Old November 2nd, 2007, 05:23 PM   #41 (permalink)
Originally Posted by tuuur View Post
At the neck side of the bridge, there is about a mm space where the bridge floats over the body... how could that happen? Possibly the top of the body isn't entirely flat... or I overtightened the screws in the soft wood.
My USA tele has this too. IMO it's perfectly normal.
About your dents in the upper bout: they should more or less go away when you make the 1/4" roundover curve...
disclaimer: I know nooooothing!!!
Razzamatazz is offline   Reply With Quote
Old November 6th, 2007, 10:02 AM   #42 (permalink)
tuuur's Avatar
Last weekend there was major progress and some rethinking...
First, I drilled the output jack hole.
Then, with a newly bought 1/8 inch (3,2mm) roundover bit, I rounded the edges of the body.
Round the bouts, it seemed the routing bit was too low. But things worked out pretty good after some sanding.
Round this time I was worried about the gap between the body and neck in the neckpocket, which you can see here.
I thought a good option would be to replace this neck with the one of my Squier '51, which I don't play much anyway.
tuuur is offline   Reply With Quote
Old November 6th, 2007, 10:17 AM   #43 (permalink)
tuuur's Avatar
And then, when I unscrewed that Squier '51 neck... horror!
A crack in the neckpocket of the '51... a good thing I took it apart then.
And the cause for the gap in the neck connection was clear as well... the neck was attached to a far thinner body, so the screws were to small and couldn't hold on to the neck to well.
So I bought some longer screws (6cm) and shortened them to 5.5cm.
Now the neck sits firmly in the neckpocket.
Old November 6th, 2007, 10:20 AM   #44 (permalink)
tuuur's Avatar
I took some pictures from the in between state again:
It looks like the bridge is off a millimeter or so to the left. I guess I have to reposition it...
Old November 6th, 2007, 11:04 AM   #45 (permalink)
esteban's Avatar
Now I know what to do with my old desk...
When I die, they'll say, he couldn't play sh*t, but he sure made it sound good. - Hound Dog Taylor
esteban is offline   Reply With Quote
Old November 6th, 2007, 11:14 AM   #46 (permalink)
spankdplank's Avatar
Nice tele and thread, Tuur. This thread is so different and is a pleasure to follow. Yet another reason to love teles and this forum, as teles can be built from just about anything, and can end up as a working tool for the masses or fit and finished for maximum class and flash.
spankdplank is offline   Reply With Quote
Old November 6th, 2007, 11:53 AM   #47 (permalink)
tuuur's Avatar
Haha, yeah, it beats burning it.
(of course when it turns out bad you can still burn it... )
Thanks! I'm actually already planning my second Tryggvecaster following these same lines. This guitar building stuff is addictive!
Old November 6th, 2007, 12:03 PM   #48 (permalink)
tuuur's Avatar
I have planned to add a neck pickup to the Tryggvecaster. It's this one:
It was on a cheapo Teisco-ish 1960s guitar, where it didn't originally belong. I haven't got the faintest idea what it is, but it sounds and looks cool.
Old November 6th, 2007, 12:25 PM   #49 (permalink)
Big Tony's Avatar
This is going to be a very cool Telecaster.
You're doing great, warts and all!
/ Tony
{8^)>
Big Tony is offline   Reply With Quote
Old November 6th, 2007, 12:47 PM   #50 (permalink)
riggergreg's Avatar
Tuur, Your gonna love that gold foil.
Another year older and deeper in debt
riggergreg is offline   Reply With Quote
Old November 7th, 2007, 04:39 AM   #51 (permalink)
tuuur's Avatar
Thanks! I'm still not sure how to finish it though. I guess it will be either Yachtlacquer or Ikea Behandla stuff. The first one is a very strong high gloss lacquer. I can't find anything on the can concerning ingredients... and the Ikea stuff is a sort of glazing paint. Would that be any good at all?
I loved it already while it was in the Teisco! But apart from the sound, that guitar is unplayably bad.
But another good thing about that Teisco is...
It's got another goldfoil pickup! Perfect for the soon to be thinline Tryggvecaster.
Old November 7th, 2007, 06:25 AM   #52 (permalink)
tuuur's Avatar
Yesterday I installed the pickguard and stuck some tape to it, to trace the route needed to accomodate the goldfoil pickup.
Then I cut out the opening with a fine blade on the jigsaw. I find this is not the most precise way to do this, but don't know how to do it otherwise... Ideas are welcome as I guess I will encounter this more often.
From a distance, the result looks good enough for me.
Then I routed out the neck pickup cavity. With a long 8mm drill, the hole for the wire was drilled.
Put together again, this is the current state of the build!
Old November 7th, 2007, 06:41 AM   #53 (permalink)
cool git!
moparmutt is offline   Reply With Quote
Old November 7th, 2007, 06:56 AM   #54 (permalink)
Very very good job, for a unique guitar, i love this guitar.
Regards, Infrapista
infrapista is offline   Reply With Quote
Old November 7th, 2007, 10:47 AM   #55 (permalink)
It looks very nice so far. You're doing fine - keep up the good work!
fenderix is offline   Reply With Quote
Old November 7th, 2007, 07:09 PM   #56 (permalink)
tuuur's Avatar
Tried it out at the rehearsal tonight, and it qualifies!!!!
The bridge PU bites like it should, both PUs give a great in between sound, somewhat middy...
but that goldfoil GROWLS!
An instant favorite guitar. And it hasn't even been finished properly yet...
Old November 7th, 2007, 07:42 PM   #57 (permalink)
bobthecanadian's Avatar
Good work.
It don't mean a thang if it ain't got that TWANG!!!
bobthecanadian is offline   Reply With Quote
Old November 10th, 2007, 04:32 PM   #58 (permalink)
tuuur's Avatar
Today I did a test-finish on a piece of scrap Tyggve shelf. It looks like it darkens the grain somewhat, which is good, and yellows the wood a tiny bit, which is good as well. The grain seems to be open still, so I guess it will need quite a few layers.
Furthermore, I made a logo in Inkscape:
I can't get myself to take it apart yet for finishing though.
Old November 10th, 2007, 05:03 PM   #59 (permalink)
We need sound!!!!!!!!!!!! Must hear!!!!!!!!!!!!
Old November 18th, 2007, 08:29 PM   #60 (permalink)
tuuur's Avatar
I hear ya... but I haven't got my recording stuff sorted out yet. What's more, it badly needs to be painted... I play it too much in this state and can see the damage already, soft dark spots developing.
So tomorrow I'm going to take it apart again.
Old November 18th, 2007, 08:35 PM   #61 (permalink)
tuuur's Avatar
OK, now for the headstock... (can you guess I am stalling the finishing of the body? ;-) )
The Squier has got to go to accomodate the Tuuur-decal. So I attacked it with a piece of mirrorball glass.
Actually, I like Squiers, so it's with a bit of a heavy hard I destroy this logo...
This is the kind of ground ink and finish that comes off.
Haha! 'uier' means "Udder" in Dutch! The Uddercaster!
(OK, that's not that funny... :-D )
Now we're there. You can tell where it came off, but not too much to bother me a lot. I'm happy.
Old November 18th, 2007, 08:38 PM   #62 (permalink)
tuuur's Avatar
And here's a mock up of what I'm aiming at:
Didn't have much luck printing the logo on decal paper today... the first test had runny black ink... the second was sort of okay, but after spraying the sealer there was a lot of pinkish hue around the letters. We'll see how it looks when it's out of the water.
Old November 19th, 2007, 09:10 AM   #63 (permalink)
colonelrobert's Avatar
[quote=hekawi;977538]looking great so far...i like the natural wood, very nice!
by the way, when you use the whammy bar on this strat copy does your car window roll down?:
My wife and I were wondering if it start's playing on the second kick?
The Man With The Golden Pen!
colonelrobert is offline   Reply With Quote
Old November 19th, 2007, 04:01 PM   #64 (permalink)
tuuur's Avatar
Heheh... this guitar has some automotive history... once upon a time it had a Opel bumper mount as a tremolo arm. I had other plans with it, which can be seen in this doctored image...
Old December 3rd, 2007, 02:47 PM   #65 (permalink)
tuuur's Avatar
So there it is, the spot where it originally read 'Squier ' is somewhat lighter, but not much:
Next: finishing. I thought about doing it the right way, as a test, with rattlecans and stuff... but decided to stay in the original character of this post and use some Yacht laquer I had in the shed.
http://www.myspace.com/tuuur
Old December 3rd, 2007, 02:52 PM   #66 (permalink)
tuuur's Avatar
First I sanded it with some sanding paper (it read 100 on the back, so I suppose that would be 100 grit). Then, I applied a first layer with brush. And let it dry.
I guess it was too humid because one day later, things were not that dry still. I ended up leaving it hanging for 5 days.
Time to check...
and sand again...
There's some wider gap between to laminated pieces of wood (mind you, that's the part Ikea glued!). I wonder how long that body will stay in this form...
Old December 20th, 2007, 02:35 PM   #67 (permalink)
tuuur's Avatar
After a few weeks of painting, leaving it to dry for a few days, discovering dust and drops, sanding, repainting, etc. , I call it finished.
When putting it back together again, I decided to keep the controls in the standard position. It's got a non standard 5-way switch, which is now wired in a strange way:
1. bridge
2. bridge/neck
3. neck
4. neck (yep, the same as position 3)
5. nothing (acts as kill switch)
Took it to the band's rehearsal, and it plays great (for the kind of music I play, which is very forgiving when it comes to imperfections of any kind).
Here it is:
All in all, I think for a first build it's a success. I got hardware plus necks for another 3 guitars... so I'm off to the Ikea again!
Old December 20th, 2007, 09:10 PM   #68 (permalink)
PMC70's Avatar
Great build Tuuur! The Tryggvecaster looks awesome.:) Do you really have 8 p/u's in the Poltergeister, or is that just a mockup of the projected eventuality?
Nice job. I really enjoyed your thread. Have fun on your next build.
The looser the waistband, the deeper the quicksand; or so I have read.
PMC70 is offline   Reply With Quote
Old December 21st, 2007, 05:29 AM   #69 (permalink)
Well, I guess I am not the patient kind of guy. So having come this far, I installed the bridge, bridge pickup, control plate with a volume pot, and a makeshift output jack...
And here it is now (is a guitar named after a 10th century viking king a she? don't think so!):
And hey, what do you know, after some tweaking of the bridge saddles it's actually very playable already! Sounding gritty like it should.
I just realized... we have the same cable
601210 is offline   Reply With Quote
Old December 21st, 2007, 06:00 AM   #70 (permalink)
tuuur's Avatar
Thanks!!!
It's a mockup... I have enough pickups for it, but the single coils I have are strat types; they can't be placed with the coils next to eachother...
But the christmas holidays are here; maybe I find some time to experiment.
Those are fun things to realize! I had to resolder this one a few years ago, but since then it never let me down.
Old December 21st, 2007, 06:05 AM   #71 (permalink)
tuuur's Avatar
Soundclip!
Finally I got my recording stuff together, so I recorded an extended version of a song by good pal Ottoboy. I used midi drums and recorded the voice and instruments through a little Behringer MX 602A into the pc and applied some digital effects.
Never saw her face again
Old December 21st, 2007, 06:39 AM   #72 (permalink)
Fatmanstratman's Avatar
tuuur, I have just re-read this whole thread again, as I have found it thoroughly absorbing from start to finish - GREAT job!...
This morning, I have read through it with my guitar-playing son, and we have been discussing the possibilities of making guitars using woods from various "household" objects, and the pros & cons of each item we have suggested.
It is threads like yours that provide inspiration to so many folks out in TDPRI land. You have shown what can be achieved with a potent concoction of ideas, inspiration, trial-and-error, patience, a little care and - above all else - the courage to forge ahead and TRY something new. I salute you!
Y'know, having read all the fascinating threads by members like tuuur, Buckocaster51 and EdHawley, I am STILL so tempted to put together a TDPRI book of some of the great start-to-finish builds (with the permission of the original authors and the Webmaster, of course). I know it would NEVER be anything near Nacho's wonderful Blackguard Book, but it would be a unique source of reference for any members (like me!) who might be thinking of trying their OWN build....
"Behind every argument is someone's ignorance."
Fatmanstratman is offline   Reply With Quote
Old December 21st, 2007, 06:57 AM   #73 (permalink)
shades's Avatar
Cheers tuuur! Fine work and craftsmanship indeed.
Thanks for the post and the audio clip.
Good stuff!
It's 106 miles to Chicago,we've got a full tank of gas,half a pack of cigarettes,it's dark and we're wearing sunglasses...
shades is offline   Reply With Quote
Old December 21st, 2007, 07:17 AM   #74 (permalink)
tuuur's Avatar
Why, thanks a lot! (don't really know what to answer to a post like that... )
As most of the new tryers would say, all there is to it is just do it...
And I salute YOU, for reaching the 2000 posts mark!
That would be a wonderful idea! I must say that I read the Buckocaster threads before even starting to think of attempting to try a build. That one is the truly essential thread on this forum for me...
Old December 21st, 2007, 08:25 AM   #75 (permalink)
Steve G's Avatar
Tuur i am just so impressed with your build. If theres one thing better than a nice piece of gear its a nice piece of cheap gear.
i think that one will mean a little more to you than a shop bought tele.
Youve inspired me to one day have a go. If not for lack of tools/skills/time Id start now!
"He was a drinkin' man with a guitar problem..."
http://www.myspace.com/stevegiddings
http://www.myspace.com/hiandlonesome
Steve G is offline   Reply With Quote
Old February 10th, 2008, 08:48 AM   #76 (permalink)
tuuur's Avatar
1. bridge
2. bridge/neck
3. neck
Here are some pics of the controls.
Anybody recognize this kind of switch? It's not your standard Fender 5 way, so I'm at a loss on how to interpret standard schematics on this one.
[EDIT]
Deaf Eddie apperantly did and posted a wiring schematic in the 5 way switch kill position thread. I'll definitely be checking this one out!
I discovered the older tone pot is dodgy. I've bought some CTS pots for replacement. Also, the Goldfoil is not grounded well; if I touch it accidentally with a string the sound is killed. Plus, it is sitting to near to the strings... so some touching up to do yet.
Old February 10th, 2008, 02:28 PM   #77 (permalink)
Hi tuuur,
awesome thread. I've been lurking on this forum for some time, and along with some other threads (by jwells, buckocaster, ron kirn and some others I don't remember at the moment) your IKEAcaster threads gave me the impression - wow, you can do this yourself, too.
So I bought a decent MacAllister 1500W router and some other stuff and I'm quite ready to start building (although my first son will be born on friday...). I ordered Keystone pickups on new year's eve, but they haven't arrived yet, must be stuck in the customs, I suppose. Inspired by the IKEAcasters I went to our local IKEA, before butchering a nice piece of alder or ash and - to my big disappointment - they're out of Tryggve boards until week 15/08. So I went to some other places that sell boards, but nobody has them in 15mm, they're all 18mm or 20something, at least no sizes that get me close to 45mm when stacked. Maybe I'll wait until week 15, maybe I'll buy a piece of alder, don't know yet, but I know I'll follow the building-threads here in the forum.
Thanks a lot for the inspiration and I hope, I can open my own building thread soon.
Markus
(\_/)
(o.o)
(> <) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
Voozle is offline   Reply With Quote
Old May 24th, 2009, 07:37 PM   #78 (permalink)
tuuur's Avatar
The waterslide decal I made didn't hold out. So I decided to give the headstock a more 1950s look; ordered with GFS some bushings and split shaft Kluson lookalikes and a single string tree.
Then I devised this logo:
Here is a mock up how it'll look on the headstock.
I plan to do Bucko's trick of a double decal, in which you paint the gold on the first decal and then apply the second oe on top of that.
Would acryl brush paint work?
Old May 24th, 2009, 08:02 PM   #79 (permalink)
chisa's Avatar
sanding the finish off the head and lacquering is not too difficult.
i have a guide if you want a copy
chisa is offline   Reply With Quote
Old May 25th, 2009, 09:36 AM   #80 (permalink)
fernando's Avatar
absolutely cool! includding the logo
fernando is offline   Reply With Quote
