Old February 16th, 2008, 10:54 AM   #1 (permalink)
ole6string's Avatar
Wiring Diagram for 2 hum, 1 vol, 1 tone & 3way lever
Does anyone know where I can get a wiring diagram for 2 humbuckers, 1 volume, 1 tone, and a standard 3 way Tele type lever switch? All the ones I find online show the toggle switch type from a Les Paul and I am not that good at this stuff to figure it out on my own.
Any help would be greatly appreciated.
ole6string is offline   Reply With Quote
Old February 16th, 2008, 11:04 AM   #2 (permalink)
octatonic's Avatar
This should do it.
I'd suggest putting push pulls on the pots for series/parallel operation if you want close to tele-single coil sounds as well.
Old February 16th, 2008, 11:24 AM   #3 (permalink)
ole6string's Avatar
Thank you soooo much.... that is exactly what I needed.
Old February 16th, 2008, 04:28 PM   #4 (permalink)
octatonic's Avatar
No worries.
FWIW Seymour Duncan's website has pretty much everything you need unless you want something exotic.
Old February 16th, 2008, 04:51 PM   #5 (permalink)
ole6string's Avatar
The sad thing was I was too much of a novice to know that the stacked pickups were the same hookup as humbuckers.
With your help, I'm learning!
Thanks again...
Old February 18th, 2008, 04:41 PM   #6 (permalink)
octatonic's Avatar
Thanks again...
It is worth remembering that vintage sing coils and humbuckers are almost identical for setup.
4 conductor humbuckers are a relatively new fangled idea- all you are doing when you tape the red and white leads together (with a SD humbucker) is continuing the series connection (from the end of the 1st coil to the start of the 2nd coil).
Understanding humbucker wiring is pretty simply but gives you a hell of a lot of options.
Have a look here:
http://www.1728.com/guitar.htm
For some great ideas on wiring.
One of my faves is a mod for strats where all pickups are wired in series (Basically a triple humbucker type of config).
Sounds great with distortion.
There is so much scope with wiring- there is a great primer available in the Guitar Player repair guide by Dan Erlewine.
Old June 16th, 2008, 08:34 PM   #7 (permalink)
Im looking for a wiring diagram, Ive got a Jackson JS1 with 2 stock humbuckers, 1 volume and 2 tone...i ordered a new 3 way switch and they sent me a 3 way for a Tele, it wires to the contacts on the side instead of the prongs on the bottom. so ANY help would be greatful, Thank you-Sunee
Fretspider22 is offline   Reply With Quote
