Why does my Tele sound like it's out of phase??
Here's the deal.
My 50s had a Duncan Broadcaster bridge p'up in it. Lately it was sounding way out of balance from th neck p'up, thin, not much output. I figured I had finally sweated over it until it corroded and had a broken winding. Looked around in my box of parts and found what I'm pretty sure is a 52 RI p'up. Pulled off the bridge, soldered up the leads, put it all back together. Pickup sounds goood, neck p'up too, but the middle pos sounds out of phase now. It's that weird hollow tone like a Strat 2nd pos "quack" setting, no bottom to it. At no point did I touch the switch or pots while doing this pickup transplant. What the hell is going on with this? At the gig last night I could barely get a usable tone out of that middle pos, and that's where I usually leave it most of the night. Could there be something else at play here that made the Duncan sound weak and crappy to start with??
Just 'cause that's the way things are, that never did make it right. |
VENDOR
Not tryin to be a Smart A$$....but it most likely is....if that's all you changed...1st rule of troubleshooting...what's the last thing ya did ?
#3 (permalink) | |
The "out-of-phase" sound of 2 pickups is more relevant to the distance between them than most factors. For instance, Strat pickups are all wired in phase electrically, but the distance between them makes that quacky sound. Any two pickups mixed together will have phase cancellations (out-of-phase) at some frequencies.
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
...Sounds like yer neck P/U iss outta faze with yer lead now.
...Reverse the neck P/U leads first and check. If it sounds good then pull the neck P/U out and change the shield ground wire tew the udder lug. ...If it still sounds outta whack yew prolly haff reversed mag-a-nute polartity and yew kin check that by puttin the tew P/Us face tew face. It they push apart yer O.K. If they suck together yew haff a prollem yew kant fix cept by pullin all 6 slugs out and reversin them. Don't try this at home less yew dunn did it a few times. ![]() I'm still urglee but still luv the TELECASTER (MySpace) Please visit my page |
Thanks Fuzzy for mentioning the magnet polarity. If forgot to bring that up.
Mr. Duncan chose specifications from sometime in the 1950's Fenders for I think virtually all his SD pickups. Fender had adopted the opposite specs shortly thereafter and never looked back. So, basically any time you replace a Seymour Duncan with a Fender non-antique pup, or vice versa, if you weren't out of phase before you will be when you're done.
Do you have a AV52 neck pup you can match your toolbox pickup to? And yeah I guess there could be some other thing still not right under the hood, under the control plate there. I bought a '69 Thinline with a stock 50's vintage MIM pickup in the neck, and a Seymour Duncan Jerry Donahue in the bridge, and the combination is out of phase and not of much use (it will be changed), and that's what spurred my observations. Bubbanov |
The Duncan I put in my MIM strat was out of phase with the others when wired up according to Duncan's normal scheme. I'd try Fuzzy's tip first.
Helping to invent english country dance guitar since 1981. |
#8 (permalink) | |
Or did I get something wrong? |
#9 (permalink) | |
#10 (permalink) | |
#11 (permalink) | |
...I kant splain why yew wood haff ta ask sumone like Terry Downs bout that. ...I jes noe I dunn did a bunch of P/U liss-nin on my test bench and it waz a different sound whence the mag-a-nutes dent match. ![]() I'm still urglee but still luv the TELECASTER (MySpace) Please visit my page |
If the magnets are reversed, then you can reverse the wire polarity on one of them until you find yourself with an in-phase sound musically that is actually hum-canceling.
OK, this is exactly why I dislike tinkering with guitars.
My tech said he'd fix it for $35 and it's worth $35 of my time to have him do it instead of me.
#14 (permalink) |
i'm 99% certain your tech is just going to do this:
![]() it can be done to the neck pickup, too, in the same way. decide for yourself whether or not it's worth paying the $35! while you're in there, you might think about adding in a switch so you can get both in phase and out of phase sounds! or maybe a series/parallel switch? or both? usually the biggest concern with doing those modifications is converting the pickup to a 3-wire, but, if you have to do it anyways, why not have some fun, too? |
i've never heard of someone's sweat messing up a pickup.
i guess it's possible, but it seems unlikely. did you ever determine if the original pickup was bad? if you put an ohm meter across each of the wires it should read around 6k. if there was a broken wire you'd get no reading or your meter will zero out. also, where did you unsolder the original pickup from? the pot/switch side or the pickup side? either way you can fix it by re-wiring the bridge pickup or switch the ground and hot wires of the neck pickup. then they will both be in phase with each other. not saying you did, but it's a lot safer to disconnect the pickup at the switch and ground. leave the wires connected to the pickup. teles are nice to work on. you won't even have to take the strings off to reverse the neck pickup. |
#16 (permalink) |
oh, yeah, the original pickup: i'd get that looked at by a good pickup winder. the problem is almost certainly with the pickup — the "out of phase" sound your hearing now just seems like the normal "out of phase" sound you get when the pickups are, uh, out of phase (and which is what the modification i mentioned up there fixes), and wouldn't have anything to do with your original pickup's problem — but, there's no point in just tossing out a dead or dying pickup when you could easily get it fixed by any good pickup manufacturer!
#17 (permalink) | |
It's absolutely possible. I've ruined more than one humbucker that way. They just corrode.
#18 (permalink) | |
And yes as someone else said, Seymour does his PU's like the old days so his 9 out of 10 times will be reversed from the traditional stuff Just as a side note, the black wire is usually the start of the wind and the white or yellow is the end of the wind. You can look at the blacks on each PU and if they are both on the same eyelet on each pickup as in the left one on both then they are wound the same direction and if the polarities are the same then they will work fine as well, just not cancel any hum.
Benny Trevillian. So Many Guitars-So little Money DOH!!!!! |
