Old February 11th, 2008, 05:21 PM   #1 (permalink)
Question about body resonance
Just learning guitar, and being new to them, and particularly telecasters, I've got a question about body resonance.
I've noticed when playing mine unplugged, at certain points on the fretboard, most prominently that I've noticed at the second fret on the D and G strings, I'll fret a note and release the string, and the tone keeps ringing, not from the string, but seemingly from deep down in the body of the guitar. Damping the strings will not quiet this, it just plays itself out. Is this normal?
And will this resonance come through the amplifier? I mean, I make enough stray noise on my own without having to worry about this.
rufus21 is offline   Reply With Quote
Old February 11th, 2008, 05:27 PM   #2 (permalink)
boris bubbanov's Avatar
I think a lot of what you hear is one or more of the other strings ringing in sympathetic vibration. The bridge assembly, nut, neck, body and even tuners lend to that effect, and yes if other strings are moving the amp should pick that up. I don't think the sound will be disturbing, however, I think it will be 'natural'.
And when we mute or lift on a string, the effect of even that on the played string isn't instantaneous. The only time I see a note really 'die' is when the string breaks.
Bubban0v
Old February 11th, 2008, 05:38 PM   #3 (permalink)
I guess you might be right. I just tried playing around with it a little bit, but just layign my index finger across the strings at the first fret, and the resonance was either mostly, or completely gone.
I'm finding that getting control of these ringing strings is the most frustrating part of learning to play. I suppose it comes over time with practice, but still..........
Old February 11th, 2008, 06:06 PM   #4 (permalink)
woodman's Avatar
what counts is the sound that comes out of the amp. work with that and don't worry about the unplugged sound -- you're the only one who hears it!
BAND PAGES:
Old February 11th, 2008, 06:43 PM   #5 (permalink)
ryokan's Avatar
"I'm finding that getting control of these ringing strings is the most frustrating part of learning to play. I suppose it comes over time with practice, but still........."
Those ringing strings are the beauty of the guitar! Don't control 'em, let 'em RIIIIIING!.
ryokan is offline   Reply With Quote
Old February 11th, 2008, 08:04 PM   #6 (permalink)
Rufus, See if the ringing will stop if you mute the strings behind the nut. I bet you have an overtone from that side of the nut. If so add a couple of winds to the g and d strings the next time you restring or add a piece of foam to deaden the sound.
keiths is offline   Reply With Quote
Old February 12th, 2008, 01:17 PM   #7 (permalink)
that might very well be. I restrung it a month or so ago, but didn't quite get the string length correct for all of them. I'll do better with that the next time.
edit: nope, that didn't seem to have any effect.
Old February 12th, 2008, 01:43 PM   #8 (permalink)
I'm sorry, I do those extra winds on the G as just natural instinct, did not think to mention it. It is a great idea. Never done it to the D, I'll have to try that.
Bubban0v
Old February 12th, 2008, 06:55 PM   #9 (permalink)
Nick JD's Avatar
Strum the strings behind the nut with you hand muting the strings over the fretboard. Quite quiet.
Now strum the strings behind the nut with no muting on the strings in front of the nut. Now you can hear it better.
The high frequency notes get to the pickups via the strings. Strange how a string can make a noise while open, that is nothing like it's resonant frequency.
Hold your ears if you like easy-listening music. Here's Tom (Rage Against The Machine) exploiting some ringin'.
The same thing is happening with sympathetic vibration ringing the strings between the ferrules and the bridge holes/saddles in a string-through Telecaster, but don't tell the top-loader vs string-through brigade. The can's already overflowing with worms!
