| Worship Service Players Religious service players discussion forum. Open to all religions. [b]No religious theology discussion, just guitar & playing performance discussion.[/b] |
hillsong united delay
Okay so their guitarist's dotted eighth delay is perfect..anyone know how I can get that? I use a dd-20
If you have a tap tempo delay, even if it doesn't have a dotted eighth setting, you can tap it in, but you have to count the quarter notes in time while you are doing the song. There is no metronome on most delays. Count quarter notes, break into eighths, then into sixteenths. While counting the sixteenths start counting them in threes, tap on the ones.
Code:
Theory only seems like rocket science when you don't know it. Once you understand it, it's more like plumbing!~John McGann Never argue with a fool; onlookers may not be able to tell the difference.~Mark Twain The hole for a pickup is a rout. No E. |
Hold the DD20 right fs down for 2 secs it becomes a tap. You can even select hitting both fs simultaneously to change presets, so you get both of all worlds.
I generally leave mine on 1/4notes so I can tap quarters, dotted eighths or eighths as needed. |
#6 (permalink) | |
I guess maybe an older model didn't have the tap or I came to a wrong conclusion. I was looking at videos of the DD-20 and the guy had a separate tap tempo switch and the comments indicated that you needed one of those in order to tap the tempo. I stand corrected. I bought a Line 6 Echo Park to replace my Digitech DL-8 because I really need the dotted repeats.
Edit: Okay, I went back and watched it closer this time, and the guy has two delays, including a DD-20. The other delay requires the external tap switch! Never mind!
You may find that you have "re-tap" from time to time during the song, if the band's tempo drifts slightly.
Agile AL-2000 with added Graphtech Ghost system Peavey Generation EXP Custom ACM |
#9 (permalink) | |
Not to say Bucky's warning isn't worth noting... but just telling my thought process as I began to use delay a lot. Or maybe I'm the only one who would be so dumb as to think it would work that way. :-) |
What HU uses???? Last I heard was a TC Electronics Nova Delay.....
Practice make permanent!!!!....Perfect practice makes perfect!!! Chris B. www.neonjones.com |
#12 (permalink) | |
Pics of Nigel's boards, in chronological order: The last is his most recent, with the new Cusack and Strymon gear. These boards range from roughly May 2002 to February 2012. |
NOt sure whether I've got anything much to add except to agree and clarify! I play some HU stuff and use a DD20. As has been mentioned you can use the right-hand pedal for tap tempo by holding it down but you then can't switch easily between presets. I use the option of an external footswitch for tap. I do take the opportunity during 'downtime' in a song to occasionally retap as, unless you're playing to a click track, the tempo will change slightly - but it's never been a big problem.
I find the dotted 8th with one repeat only to be invaluable for something like 'The Time Has Come' - I can't play at that speed without assistance! |
#14 (permalink) | |
