1956 Telecaster build
Discussion in 'Tele Home Depot' started by preeb, Jan 29, 2009.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sep 10, 2008
    Sonoran Desert
    OK.... so here we go again...
    I already have a couple of pre-cbs bass builds posted on the "The Bass Place" section (1956 p ,1957 p ) and I was asked to post guitar builds as well, so I promissed to do so as soon as I'll get a new guitar ordered. I'm working on a 1955 Strat and a 1955 Telecaster at the moment and in this thread I will show the Tele build process.
    This is a late 1955 reproduction with a fat soft V neck, feather weight, white guard (although I was trying to talk the customer into a black bakelite without luck) and thin nitro blonde finish.
    The templates were made from a 1954 original Telecaster which will be OK for 55-58 models as well. It took 3 days to measure and cut the templates very accurately, after all this is a critical stage in the build and will be reusable in the future too.
    Body basic template
    Complete set
    imploration likes this.
  2. preeb
    Sep 10, 2008
    Sonoran Desert
    I start with the neck (for some reason I always do...).
    Old growth maple blank is selected and neck shape outline is penciled
    Shape is cut right outside the line
    template is attached correctly (pre-cbs screw locations) to the back
  3. preeb
    Sep 10, 2008
    Sonoran Desert
    Very carefully flush trimmed with a special spiral router bit
    Thin period correct truss rod channel is routed on the back
  4. twangcaster1
    twangcaster1 Friend of Leo's
    Feb 28, 2008
    Nashville, TN
    Looks like you know what you're doin', man! Cool stuff.
  5. preeb
    Sep 10, 2008
    Sonoran Desert
    Headstock is thinned down to allow the truss rod insertion channel drill
    Headstock plug side hole is drilled with a jig - aligned and in the correct angle
    Came out nicely - in the middle and flushed with the channel bottom
    Same for the heel side
  6. preeb
    Sep 10, 2008
    Sonoran Desert
    I could never find an after market period correct truss rod so I build my own to match the pre-cbs rods 100%
    Rod is inserted (actually - hammered in)
    Washer and nut are installed and rod is tested to function properly
    Headstock transition is partialy shaped and koa plug is glued in
    Koa skunk stripe is cut
  7. preeb
    Sep 10, 2008
    Sonoran Desert
    Skunk stripe is sanded and shaped for a tight fit
    tight fit is a must
  8. preeb
    Sep 10, 2008
    Sonoran Desert
    When dry it is flushed and sanded
    tuner holes leads are drilled
  9. preeb
    Sep 10, 2008
    Sonoran Desert
    Back of neck is shaped the pre-cbs way with a 56 cutter/shaper (I made a special cutters for each pre-cbs year 1950-1965)
    Shape is roughly done. it will be transitioned and sanded smooth of course
    some transition shaping here
  10. preeb
    Sep 10, 2008
    Sonoran Desert
    more shaping
    shaped to original type specs
    7.25" Radius is cut "the old original way" (sorry - no jig picture here...)
  11. preeb
    Sep 10, 2008
    Sonoran Desert
    Headstock transition is cut
    once again - period correct radius and plug shape
    nut and fret slots are cut on the jig
  12. preeb
    Sep 10, 2008
    Sonoran Desert
    My daughter thinks the neck is OK. Fat soft V is her favorite neck shape !!!
    position marks are ... well... marked
    and drilled
  13. preeb
    Sep 10, 2008
    Sonoran Desert
    position markers are hammered in (Yes, they are bakelite of course)
    and flush sanded (notice the greenish bakelite dust - lots of fun...)
    nut slot is smoothed
  14. preeb
    Sep 10, 2008
    Sonoran Desert
    Nut is cut from yellow cammel bone (the bone is yellow not the cammel... well... maybe both)
    ...and hide glued very tightly (tightly is important)
    Neck is done for now. I'll get to the body.
  15. preeb
    Sep 10, 2008
    Sonoran Desert
    Body is made of feather weight old growth swamp ash. Same kind Leo used in the mid 50's. Some of the lightest and greatest guitars were made in the mid 50's period. This is my personal favorite period for Fender guitars and basses.
    Those blanks are carefuly stored...
    Outer shape location is selected and penciled
    Cut right outside the line
  16. preeb
    Sep 10, 2008
    Sonoran Desert
    Roughly cut body
    Template is attached (once again, with period correct screws location)
    Body is drum sanded to save router bit labour
    ... and flush trimmed on the router table
  17. Lobstapickin
    Lobstapickin Tele-Meister
    365
    Sep 23, 2004
  18. preeb
    Sep 10, 2008
    Sonoran Desert
    Neck mounting holes are drilled
    Top routing template is attached (correctly...) to the body
    Routs are made to correct depth (I say "correct" too much... I know... I don't care...)
    Body roundover is shaped on the router table
  19. preeb
    Sep 10, 2008
    Sonoran Desert
    Neck is fitted to body to check that fitting is as tight as a... whatever
    It's very tight alright
    Bridge holes are drilled from the top (hope the holes will not come through the back in a straight line... if you know what I mean)
