Old December 13th, 2007, 07:03 PM   #1 (permalink)
martyb1's Avatar
Primer or No Primer?
Well after the screwup with the router,and the fix with bondo,I got the binding all on
My question is now that there is bondo on it should I prime it before I paint it.It has been grain filled and sanding sealer has been used(before the bondo patch)I have all the glue sanded off but now I wonder if I should prime it
Any you guys got suggestions?
There is no bondo on the top or back just the edge.You think the paint will cover it?
Edit:I just noticed that I am now a tele-holic
Sure hasn't seemed like I have been here for 500 posts
Thanks to all who have put up with me and responded to my stupid questions
Before throwing it out,make sure it's not 16x13x1.75
martyb1 is offline   Reply With Quote
Old December 13th, 2007, 08:15 PM   #2 (permalink)
Ronkirn's Avatar
A bit of primer wouldn't hurt.... the patch will have a different texture than the surrounding area, the primer will even that out.
Ron Kirn
Lord, give me a sense of humor. Give me the grace to see a joke, To get some humor out of life, and pass it on to other folks.
The only thing necessary for evil to triumph, is for good men to do nothing......
Old December 14th, 2007, 02:59 PM   #3 (permalink)
Bloozcat's Avatar
If you're painting it in a solid color, which I assume you are, primer would be a good idea. In addition to the dissimilar textures that Ronkirn mentioned, the primer will also allow the paint to cover more easily over dissimilarly colored surfaces. In other words, dark and light patches will require different amounts of paint to cover them, and therefore more paint to even out the color finish. The paint will cover much more uniformly over a solid colored primer, and require fewer coats of paint.
Now having said all of that, it was a common Fender practice in the past to take botched sunburst finishes and re-paint them in a solid color...without a primer coat in between. So, it can be done, but if it's my guitar and I'm the one painting it, I'm using primer.
Bloozcat is offline   Reply With Quote
vB code is On
Forums Directory
