| Worship Service Players Religious service players discussion forum. Open to all religions. No religious theology discussion, just guitar & playing performance discussion. |
You can plug your electric guitar straight into a PA that has 1/4" inputs, or through a Direct Box if it doesn't, but it won't sound good. It'd be very dull and lifeless, even if you adjust the PA channel's tone controls. You won't like it. The best way is with an amp modeler, such as a Line6 POD, Behringer V-amp, Digitech RP-series pedal, etc. I'm using the RP-200.
Peavey Generation EXP Custom ACM |
Yep. You need an amp modeler or at least some decent effects. In my experience if you need to go direct then the hotter the pickups the better. A straight Tele will sound a bit lifeless, while I've found G&L's with the MFD pickups actually sound half decent. I've run a Tele with just a pedalboard using a compressor with minimal squish just to boost things a bit and then OD and distortion pedals to approximate amp OD (it's funny, but I've found that the cheaper the better with the OD pedals in this situation - the low-end Boss pedals work well). But it sounds a lot better with some type of amp modeler. I'm using a Pod XT Live right now and while you'll never get the feel of having an amp there you'll at least get decent tones. If you can imagine playing with your amp isolated in a room far away and the tone being pumped through the monitor then you're 1/2 way there. You won't move air but you'll get tone that everyone but you will be fooled by.
Get a Shure sm57 or Audix i5 or some other instrument mic and stick it right up against the grill cloth of your amp. Sure the sound guy will yell at you all through rehearsal to turn down so go ahead and listen then turn back up once the service starts :)
But seriously, If you can mic the amp then do it and forget about modelers. You will be much happier with your tone. |
#7 (permalink) | |
I happen to be both a sound dude and a guitarist. Don't turn your amp up after practice. It really sucks when I've got a good mix going during practice, and then, all of a sudden, the guitar or bass player's amp is too loud for the room, even taken all the way out of the house speakers. |
#8 (permalink) | |
I was partially kidding. The problem is that most church sound guys don't know what a good mix is. I played at the same church for about 7 years and we had a dozen different sound guys none of which had any experience with running sound or playing in a band or music whatsoever. The mix was horrible, the eq was horrible, the stage sound was horrible. Church sound guys are somewhat notorious for telling the guitarist to turn down but I am not trying to equate low volume to a bad mix (sometimes the guitar IS too loud). I have since moved on to a place where we (the band) basically set up the mix ourselves and have someone sitting behind the board during the service to mute the mains when we aren't playing. The sound is a lot better this way because opposed to a volunteer running sound who didn't write the music and doesn't play an instrument; we (the musicians) are able to have the room sound the way we actually want it. |
Yeah. Good sound guys are somewhat rare. I suppose you'll usually see 'em in big churches. Maybe they get paid. Most sound guys you see in churches either A) Don't really know what they're doing, or don't know anything beyond the basics, or B) Don't care or can't tell that it sounds bad.
I go direct to my pedal board, that goes direct to my amp, then a microphone placed in front of it, goes direct into the PA.
OK, seriously. I have heard from a lot of folks that use em, they are happy with the new PODX3 Live rig. Guitar into it, it into the PA. Thats what Lincoln Brewster uses, and his tone aint shabby at all!
Later! PraiseCaster Visit Guitarists Praise and Worship Forum!! ![]() Dance Like David, MySpace |
I use a POD XTL. It works fine. The other guitar players (we have 3 teams) use amps. Lincoln Brewster played at our church a while back. I got a chance to talk with him a bit during setup. He likes thing simple. He had a POD XTL, Boss Blues Driver and a yellow Boss OD. Even the amp guys agreed his tone was quite good.
I personally use a Vox Tonelab LE. It delivers some very nice, organic tones. The one downside is that the cab sim is mic'd on-axis and that's not adjustable. So, if you put that signal straight into a device like a Tech 21 Power Engine or Atomic amp and treat it like a regular guitar amp, it'll work great. But when you put it straight to headphones or live, it's really harsh. Point your ear directly at your guitar speaker and you get an idea of what I'm talking about.
The fortunate thing is this can be easiliy fixed with further EQ'ing. As you get a little off axis from a 12" speaker, you mainly lose the highs above 2-3k. So I got a Boss GE-7 EQ pedal and I cut the top two bands by several dB's. If you had it wired up to a mixer, you could center the mids at 5K and cut 3-6dB's. That would also fix it. You might ask why I don't just use a modeler that has a selectable mic position? Because the Tonelab has an organic tube-like tone and feel to it that can't be added in to another modeler with EQ's. And one more thing: Lincoln Brewster's tone is really good, especially on his live album. Last edited by giantslayer : March 16th, 2008 at 10:06 PM. |
Been using a POD (either a POD 2 or a Floor XL) for a long time. Don't really like it so much, but....sound guys really like it. Have miked amps, but most amps are too loud for our stage situation. I am going to try a Princeton Recording amp over Easter. Use the DI out and the built in attenuator.
For Acoustic, I have used the LR Baggs DI box and a Fishman Aura. both worked fine, but the Aura sounds a bit better over the PA. For mandolin, only microphones so far. |
#14 (permalink) |
I'm really trying hard to mic the amp but the sound guy says its too complicated and I don't understand why.
2000 MIM tele std. Vox AC15CC USA Ovation Big Baby Taylor - Takamine Classical Some people sing in the shower, I play guitar... |
I play my '85 MIJ Tele through an RP200, and we are fortunate enough to have POD XT Live pedalboards and an Aviom headset monitor system for our band/rhythm section and orchestra. This keeps our sound guys from pulling out their hair, and our pastor from getting nervous! We can adjust the level of everyone on the 16 channel headset mixer, which is really handy.
Brace for worship!
Sure, I work on electronics...It doesn't bother me... bother me... bother me... "We've got a blind date with Destiny... and it looks like she's ordered the lobster!" - The Shoveler Mystery Men Movie |
#16 (permalink) |
Jenix, I use a Palmer PDI-09 with my DRRI. Guitar, pedal board to amp. Amp speaker is my monitor and from the PDI-09 to the PA. It works very well.
Checked this demo video. http://www.youtube.com/watch?v=GTKkY-GmxLQ I have two of these and love them, they record very well also. |
#17 (permalink) |
For me, the Line 6 XTLive is the only way to go. Into the XTL, then out to the P.A. We use the Aviom system so I always have the mix that I want.
This is the best rig for me sound wise, but also because I can recreate a majority of the sounds that I hear on the recordings.....we do a lot of Desperation Band, Paul Baloche, Brian Doerksen, etc. I can come up with a preset that I like and name it for the song and I can punch effects in and out like distortion or delay. I's funny because I bought this pedal to use live, but church is about the only place it works for me. When I play out I go back to an amp. I recently obtained a Vox AC15CC to recreate the Vox model in the pedal. Life imitating art, or the other way around?
"Each guitar has its own character and personality, which can be magnified once the player engages in beatin' it up"- Billy F. Gibbons -ZZ-Top |
#19 (permalink) | |
Just put a mike up to the grill and have him pretend its a singer. You know, turn the little knobby things on the big board thing. He might get it. |
#20 (permalink) |
Mic the amp
I have a Line6 Flextone II that I have used in church since 2000. At my previous church, I just plugged into the XLR output and it sounded great, since it has the POD innards. However at my new church, there is a ton of can lights on the stage, and I can't find clean power causing the amp to pick up signal noise when I use the XLR out. I have started mic'ng with a SM57 at monitor level, mixing with normal stage volume (drummer is in a cage, where they need to be
#21 (permalink) | |
At my church, we go a long way to minimize the volume on stage. Drummer in a cage. Used to be, synth drums. Every stringed instrument get D/I boxes. In-ear monitors for all the musicians and the worship leader. Axioms, as mentioned. The other other guy uses a Boss GT-7 among lots of other multieffect choices. I uses a ToneWorks AX1500G, which is a bit of a toy compared to the Boss, but I can make it work. I have a bank of tones for my acoustic/electric and the rest set up for the Tele. Does your amp have a headphone out? I used to do that, before I got the good rig. |
#23 (permalink) |
I've used my POD XT Live hooked up to a Tech 21 Power Engine 60 for several years. It works great, as I can set the volume of the amp independent of the signal going to the board. This lets me turn up a little if I can't hear myself as well as I need to, but not loud enough to anger the sound guy or affect overall stage volume too much. I turn it facing me and tilt it back a bit. The open back of the cab faces the congregation. There's usually a small riser behind it so that helps since it's an open back cab.
Another option is one I used before I got my PODXTL. I have a small Marshall Lead 12, which is the older version of the Micro Stack they have now. It's a 12 watt solid state head with 2 separate 10" speaker cabs. I used the slanted cab with the head onstage and ran a long speaker cord to the other cab miked up with an SM57 under the stage. This worked really well also. Not as versatile as the PODXTL option, but, not much is when compared to all the stuff packed in there. |
#24 (permalink) |
LINE 6 POD... the Wonder Box!
I have been using a LINE 6 POD for about 6 years. I have it tweaked for all of my guitars with each guitar set up on it's own bank. My sound guys love it! Mine is dialed in and sounds amazing! I can go direct into my Marshall 8200 or direct into the board... sweet as honey.
Good luck and God Bless! PJ
http://www.soundclick.com/bands/defa...&content=music Schecter Stargazer, 1981 Ibanez Artist AR50, Tele Standard, Ibanez SZ520QM, Line 6 POD, Fender Princeton Stereo, Marshall 8200 |
#25 (permalink) |
Currently I am using a Princeton Recording Amp. It has a DI out with independent volume. It also has the built in anttenuator. I currently love this solution.
This has been a superior solution to other low power amps or the POD (have two, ad POD II and a XT Live; the XT Live is better but still not a real amp). With low power amps, if you turn up to the point where you can get some good dirt during practice, the singers get it in their head that you are too loud and need to turn down. However, at the same volume during actual performances/worship, the overall level is so high that they cannot tell how loud you are if that is the only time you are at a specific level. So...you are left with practicing at a lower volume and only turn up during the service or antenuating somehow. You could use your regular amp and a THD Hotplate. Those actually work pretty nicely, but I was only able to borrow one for a while, never bought one. A bit spendy at ~$350 delivered to your door, but not as bad as buying the Princeton (go figure on my priorities). There are other attenuators out there that have good reviews, maybe some are better than the Hotplate, but the hotplate has a PA out as well as the anttenuated signal to the speakers. POD works OK. Most of the folks in the pews cannot really tell when everything goes through the POD. However, one thing is you ability to monitor your own playing is either you need a guitar only chanel (or an instruments channel) from the sound board, or you will only hear the final mix. We have been having problems with our guitar only monitor at our church, so...the guitars have a hard time hearing what they are doing. You can play the POD locally through an acoustic amp (I have used my AER) but...then there is yet another item in the link. POD, et. al. have the great advantage of being designed to provide output to a PA (although niether of mine have XLR outputs, need a matching transformer). With the Princeton Recording, I leave the anttenuator volume down for practice, and turn it up for the worship, but the tones are pretty much the same. Use the DI out for the board. The built in effects are pretty good too. Not as cool as some of my better pedals, but if I want those instead, I can put my pedalboard in front of the Princeton. Best solution so far (short of a bigger building!) |
