10k Nocaster pickups
Discussion in 'Just Pickups' started by dogfootblues, Jul 18, 2013.
  1. dogfootblues
    dogfootblues Tele-Afflicted
    Nov 6, 2011
    New Jersey
    So I just recently found out that the previous sets of Fender Nocaster pickups were a lot hotter than the current versions. So where can I find a set of Nocaster pickups that are that hot?
    Sent from my iPod touch using TDPRI
  2. sjtalon
    sjtalon Poster Extraordinaire
    Get a Broadcaster bridge pup.
  3. Reeek
    Reeek Tele-Holic
    I have never used them but the Tone Rider Hot set uses a bridge wound at 9.1K with alnico 3 magnets which is a common magnet for "Nocaster billed" bridge pickups. They claim the neck is at 7.2
    I'm not sure what "level" of boutique-ness you are after either.
  4. thesjkexperienc
    thesjkexperienc Tele-Meister
    474
    Dec 19, 2008
    Gunbarrel, Colorado
    Rumpelstiltskin makes a 50's black rope that is around 10k. Aaron will wind it however you like. I also REALLY love Klein's Epic Nocaster pickups! They are only in the high 8k but are just the most beautiful sounding pickups I have ever heard. The other bonus is the neck pickup is very useable and the "in series" sound with a 4 way switch is super fat yet clear.
  5. Rob DiStefano
    Rob DiStefano Poster Extraordinaire Vendor Member
    Mar 3, 2003
    NJ via TX
    you can not compare tele bridge pups that use different gauge coil wire - that's like the classic apples to oranges comparison. i see this happening here all the time.
    a "nocaster" (OR "broadcaster" - these names are exchanged quite liberally) wound with 9700 turns of 43awg coil wire will have a higher dcr value (about 9.7k) than the same pup wound with 9700 turns of 42awg coil wire (about 7.7k dcr) and they will sound totally different.
    the moral of this is that you CAN'T use dcr to evaluate any two or more pickups, UNLESS all of the pickups in question have the exact SAME footprint and build. what that means is, if the bobbin and materials are essentially the same spex, then dcr will be a reflection of the bobbin's coil wire turn count.
    a tele bridge pup that meters 10k will almost always sport 43awg coil wire (about 10,000 turns). to get that same 10k dcr from that bobbin with 42awg coil wire, the bobbin must use very Very tall rod magnets and require well over 12,000 turns of 42awg coil wire. VASTLY different pickups!
  6. Rob DiStefano
    Mar 3, 2003
    NJ via TX
    "nocaster" and "broadcaster" are interchangeable pickup labels.
    klein's "nocaster" uses 42awg wire and well wound.
    rumpelstiltskin's "50's black rope" uses 43awg wire and is alluded as a "broadcaster".
    very different tele/esquire bridge pickups.
  7. gmann
    gmann Friend of Leo's
    May 7, 2008
    Okinawa, Japan
    I have a Rumpestiltskin in mine and it's the best Tele bridge pup I've heard. I know a little about the different magnet types and wire gauges etc...but what I really know is what I like.
  8. Rob DiStefano
    Mar 3, 2003
    NJ via TX
    exactly. the bottom line to any pickup is always what you hear. messing around with the technical info can cause issues, particularly when things are unintentionally mismatched. stick with trusting yer ears - don't pander to the hype and wannabe speak. :cool:
  9. Reeek
    Reeek Tele-Holic
    I have this set in one of my Teles. They are amazing!
  10. H. Mac
    H. Mac Friend of Leo's
    May 26, 2012
    Atlanta, Georgia
    The "old" reissue Nocaster pickups were hot - around 9k or 10k for the bridge, and then around 2000 or so, there was a change to about mid 7k +/-.
    I bought one from the Stratosphere a few years ago for about $50, although I didn't know it was an older ones until I measured the resistance, which was 10.25k.
  11. Rob DiStefano
    Mar 3, 2003
    NJ via TX
    a 9k-10k tele bridge pup wound with 43awg coil wire is not "hot". it actually has far Far FAR less coil wire turns than a 9.5k tele bridge pup wound with 42awg coil wire - we're talking thousands of turns less. it's unusual to find a tele bridge pup that measures 9k or above that's wound with 42awg unless the rod magnets are unusually tall. this kinda tele/esquire bridge pup build is NOT the norm.
    once again, this is where you need to know precisely what the build is on a pup in order to make correct comparisons of dcr, which is solely a reflection of the bobbin turn count of a specific gauge of coil wire.
    and also, again, the "nocaster" and "broadcaster" labels are interchangeable, as is the use of 43awg and 42awg coil wire for these early, vintage style fender pickups. spex on these pups were the results of materials on hand, for the most part. gotta love uncle leo ....
  12. Dr. Bill
    Dr. Bill Tele-Afflicted
    May 1, 2003
    Upstate, SC
    Rob is correct. The two Nocaster pickups referenced are comparable in output. 43awg wire has a significantly higher DC resistance than 42 because it is thinner, but it is the number of turns that determines the output (assuming the magnet strength is equivalent).
    Some pickup makers perpetuate the myth that DC resistance is a measure of "output," but that is nonsense without further information allowing one to compare apples to apples.
