1951 Pro Amp "kit"
Discussion in 'Glowing Bottle Tube Amp Forum' started by Mike Simpson, Jul 8, 2016.
  1. Maricopa
    Maricopa Friend of Leo's
    Feb 4, 2009
    Phx, AZ
    There's also a Hoodoo Brewing Co. in Alaska.
  2. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    Here is a shot of the raw tweed and the shellac mixture tint I am going with. I will top coat this with lacquer to seal it.
    El Tele Lobo likes this.
  3. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    Here is the cabinet before the tint and the grill cloth was not stretched yet.
    Here is the tinted cabinet with the grill cloth stretched.
    King Fan likes this.
  4. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    Final of coats of lacquer done.
  5. bparnell57
    bparnell57 Poster Extraordinaire
    Feb 10, 2014
    Philadelphia, PA
    Now it just needs some light relic work to make the back panels match!
  6. bparnell57
    Feb 10, 2014
    Philadelphia, PA
  7. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    Thanks!
    It is not perfect but so far I have spent about $160 on the recover, grill cloth, shellac, lacquer, handle, filter caps, couple of resistors, power switch, feet, grounded cord and a few other things. I switched back to the old handle hardware after this pic. I need a few little nuts and washers to put it all back together. Since the OT is mounted on the speaker I didn't want to start testing voltages with the tubes in until I had the speaker connected to the OT.
  8. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    Put the logo back on
    Rock-Ola, King Fan and keithb7 like this.
  9. King Fan
    Jan 1, 2013
    Salt Lake City
    There's a society for you pro archaeology restorers. Great work!
  10. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    I powered the amp up today, first without any tubes and then with the rectifier only checking voltages.
    Using a light bulb limiter all is good. With the power tubes in the light bulb glows a peachy color brighter than I thought it should but I tried both of my other Pro Amps and they both glow about the same brightness. The amp works and plays with a very slight distortion on notes that are not loud and should be clean. The amp is quiet and there are no strange noises except for a little distortion on notes that should be clean and that could be the speaker.
    Rectifier
    Pin 4 362 v
    Pin 6 362 v
    OT center tap is on rectifier pin 8 and the primaries on pin 3 of both of the 6L6 is 290 v on the plates of both tubes
    The filter caps B+ voltage 295 v, 295 v, 247 v, 224 v the 3rd and 4th showing the voltage drop from the 10k resistors
    Heater voltage on all the tubes is 5.25 v + or - .03
    It works !
  11. rebelwoclue
    rebelwoclue Poster Extraordinaire Platinum Supporter
    Jan 15, 2012
    kentucky
    It's alive!!!!
    Nice work!
  12. Mike Eskimo
    Mike Eskimo Doctor of Teleocity Ad Free Member
    Nov 9, 2008
    Detroit
    That looks fantastic. It was sleeping all those years waiting for you to wake it up...
    El Tele Lobo and boredguy6060 like this.
  13. boredguy6060
    boredguy6060 Friend of Leo's
    Mar 28, 2012
    Sou Cal
    Godzilla did the same thing!
  14. rebelwoclue
    Jan 15, 2012
    kentucky
  15. brapscallion
    brapscallion TDPRI Member
    91
    Jun 8, 2016
    Preston, UK
  16. peteb
    peteb Friend of Leo's
    Apr 25, 2003
    Cascadia
    I really like how that amp came togethor.
  17. screamin eagle
    screamin eagle Friend of Leo's
    Oct 9, 2008
    S. CA
    I have a hot rodded 5c5 based amp and regularly play through my buddy's original 5d5. Tweed pro with octal preamp tubes really is a special thing.
    FenderLover likes this.
