1955 Stratocaster Build
Discussion in 'Tele Home Depot' started by preeb, Feb 17, 2009.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sep 10, 2008
    Sonoran Desert
    Hi again...
    This build is of a feather weight mid 50's strat. I'm going to build 2 necks for this guitar, one will be a 54 style plain maple, and the second is a soft V fat boat neck heavily flamed. Color might be a 1 tone burst (Yes... 1 tone... like on early 54 strats which didn't have a yellow in the middle... just brown around the edges)or blonde. we'll see...
    Neck maple blanks... from my old growth stock. I will select the *one* after cutting them to correct dimension and give them the tunning forks test
    Roughly shaped on the band saw and thinned down to 1"
    This is the one!!! bright as bright can be, and a great match to a lightweight soft swamp ash.
  2. preeb
    Sep 10, 2008
    Sonoran Desert
    54 Strat neck template is placed on the selected blank and pin holes are marked
    and drilled
    Template attached
  3. preeb
    Sep 10, 2008
    Sonoran Desert
    and neck shape is routed flush on the router table with an upward spiral bit
    Trussrod channel is routed
    Headstock roughly thinned and truss rod holes drilled (Sorry, forgot to take the shots but it's the same like in my other posted builds...)
    Truss rod is bent and cut to length (and checked against the blue print)
  4. preeb
    Sep 10, 2008
    Sonoran Desert
    TR installed, Skunk stripe & plug glued and nut is installed.
    TR is tested. All OK.
  5. preeb
    Sep 10, 2008
    Sonoran Desert
    Back of neck is cut with a 54 shaper bit (see my other threads for this method)
    Transitioned
  6. preeb
    Sep 10, 2008
    Sonoran Desert
    Transitions closeups
    Radiused to 7.25" on the sander jig
    nut anf fret slots cut on the fret cutter jig
  7. preeb
    Sep 10, 2008
    Sonoran Desert
    Bakelite dot marks installed and flush sanded
    Frets are installed sideways (see 55 tele thread for more info)
    Edges are over-rounded along with the fret ends
    noah330 likes this.
  8. preeb
    Sep 10, 2008
    Sonoran Desert
    One neck down one neck to go.... but I feel like cutting the body now...
    Templates templates..... quite a few for a Strat...
    Body blank was selected. It's a classic grained strat body with a round figured upper part and straight bottom. Very light piece of Swamp Ash.
    Body outer line is located and penciled
    Band sawed right outside the line
    Looking good
  9. preeb
    Sep 10, 2008
    Sonoran Desert
    Pin holes drilled and back template is attached
    Robosanded to about 1mm off the line
    and flush routed
    Neck mounting holes drilled
  10. preeb
    Sep 10, 2008
    Sonoran Desert
    Back bridge cavity is routed
    Check out this template attachment. It will help in routing the deeper part correctly later
    first stage done
  11. preeb
    Sep 10, 2008
    Sonoran Desert
    Block cavity is deepened
    Top body template is now attached
    Smaller block cavity is routed
    Looks nice and clean
  12. preeb
    Sep 10, 2008
    Sonoran Desert
    Neck pocket, pu and the rest is routed to first level depth
    Control and input jack cavities are routed to second level depth
    Deep round-over for this body
  13. preeb
    Sep 10, 2008
    Sonoran Desert
    Looks like a strat body... doesn't it?
    and back
    these transitions will be shaped by hand later
  14. preeb
    Sep 10, 2008
    Sonoran Desert
    Neck is tested in body cavity. Very tight (Yeah!!!)
    noah330 likes this.
  15. preeb
    Sep 10, 2008
    Sonoran Desert
    Transitions are done
    Back relief contour is sanded on the 15" sanding wheel
    and arm rest relief on the belt sander table (just like in the old days...) - I love this stage...
    I'm cutting those deep... 54/5 bodies were like that deep deep contours and lots of hand sanding and smoothing (they couldn't afford this in 56 when production numbers got higher...)
  16. preeb
    Sep 10, 2008
    Sonoran Desert
    That's the result of the tooling stage
    And... the hand sanding smooth lines
  17. preeb
    Sep 10, 2008
    Sonoran Desert
    A few more angles of the contours (deep and gracefull)
  18. preeb
    Sep 10, 2008
    Sonoran Desert
    Body looks good and almost done
    Neck pocket ends are cut correctly on both sides
  19. TeleJelly
    TeleJelly Tele-Meister
    325
    Mar 3, 2008
    Ohio
    I looking at this thread wondering when I can move my family of 5 into a shanty behind your home and be your apprentice :)
    They say a picture is worth a thousand words...and I believe this thread has spoke volumes already!
  20. preeb
    Sep 10, 2008
    Sonoran Desert
    Bridge mounting holes drilled to correct depth
    Bridge is tested against the holes. All is OK
    I usually use Gotoh tuners and bridges. Correct materials and measures without BS butique price tag...
    Woodwork is pretty much done. A little sanding before finishing and tuner holes and that's it.
