120 to 220 v conversion - tweed champ 5F1
Discussion in 'Shock Brother's DIY Amps' started by flyinjack, May 14, 2019.
  1. flyinjack
    flyinjack TDPRI Member
    Hello all,
    I am trying to convert a 5F1 tweed champ kit from 120 V to 220 V. I have attached the power transformer info as well as what I think the correct wiring is. Could someone please check my wiring plan? I'm not sure that my idea is correct.
    Thank you!
  2. robrob
    United States
    Is the amp currently using the PT's black & white wires for 120V? If yes, then the black and black/yellow wires should work for 220V.
  3. flyinjack
    That was a super fast response. Thanks!
    Yes, it's currently wired with the white/120v and black.
  4. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    may I ask why you want to convert it to 220?
  5. flyinjack
    I am taking the amp overseas and need to modify it to work easily there. It’s a clone build so I figure no harm done, and it would make for a fun project.
  6. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    Just wonder, is the filaments' secondary really 3.15V?
  7. robrob
    United States
    How are your amp voltages with the 120v hookup? If they run high like many modern amps you may want to use the 230v wires to bring down the voltage a little. And are you sure the voltage over there is really 220? Many countries are running 240 and above. If you use the 220v wires and you actually get 230+ voltage you'll get an extra 20 or 30 volts of B+.
    Wallace Snr likes this.
  8. Dacious
    Dacious Poster Extraordinaire
    Godzone
    If it's only temporary get a 115 volt stepdown.
    Teleterr likes this.
  9. Dacious
    Godzone
    Each leg to ground is. AC it's 6.3
    Finck likes this.
  10. flyinjack
    I work out of Dubai, UAE and have a home setup over there with quite a few of my toys. I have this mojotone 5w tweed champ and it would be a perfect amp to have there.
    The amp has the multi tap power transformer that I listed above, so I'm thinking it should be a very simple process. I'll give it a try when I get back in a couple days.
    As far as power goes everything I read claims to be 220v and 50 Hz. I have gone the stepdown transformer route in the past, but this small amp is going to be a permanent fixture there so I might as well do it the right way.
    robrob likes this.
  11. Finck
    São Paulo - Brazil
  12. Dacious
    Godzone
    Just get a DMM and (carefully) check the wall voltage. As RobRob says often 110 volts turns out to be 115. Here 240 is 245-247.
    OTOH, I had two SF Champs - one I fitted a 240v transformer for Oz, the other ran through a 110v stepdown, both had exactly the same B+ which was 15 volts over the scheo but well within tolerance, I think through a tube recto the Champ P/t won't generate really high voltage regardless of wall voltage.
