Old February 11th, 2008, 04:57 PM   #1 (permalink)
after the country sound ... how?
i have the rio grande Muy Grande in the bridge.and stock in the neck. should i go with changing pickups or getting a compressor and delay. i currently use a digitech gnx3. if i were to change pickups i was thinking no casters
gator19482005 is offline   Reply With Quote
Old February 11th, 2008, 05:07 PM   #2 (permalink)
Moderator
getbent's Avatar
if you have gnx you already have a compressor and a delay... what amp are you using?
I'd start with just going straight into the amp with a little tiny bit of reverb. bridge pickup, tone up toward full on ...
if your pickups are a little too beefy (those are great pickups btw) you can lower them a bit to get a little thinner sound rather than just replacing them.
That will get you on the road to Buck and hag....
If you want a more modern sound... you can put the gnx in there and add a little compression and delay.
Happiness makes up in height what it lacks in length.
Old February 12th, 2008, 12:27 AM   #3 (permalink)
mellecaster's Avatar
+1 ....What He said !
mellecaster is online now   Reply With Quote
Old February 12th, 2008, 09:24 AM   #4 (permalink)
blue metalflake's Avatar
+ another. Thats hit the nail on the head.
blue metalflake is offline   Reply With Quote
vB code is On
Forums Directory
