‘65 Reverberocket 2 too much reverb!!
Discussion in 'Amp Tech Center' started by Tomm Williams, Mar 15, 2019 at 11:57 PM.
  1. Tomm Williams
    Tomm Williams Tele-Holic
    When turning the reverb knob on this amp, I get a LOT of reverb very quickly. The choice nearly seems to be no reverb or too much! I have not even tried seeing what it sounds like maxed out.
    Any easy fix here ?
  2. robrob
    United States
    If your Reverbrocket is like the RR II below then you can adjust the two 150k resistors in the reverb out path to decrease the reverb signal. They form a 50/50 voltage divider which sends 50% of the reverb signal to ground. You need to keep the total resistance close to 300k because the two resistors are the grid leaks for the gain stage after the 1.5m reverb mix resistor.
    A 100k bottom resistor and 220k top resistor would send about 69% of the reverb signal to ground. A 68k and 220k would send 76% to ground.
  3. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Could it be something wrong with the pot itself? Just thinking I've never noticed an old Ampeg to be that sensitive on the reverb, but I really like that old Ampeg reverb.
    If this was an old Fender I'd say try a 12au7 instead of the 12at7 for a reverb driver. Ampeg used some odd tubes so swapping in a lower gain one would take some research and might not even be possible.
  4. David Barnett
    Is the 500K reverb "Dimension" pot linear, or audio taper?
    slider313 likes this.
