| Worship Service Players Religious service players discussion forum. Open to all religions. [b]No religious theology discussion, just guitar & playing performance discussion.[/b] |
#21 (permalink) | |
Its the decline of music, man! :p the exception would be that as much as bass frequencies spread, they really should be DI'ed. No amount of musicality can change the physics of music. |
#22 (permalink) |
I used a Digitech RP50 once with good results. Described as a "cheap toy" even by the salesman who sold it to me, I had no complaints with it. Simple, quiet and small. I made 5 models and had a great time.
No Comment. |
#23 (permalink) |
I use a traditional pedalboard into and Egnater Rebel 30 combo with a direct out. All the Tubey goodness, zero stage volume. An H&K Redbox could be an excellent solution, too!
One thing to remember: as leaders (and musicians), we normally have authority issues. Learning to work with the parameters given us is part of what helps us continue to grow.
According to my wife, "the true beauty of free will is that you can continue to be stubborn" |
#24 (permalink) |
I would stick as close to your current rig as possible, so when you practice at home, jam with your buddies, or play at church, you're using pretty much the same gear. Too many variables otherwise.
Given that, if they are disallowing ISO boxes, then go with an attenuator that has both a "load" setting and a line out. Here is one. There is also one called "Alex". Seems boutique... lots of people like it, but there's a waiting list. Google around for these and check out the reviews/opinions. With this, you still use all of your existing rig except for your speakers/cab. That's my plan if I ever find myself with this restriction. Actually, you should really have a conversation about the ISO boxes. He's concerned about coloring tone, but expects you to use a modeler? hmmm, which option is going to change your tone more... switching from your amp with pedals over to a modeler, or putting your amp in an ISO box? Is his real motive to get zero backstage volume? Maybe that's it? |
#25 (permalink) | |
The church that I play in is headed in that direction too (mandatory DI, in-ear monitors, etc).. I'm still not sure of what I will use. So far, when I've had to run direct for gigs, I've used: 1. the Pod set to a clean Fender type sound, and used my pedals 2. Roland Cube with pedals. same approach as above 3. I have a Pod XT live but haven't really bonded with it... BTW- does the church pay for your in-ear monitors? |
#26 (permalink) | |
#27 (permalink) | |
For me personally...and please, I am in no way suggesting that my preference is universally best for anyone...I found that I get a significantly better tone and feel out of a POD HD than my amp running into an iso cab. My amp miced up through an open cab and it's no contest from a player's standpoint. I'll take the amp, please! From an audience member's standpoint I don't think they care either way. From a church congregation member's standpoint...they probably would prefer the POD as the way I like to run my amp would be a little loud for the first few rows My experience, though, is that really no matter which solution I end up going with, I always end up sounding like me - for better or worse. Go figure. |
#28 (permalink) | |
This video compares two. The Demeter sounds like every other boxy, stifled iso cab I ever heard. The Rivera sounds pretty good to me. |
#29 (permalink) |
I started using a fractal axe fx ultra, which I bought from a worship leader who bought a new axe fx 2, hands down the best tone and feel I have ever had in 30 years of playing, I am in the process of selling all my amps (except my Matchless for backup) and all my pedals this thing is the be all end all for me its just incredible, its pricey I paid 1700.00 used for mine but to have all the amps and high end effects that it has you would have to spend at least 50k, its hans down the best piece of equipment I have ever bought in my life. I also play in some clubs in another band and the 4 times I used it live I had the other band memebers, and people in the audience telling me how good my tone was and basically I just plug into the PA and have two powered speakers behind me, my biggest compliment came from Michael Shenker who we opened up for and he told me he liked my sound..........that says a lot. I have tried just about every modeler except for the kemper and the Fractal Axe Fx makes them all seem like toys, it feels and reacts and sounds just like a tube amp and you can tweak things that you could never tweak on a real amp, the effects are on par with eventide and tc electronics.
#30 (permalink) |
I would think that using IEM's would be to clean up the stage monitor sound/volume and also allow you to here the mix you want in your ear. I would still want some kind of reference from the other instruments, I wouldn't blast the volume to where all I hear is the IEM.
I wonder what it would be like if the main mix dies in the service but the IEM is still working. Now THATS air guitar baby! |
#31 (permalink) |
good luck. not to be a baby but i couldn't play in that situation. not that i wouldn't, but i couldn't. i mainly play bass and they tried to do that to me maybe a year or so ago. i couldn't play without an amp. it felt so "fake" that i kept getting off. eventually they let me play though the amp again and haven't tried to take it away from me.
we also have a horn section so we'll never have zero volume either. again, good luck. sorry i can't offer any help.
clean as a whistle |
#32 (permalink) |
I put my pedals into a DI box straight to the board. Sounds pretty good IMO. But I'm only using my tele, an OD (when it's working) and a Muff.
Gotta have a competent sound guy though, because he is in total control of your EQ unless you have an EQ pedal. |
#33 (permalink) |
We don't have a "Stage". We're set up off to the side, took out about six of those half pews, right in front of the pulpit. We use my old school PA, huge Peavey speakers with horns on furniture dollies... we roll em' out before second service. Everything but the Bass player runs thru the board which sets next to me. So I'm singer, guitarist, and FOH... we still use monitors and our amps, but I'm running a splitter to my little Bugera and DI to the board, while the other Guitarist is mic'ed. I WISH we had a budget to allow a more modern set up but this old rig worked many a High School gym in the past, and since we use all our own equipment with a budget of ZERO, I'm grateful I get to play. Some of you BIG BOX churches spend thousands on equipment and all I read are complaints.... "If I can't crank it, I'll quit." "No rock anymore." Sure those IEM's aren't being used by 99% of the touring bands out there because there's no rock, its because they eliminate feedback and allow freedom of movement, and Direct boxes been around longer than alot of us. Think about it. How many knobs to adjust your sound are between you and the speaker it comes out of? A modest pedal board and a direct box or a modeler, and you'll have plenty of tweekage to tailor your sound. We can't all sound like Skillet. But we can play for the Glory of God with what ever we have.
Peace. Back by popular demand... |
#34 (permalink) | |
"Tech Pastor" . . ??? Is he a musician? Tell him that he should care about the service and you take care about the music! :-)
Romani ite domum! |
#35 (permalink) |
Big Muff into a PA? This stuff can be really frustrating. Amp tone is everything. I just want to sound like me. IMO solid body electrics should NOT be plugged directly into a system. A lot of sound people/people not in the know really don't understand this. The amp is like 50% of the instrument. Even if it is just a Champ 600 MIC'D. The music director at my church recommended that I plug directly into the system so everything can be modulated from the booth. I said I understood his thinking, but, no way-- the amp is like the bell on a trombone or the horse hair on a violin bow. I said I would use a SF champ and aim it directly at my head and they can just mic it. guitar tone needs to compliment and be distinctive at the same time-- mixing with the other instruments tones in their own right. I really don't like using pa system monitors-- everyone in the band depends on them so much, I prefer to stretch my ears a little.
#36 (permalink) | |
![]() oh yeah, VDrums are cheesy and don't effectively portray human expression. just from experience and MHO |
#37 (permalink) |
our regular guitarist built a sound damping board that we put in front of the amp for the electric and that takes the projected stage volume down a lot to a manageable level for the sound techs, i have found that when playing bass i need the in ear monitors, the stage monitor for bass is loud, except right in front of the speaker where i am, so i cant hear me but everyone else can, funny how that works so using IEMs for bass has been a blessing for me.
I haven't tried it for electric yet, i doubt i will since i will probably try to use my amp for a little bit of a monitor.
-Brandon |
#38 (permalink) |
While we don't have amps on stage, I totally agree that the amp is a vital part of the sound, possibly even more so than the guitar. I've yet to find a guitar that sounds bad through the Hot Rod Deluxe I'm using. I would never plug direct into the system without an amp modeller at the very least, but I'm not personally into them compared to a nice tube amp. As I mentioned above, our solution is to keep the amps off stage and mic them up - all the ampy goodness, none of the annoy-thy-neighbour sound on stage.
With bass I don't have an issue going to the system via DI - bass doesn't seem to lose its sound or character in the same way that guitar does. |
#39 (permalink) |
I think if I had to resort to modeling again I'd just put a Tech 21 Liverpool or Leeds at the end of my pedalboard. That way all of my pedals remain there and tweakable and I have a pretty good facsimile of Brit amp tone and color to the board.
#40 (permalink) |
I use my zoom 505 II for my bass so I can have a little bit of an eq and I use the crude amp simulator, it works for bass but its nothing compared to the real deal for a guitar.
-Brandon |
