...but wasn't used in production...although some early models might have actually used it.
    Anybody got one with a pot in that location?
  11. Ringo
    Ringo Poster Extraordinaire
    Mar 16, 2003
    Memphis TN
    That's a very cool amp.
    I recently acquired a 1960 Vibrasonic which as I understand is a very similar amp maybe even the same circuit except it's a 1-15 combo.
    Unfortunately it appears that someone had robbed the original transformers and most of the caps.
    I found a local tech who gutted it and rebuilt it with as many original parts as possible. He did have to use some new transformers , when he got done it's a great sounding amp and though not as collectible as an all original, it should be totally reliable.
    I imagine the Concert 4-10 amp sounds great too, or will after you get it all done.
    IIRC I saw a video of Rory Gallagher using a brown Concert and maybe a tweed Bassman live, and it sounded great.
    My Vibrasonic amp has the center volume too.
    I have found it's kinda hard to get used to that after playing BF and SF Fender amps for so long, more than once I've reached over and turned up the treble meaning to turn the volume up.
  12. theprofessor
    theprofessor Friend of Leo's
    Aug 8, 2016
    Chattanooga, TN
  13. Viejo
    Viejo Tele-Holic
    917
    Feb 12, 2011
    Central IL
    Rare as hens teeth.
    ponce likes this.
  14. Obelisk
    Obelisk Tele-Holic
    889
    Apr 1, 2013
    NW USA
    The earlier Concert uses the same 45294 output transformer that a Bassman did, but both the power transformer & choke are different.
  15. teletimetx
    teletimetx Poster Extraordinaire
    Jul 25, 2011
    Houston, TX
    sweet... thanks for posting!
  16. David Barnett
  17. Ricky D.
    Ricky D. Poster Extraordinaire
    Oct 22, 2006
    Raleigh, North Carolina
    Be sure to get those caps serviced. If they are original or of uncertain age, they could blow out and take out your transformers.
    Seriously cool amp!
    thunderbyrd and BobbyZ like this.
  18. rw4951
    rw4951 TDPRI Member
    11
    Jan 8, 2012
    Coeur d'Alene, ID
    Thanks, you are correct. Can't edit the original post. Tweed Bassman OT is 45249.
  19. rw4951
    rw4951 TDPRI Member
    11
    Jan 8, 2012
    Coeur d'Alene, ID
    Roger that. The filter caps have been replaced with IC's of unknown age. I'm replacing them with new Spague Atom's. Cathode bypass and bias caps have also been replaced at some point. They will also be replaced with new Spagues.
    Ricky D. likes this.
