| Twanger Central THIS FORUM IS FOR POSTING LINKS TO MUSIC YOU HAVE PERFORMED AND RECORDED. No other posting please! No posting other people's music, PERIOD. Please be mindful of any copyright issues. |
Fred Stuart Bakersfield set for tele + Glendale & RedPlate
I finally got my Stuarts custom '60 pups installed in my Tele, and replaced my Callaham bridge for a Glendale Blackguard bridge with the screamin' '59 saddles. Here is a small review, and a video of me noodling in my PJ's early in the morning.
Fred Stuart '60 Bakersfield pickups. I been dying to get these puppies installed in my Tele, and it was no disappointment. I wanted a Tele that was versatile. One I could do Country, Blues and Rock with, without any real compromise. All there really is to say here is that the dynamics, harmonics and touch sensitivity of these pickups are simply incredible. I like to always have the clean & natural tone of my guitar shine through no matter what pedal or how much drive I use. I always use the guitars volume and tone to shape my sound and I use a pick and finger picking combined. To me it is a must to have a guitar where I can shape my sound as I need to with the way that I attack & pick the notes. These pickups allowed me to do all that. The tone is simply gorgeous. It can be sparkling clean, with piano like bass notes and crisp highs. If I hit it with a little drive and boosts the mids a little on my amp, it transforms into the lowdown and nasty blues. For an alder Tele with a rosewood board maple neck, I believe that it could not be any better. Thanks again to Fred for winding me this Bakersfield Tele set. It's everything I need out of my '60 Telecaster. I ordered the bakersfield set, cause I wanted to be sure it was not wound to hot for my taste. I really wanted that low-wound tone. It has the perfect blend of wood & steel, and I think you can hear it in every note. The Glendale Bridge; I did like the callaham, but found it to be borderline brittle in the highs, with my setup and how I like to run my amps. It was also hard for me to get the in-between position to sound right. It was to bassy. I wanted a more '60 sounding Tele, with a useful in-between and neck position. The Glendale hit the spot. I did loose a little bit of bass, but gained a lot more of my guitars natural tone and character. To me, this was a no-brainer. With the Stuarts & this bridge, my Tele sounds just like I hear it in my head. As soon as I hit a simple G chord on my Tele, I felt my guitar vibrate in a way it had not done before. I literately felt every note I played sustaining through the guitar into the side of my body. It really surprised me, cause I did not think I could get anything more out of my Tele acoustically. The tone was more musical & nuanced. It pretty much opened up my guitar and the in-between position finally sounded right. Now, my pickups make a 100% sense. They are perfectly balanced, and I could NOT have achieved that with good pickups alone. It took the right bridge to balance it all out. Thanks to Dale for such a killer product. I should have bought this bridge long ago. It was a really important missing piece in the puzzle. I could easily have missed it, cause I already had a great quality bridge to begin with. I got this bridge cause I knew something was not quite right, and I had to be sure. That's why I gambled and ordered the Glendale. Thank again Dale, you have that S*** down!!! The video takes of clean, going to more gritty and then with some drive. It's recorded with my IMac, so sorry for the not so Hi-Fi sound quality. I really wish the audio quality would be better, there's so much lost!!! kinda frustrating. I figured that some might still prefer a decent clip versus no clip at all. Here's the video link: http://vids.myspace.com/index.cfm?fu...deoid=59457709 Thanks for reading guys. Again, I appreciate it very much. __________________ Last edited by the-tone; June 23rd, 2009 at 06:02 PM. |
I just took the neck pup out of my pickguard and mounted it to the body, and there is a noticeable audio difference. My tone got a little less jangly, which is okay cause it's not a strat. I gained a tighter bass and the mids got a little more present. It also made the pup cut a little more.
I could also just say that the pup became overall stronger sounding. The tone of the two slot also improved. It's tighter and cuts more. I was looking for a true vintage tone and now when I got the right bridge and saddles, and mounted the neck pup to the body, it is prefect. which is what I was looking for to begin with. For me, this is it. Last edited by the-tone; July 2nd, 2009 at 01:34 PM. Reason: Tone Update... |
this is a great video! you don't even need Hi-Fi sound quality to be able to tell that that tone is killer!
great playing and great licks BTW. I love that sound! i've got Glendale saddles, and i'm toying with the notion of getting a Glendale bridge, cuz the saddles don't quite fit perfectly. The E/B saddle is slightly angled and the side isn't flush with the D/G saddle. It hasn't caused me any intonation problems (that i know of) yet. even so, the bridge plate i've got is just a stock Fender, nothing special about it. I'm curious to see exactly how it might influence my tone. Cheers, Joel |
Thanks so much Joel!
The way Dale does his saddles can be confusing. There is an explanation on his website. The saddles did not fit right for me either when I first put them on, then I realized when I checked the manual that they're suppose to fit so when the saddle is turned upside down, the lettering on the back of the saddle match up with the strings. then you flip it around and it will match up prefect. i.e. upside down, the D will face the D string and the E will face the E string. Then flip it. Now the E lettering will be under the D string and the D lettering will be under the E string. Also, the sides are only suppose to touch at the top of each saddle. that's the design for ultimate tone. You gotta get the bridge!!! it'll sound way better that the stock Fender IMHO. I hope this made sense. |
Strat '60 Pickups video update!
http://www.youtube.com/watch?v=wvNcJNHTm4I USACG, with Fred Stuart '60 pups, Raw-Vintage Saddles and springs. After I switched to the raw-vintage combination, I now use vintage correct tubing for pickup mounting instead of springs. __________________ Tele UPDATE! I have changed my bridge to a Glendale Vintage cold-rolled steel with the Bakersfield saddles. I also ordered a 4lb and 14oz ash body from Tommy at USACG. I need the ultimate twang and old-school vintage tone and I just wasn't quite satisfied with the Callaham bridge and my alder body. Awesome quality for Callaham as always, really no complaints. I just found the Glendale to be more musical and have none of the problems Callaham describes on his site regarding the vintage style bridge. I think my alder tele as it is in the video is more of a rocker and I'm looking for more bite, bigger lows and more twang! The Stuart Bakersfield set measures: 6.13K bridge and 6.8K neck. very balanced and plenty bright in the neck for me. It's a '60 style stagger with alnico 5. I will have a new video demo ready sometime in mid August. |
haha, so get this. i went back and checked the saddles on my tele - turns out i had the D/G saddle on the E/B strings and the E/B saddle on the D/G strings.
NO WONDER IT DIDN'T FIT! well we're golden now, they fit just fine and the tele is perfectly intonated now. |
Good to hear ...LOL! you gotta get that Glendale bridge. It really takes the whole guitar to another level. You'll love it, trust me. I have the double cut, but I'm thinking of getting the traditional bridge with the sides untouched just because I like to rest my had there and don't have a problem when picking. If you want my bridge, I'll sell it to you cheap. PM me, if you're interested.
Most excellent.
http://www.myspace.com/otiskeithwatkins |
#14 (permalink) |
My email address is hgruple@gmail.com by the way.
#17 (permalink) |
Ash Tele Stuart video update!
http://www.youtube.com/watch?v=sb6riyTdDYw Glendale vintage bridge, Screamin' 59 saddles, Aluminum for the low e & A. |
| Fred Stuart Bakersfield set for tele + Glendale & RedPlate | the-tone | Just Pickups | 15 | October 9th, 2009 03:40 AM |
| Fred Stuart strat and tele pup review! | the-tone | Just Pickups | 31 | July 15th, 2009 09:28 PM |
| Fred Stuart Tele Neck Pickup - WOW! | petebradt | Just Pickups | 18 | September 17th, 2008 10:47 AM |
| Value of a Fred Stuart Tele?? | endzone | Telecaster Discussion Forum | 1 | March 9th, 2007 08:14 PM |
| Fred Stuart refin Tele? | Masterbuilt | Telecaster Discussion Forum | 0 | May 10th, 2005 08:22 AM |
