1959 ES-335TD proto build
Discussion in 'Tele Home Depot' started by preeb, May 3, 2011.
  1. deaconque
    deaconque Tele-Meister
    Virginia
    Was there a reason he was holding the guitar at an angle while making a pass through the router? I'm sure it has something to do with the carved top but the angle he was holding it at didn't seem to follow the angle of the top.:confused:
  2. telemcCaster
    telemcCaster Tele-Holic
    Michigan
    Hey there Captain. You are welcome. I think it is important to get this technology out there because it is such a good design and there really are differences between the modern and old ES guitars.
  3. telemcCaster
    Michigan
    Hi Fred,
    You are certainly welcome. Can't wait to see the 355.
    Cellos and DB are made similarly and almost always from big factories. I have never seen a small scale laminated bass made. Aarnold Schnitzer is making the New New Standard but I think he gets his plates from Germany where a lot of this laminated construction happens. Big sheets are not a big problem if the big equipment is available. It just gets sliced off the log and if wide enough then it covers that size. The cross grain is endless.
  4. telemcCaster
    Michigan
    :cool: You are welcome.
  5. telemcCaster
    Michigan
    Yes I think so. There are formulas for it. But they are based on radius and this has changing radius so it would be complicated.
  6. telemcCaster
    Michigan
    It should be held flat, parallel with the rims. Not sure what was going on there.
  7. landsharkey
    landsharkey TDPRI Member
    IL
    Really a great tip! If it is not difficult, can you do a similar sonic test for a completed 3 and 4 ply bodies? It would be nice to know when they switched to the 3-ply - possibly late 60's?
  8. exluthier
    exluthier Tele-Meister
    St. Louis, Missouri
    Gibson kind of excels at that. You should see the huge shaper bit that puts the open book headstock shape on the top the the reissue LPs. Thing sounds like a hurricane when it starts up.
  9. jglenn
    jglenn Tele-Afflicted
    everett wa
    Man there are some talented folks here!I would be lucky if i could build a lap steel,and you guys are doing es335s!
  10. zx1012r
    zx1012r TDPRI Member
    western CT
    I really think the router level was adjusted to the thickness of his fingers. That way it stays level on the plastic rim around the router bit, and the top arch stays off the table while the edge is resting on his fingers!
  11. jonal335
    jonal335 Tele-Holic
    vancouver island bc
    I'm so glad to see this thread start up, many of have been looking forward to it for quite a while. The 335 is my favorite of the many,many guitars I've played over the years...
  12. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    There was a pretty large bearing surface on that shaper bit, and a UHMW plastic 'donut' at the bottom that sets the depth of cut. I'm sure the side ended up parallel when he routed it.
    Amazing to watch how fast these people work. In my building 'career' I've maybe bound 20 guitars, they probably do that every day.
  13. Nick JD
    Queensland, Australia
    All about the donut! Although the folks at the scraping bench will yell at him if he's too far off 90 degrees, I'll bet. I think he's flush trimming the sides as well.
  14. telemcCaster
    Michigan
    Hi P
    I have not made a full body with the 3 ply plates. I do testing on the finished bodies and will be showing the results. I have several now to compare and most are the same but I did compare one with a hard maple block to a soft maple one. I will show that later.
    Can we go public with your drawing yet?
  15. telemcCaster
    Michigan
    I will show you my ledge router soon.
    Anyone else having trouble with the forum software freezing?
  16. Daintree
    Daintree TDPRI Member
    Thanks for taking the time to post this build, much appreciated!
    Gonna sit back and watch some real talent at work...
  17. telemcCaster
    Michigan
    Ok I had an unresponsive script message freezing up my old mac. I should be able to post now.
    First thing I want to show tonight is my VINTAGE vacuum pump :rolleyes::lol::p
      File size:
      35.3 KB
      291
  18. telemcCaster
    Michigan
    After about 30 plates, the mold looks like this. I use the same plastic and bleeder cloth until it falls apart.
    The veneers have to stay in a humidity controlled environment.
  19. telemcCaster
    Michigan
    There were plenty of "factory seconds" for various reasons.
  20. telemcCaster
    Michigan
    The shop is really small and cramped but has a tremendous ability to get things done. Thanks to a combination of drawers and drawers of hand tools and a few important stationary tools. This combination machine does many things with ease. It has a huge shaper, planer, jointer, cross cut table saw. And the band saw is another frequently used tool. I spend a lot of time at the drill press.
