Go Back   Telecaster Guitar Forum > Vendor Forums > Vendor Forum
Vendor Forum Special Forum for Vendors to discuss and post about their products and services. Only registered Vendors can start threads here, but everyone can post in these threads.
Old June 24th, 2009, 04:04 PM   #1 (permalink)
VENDOR
Don Mare's Avatar
Hello, TDPRI Vendor Forum -
Well _ I really _I wanted to thank Paul, the TDPRI customers - you all have been very good to me, and I hope It was good for you guys too....
OK, now heres some Don Mare Pickup news -
busy as a bee - and I really have to go to work now - I do apologize ( hows that for news?) LOL
Well.. maybe I'll think of some news stuff soon - but I just wanted to post was all.
Cheers
Don
Don Mare is offline   Reply With Quote
Old June 25th, 2009, 10:53 AM   #2 (permalink)
jaydawg's Avatar
Hey Don!
You should let the guys know about your new "Big Box" neck pup. It's bound to be a favorite.
WWLD
(What would Leo Do?)
jaydawg is offline   Reply With Quote
Old June 25th, 2009, 12:04 PM   #3 (permalink)
VENDOR
Southern Ill Electrics's Avatar
Big Box ?
I better get over there and see if I can find it.
Jeffro' at Southern Ill Electrics
618-643-2406/618-308-0223
God Bless Les and Leo.
Southern Ill Electrics is offline   Reply With Quote
Old June 25th, 2009, 02:42 PM   #4 (permalink)
Rich Rice's Avatar
Big Box...sounds dirty?
In case you haven't heard, Don's pickups are great. Keep it up!
This guitar's gone through a few sets, currently sporting 0038s.
Please visit my website!
If you are driven to play, you will find a way.
Old June 25th, 2009, 02:45 PM   #5 (permalink)
stevieboy's Avatar
Originally Posted by jaydawg View Post
Hey Don!
Hey, leave him alone--so he can wind my Big Box. Shouldn't be long now!
stevieboy is offline   Reply With Quote
Old June 25th, 2009, 04:33 PM   #6 (permalink)
Groovey Records's Avatar
Don this 3 tap Stingray sounds mHIGHty fine DON on my LesQuire Jr.
eSpecially in combo with The Charlie Christian from Jason
The Combo works better then I could of imagined and I can Imagine a lot
Yeah but you should of heard what I was trying to play-Thelonius Monk
EnJoY ThE MuSiC
GrooVey RecOrds
Groovey Records is offline   Reply With Quote
Old June 29th, 2009, 07:57 PM   #7 (permalink)
VENDOR
Don Mare's Avatar
Big Box - was a mistake that turned out very cool - funny how that happens
it was Rick Holmstrom who coined " Big Box~Arch Top" to that pup -
its also tap-able. about 6.5 then 7.5 -- but most guys run them all the way up 7.5k
Rick says the tone is much like a Arch Top Humbucker guitar - but on a Tele - the tap can get you back to normal Tele tone when needed..
the main tricks is wire gauges are switched . and the magnets are "Taller" much like the Twisted Teles* (* Fenders )
PS.. thanks for all the "pipe -ins"
oh - yea.. Stevie-B yours is a 2-weeks away now
Don
Old July 6th, 2009, 06:01 PM   #8 (permalink)
strat-o-teleman's Avatar
Can't wait to get mine!!! A 3-Speed StingRay coupled with the tapped Big Box/Archtop. Should be a really cool and versatile combo. Should've ordered them sooner--my build is nearly done.
I Know...Patience!!
Joel
aka. strat-o-teleman
strat-o-teleman is online now   Reply With Quote
Old July 6th, 2009, 08:56 PM   #9 (permalink)
jaydawg's Avatar
I Know...Patience!!
Joel
How do you plan on wiring the two?
WWLD
Old July 6th, 2009, 10:16 PM   #10 (permalink)
stevieboy's Avatar
I Know...Patience!!
Joel
Mine's coming with a two tap Sting Ray. I actually didn't realize when I ordered the Big Box that it was tapped as well, so I didn't think to ask about how I would have to wire it. I assume I could use a push-pull pot in both the volume and tone positions, one for each pickup?
Old July 7th, 2009, 01:24 AM   #11 (permalink)
I'm putting in a 4-way tele switch for the 3 bridge taps and the hotter neck tap by itself. The Neck pickup will also be on a mini toggle switch to switch between the "hot" neck and "regular" neck and to add either one to any of the bridge taps.
Essentially, it'll be a 5 pickup tele with 11 different combinations(if my math is correct).
Should be a cool setup. Of course, there'll be a bit of a learning curve to get all the different combos down. I'm sure I'll end up using only a couple of different settings...but it'll be cool to have the other ones there...ya know, when you just need that little extra something!?
Old July 7th, 2009, 10:32 AM   #12 (permalink)
jaydawg's Avatar
You might think about using two push/poll pots. One to select between the two taps from the neck pup and the other to direct which ever neck tap is selected to either the neck position of the switch or the outside lug of the volume pot. By routing the neck pup to the volume pot you be able to have all the taps by themselves on the switch then all the taps in combination with either tap of the neck pup. And the control plate will still looks stock.
WWLD
Old July 8th, 2009, 03:47 PM   #13 (permalink)
VENDOR
Don Mare's Avatar
Hello,
The Push Pull Pot has _two "banks"_ with 3 solder lugs each - so you could run both on just one P/P switch pot -(the neck on the left bank and the bridge on the right bank)-
but they are "both" going to be dedicated that a way -
You'll get both on _or_ both off is all you get. for some thats fine -
Old July 8th, 2009, 03:55 PM   #14 (permalink)
VENDOR
Don Mare's Avatar
testing signature logo picture ( test)
Old July 8th, 2009, 04:24 PM   #15 (permalink)
stevieboy's Avatar
In my case I don't mind having two push pull pots, and I'd prefer to have them work independantly. I'm able to follow schematics and install a control plate and pickups from scratch, but I don't understand it, I just can do the grunt work. My question about it is, it seems to me that the tone pot is always the one that is used for a push pull coil tap. Is there any reason why a volume pot in a circuit wouldn't work the same as far as coil tapping with a push pull pot? Seems like it should, but for all I know there's some reason it won't.
Old July 8th, 2009, 04:41 PM   #16 (permalink)
VENDOR
Don Mare's Avatar
Folks find it too easy to accidentally knock the P/P Volume pot down while picking / strumming is all - so they put it on the tone - out of harms way - hehe!
Old July 8th, 2009, 05:27 PM   #17 (permalink)
stevieboy's Avatar
So I'll be needing a pair of them!
Old July 8th, 2009, 05:32 PM   #18 (permalink)
Good to see you're busy Don, and I hope you're keeping well!
Ron Garson is offline   Reply With Quote
Old July 8th, 2009, 06:54 PM   #19 (permalink)
VENDOR
Don Mare's Avatar
I'll have 2 here for you then, ok
Health is stable now - and I cut down to 30 pickups per week max., production
and I take weekends off - & far away from Electric guitars - hehe!
Old July 9th, 2009, 02:07 PM   #20 (permalink)
Glad to hear your doing well.
I'm not sure if it's "kosher" to ask, so thought I'd just post here and see. I was just wondering how far out my pickups might be? It looks like the "Freida" the Sparklecaster is just about finished(thanks to Uncle Buckocaster). It just needs pickups to bring it to life.
I'm really looking forward to getting them...I've yet to read anything less that a great review of any of your pickups. It seems everybody who has them... loves them.
Hope I'm not out of line asking...just anxious, I guess.
Thanks,
Joel Ulmer
Old July 9th, 2009, 07:08 PM   #21 (permalink)
VENDOR
Don Mare's Avatar
Hi, Joel - hope your doing good too..
ok, your pickups are due to ship Friday the 24th
thanks for the kind words
Don
Old July 9th, 2009, 11:11 PM   #22 (permalink)
Don
WOW!! Now that's service!! This internet/Forum thingy is pretty slick!!
Thanks for the quick reply. I'll be waiting patiently. OK, Well I'll be waiting, anyway.
Joel Ulmer
Old July 28th, 2009, 09:26 PM   #23 (permalink)
VENDOR
Don Mare's Avatar
photo by our own TDPRI member Steve D., taken while on his visit here to "pickup-pickups"
just wanted to post it here in my vendor page for all to see,
- I really do use these mariachi instruments to escape the electric world daily - Story goes, that they were all designed way back in the 1800's, to be light-weight so the mariachi could wander the streets or town to town - also they were designed to be loud enough to play small venues without amplifiers... ( No Pickups )
Old July 28th, 2009, 10:45 PM   #24 (permalink)
Ese' Hombre El Mariachi
Mucho Macho
BTW
KABONG!
EnJoY ThE MuSiC
GrooVey RecOrds
Old October 30th, 2009, 03:05 PM   #25 (permalink)
P Thought's Avatar
Fire in the hole! Order's in for my "Green Onions" set. My first tele is just about to go together. I'll play it with some $20 Chinese pickups until my new ones come. This is very exciting for me.
quidquid latine dictum sit altum viditur
P Thought is offline   Reply With Quote
Welcome to the Vendor Forum TDPRI Vendor Forum 17 August 30th, 2009 03:44 AM
TDPRI Forum History 101? KYTele Telecaster Discussion Forum 32 March 9th, 2007 02:51 PM
Add New Forum to TDPRI?? bender72 Telecaster Discussion Forum 31 April 20th, 2004 06:05 AM
