Birth of a body- another work in progress
I received some really gnarly looking rough cut ash a while ago, and contemplated sending it back. Being busy, along with being a World Class procrastinator, I never did. In the meantime, I have been thinking about a good way to use it. I finally decided on a course of action, and figured you low-tech guys might dig seeing how it goes..
I cut the one piece into 16" lengths, and played around with the pieces until I liked the grain orientation and the usable areas of the lumber. ![]() Once I had determined the surfaces to be joined, I ran the edges on the jointer to square them up, and to give a nice, tight seam. ![]() Once the pieces fit together, I applied some wood glue on one edge ![]() and smoothed it out with my finger, to check for foreign matter, and to make sure there was 100% coverage. You can see the waxed paper in the background, and the board it is sitting on is 12 ply birch. I use this board all the time, as it is very smooth, flat, strong, and stable.
If you are driven to play, you will find a way. |
At this point I set the waxed paper below the seam area, and put the two true edges together. Tha waxed paper keeps the work separated from the work table.
![]() I temporarily put a pair of bar clamps on, to hold both pieces together, and set my template on top. This way I can physically make sure that the usable areas of the wood are going to work, and the bark/spalted/yuckky stuff will be trimmed away. It's close, but this one looks great. Lucky me. ;) ![]() Now that I know the wood will work for a tele, I clamped everything down to the table (for alignment of the surfaces), and then squeezed the joint tightly with some bar clamps. Once the glue squeezed out, I wiped the surface off with a damp rag. It will need to sit overnight now, and I'll continue tomorrow. ![]() If you noticed the roughness of the wood, and the low spots at the seam, don't worry. I'll show how to deal with these problems as the thread continues.
If you are driven to play, you will find a way. Last edited by Rich Rice; October 8th, 2007 at 04:10 PM. Reason: forgot one of the pics |
So how you gonna deal with that center seam? Daddo it out and scab in some more ash? Fill it with epoxy or bondo? Or leave it? Might be a cool look.
This should be a cool thread. I love seeing how other people make their bodies. Every one has there own cool tricks. |
I'll trim the excess from the sides, and run the slab through a thickness planer first. Once the body starts to settle in to where I like it, I'll check the thickness and decide if I should chamber it and add a nice top, or run the body thinner. The weight and the look will determine the process. I'm not planning on a solid color at this stage, otherwise Bondo would be just the ticket. If everything looks great (doubtful) I would just leave it alone. Fortunately, I glued up a half dozen tops about a month ago- so it may wind up as a chambered tele or esquire with a fancier top. Just have to wait and see tomorrow. I'll know pretty quickly what I want to do with it. Whatever the body demands...
Super Moderator
Gnarly?
Yeah, that's gnarly. Thanks for sharing. I can't begin to describe how much I have learned from TDPRI members over the last few years. This is such a great place!
"If you can't say something nice... don't say nothing at all." - Thumper the Rabbit "She's not only merely dead, she's really most sincerely dead." - The Munchkin Coroner |
Superc_1, I'd love to see some pics of your build.
Bucko, I always watch your builds, too. I've enjoyed each one. This piece was pretty nasty looking, but the wood inside that rough exterior is really nice.
Here's the rough wood after the clamps came off:
![]() ![]() I measured and cut both sides down to wind up with just over 13". ![]() By treating both sides the same, I've maintained my center line. Once the piece was trimmed to size, I started running it through the thickness planer. Heck of a machine, for sure. ;)
I kept passing the rougher side through until it started to look better, and then flipped it over to true up the back side.
![]() ![]() Quite an improvement! I ended up with approximately 1-5/8" thickness, so I'll end up putting a pretty top on this one. I haven't weighed it yet, but it feels fairly heavy. This will end up being chambered, which will make it lighter and more resonant. As stated earlier, each piece of wood dictates how it needs to be handled. That's half the fun for me, seeing what develops. ![]() All the planing generates lots of shavings, which I can use for starting campfires... Nothing goes to waste around here.
The grain is now interesting, asymmetrical. The uglies are gone. Weight after rough cutting is currently 5.5 lbs. That's gonna change right quick. ;)
![]() This body style is our "Osprey". No, it doesn't fly. ;) I drilled three holes through my template and into the slab, to keep everything straight. Then I pinned it with three 1/8" steel pins. ![]() ![]() Once the template was secured, I ran a soft lead pencil around the perimeter, to mark the finish shape on the slab. then removed the template and pins.
If you are driven to play, you will find a way. Last edited by Rich Rice; October 9th, 2007 at 10:50 AM. Reason: Spelling correction |
Once the slab was marked, I put it on the band saw for rough shaping. This saves lots of time, as well as wear and tear on the routers and router bits. I want to cut pretty close to my lines, without touching them.
![]() ![]() In the tighter curves, it is a good idea to make several relief cuts, otherwise the blade can bend, overheat, or snap. This is the same with jigsaw blades or band saw blades. The key is to go slowly, and don't bind the blade. ![]() See how the relief cuts work? I always love this part.. ;)
It's good to see someone else using primitive tools. Rich ..... you definitely qualify to be a member of the Caveman Guitar Builders Guild. Ed Hawley doesn't qualify.
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
#16 (permalink) | |
#20 (permalink) | |
This will be fun! Cheers ED |
#21 (permalink) |
Well, I got busy yesterday- and made good progress on this body. Here are some pics to give a quick rundown of what went down..
I put the template back on, and re-keyed it with the pins ![]() Then ran around the edge with a top bearing router bit in a hand held router ![]() Then followed with a tall bit on my router table ![]() This could have been accomplished with just a hand held router (I've done many bodies that way), but the table offers more stability, accuracy, control, and safety. I also find it is a bit faster. Looking good!
#22 (permalink) |
The template and the body are identical. Notice I left the pins in the body
![]() Then put my second template on, to cut the neck pocket. Chris saved me at this point, as I want the neck pocket to be 5/8" deep on the finished body. I set the router bit to a 5/8" depth- forgetting that I plan to do a top on this body. Right before I made the cut, Chris walked by and asked me about the depth of cut. Whew.... So I reset to 1/2" depth. My top will add about 1/8", and I'll trim the pocket after the top is glued on. Glad somebody's thinking... ![]() The rout was made with a 1/2" top bearing bit in the hand router. ![]() Once that was completed, I did a rough sanding of the edges on my oscillating spindle sander. What a great machine. ;) I used to sand the edges with a sawed off broomstick handle covered with sandpaper. This machine just saved two days of screwing around, and it does a better job- plus keeps the edges square to the faces. ![]() If you look at the edge of the neck pocket in the above picture, you can see there is a little material left where you would normally see a notch. I made the pocket a bit skinnier than usual, in order to hand fit it to the neck after the top is on. I would rather have it smaller, as once the wood is gone, it's gone.
#23 (permalink) |
Here I put a flatter spot on for the output jack, using a 9" disk sander.
![]() Then over to the drill press to drill a few holes for the chambers. I started with a 5/8" diameter forstner bit and hit the corners of my chambers ![]() ![]() Then put a big mother on there to hog out the rough shape
#24 (permalink) |
Once I had the bulk of the chambers drilled out, I played "connect the dots" with several passes of the hand router. I could have made another template for this, but opted to just carefully route these by hand. Once the top is glued on, they will be buried forever anyway.
![]() ![]() ![]() At this point I had to leave to go teach guitar lessons, and this is where it sits right now. I weighed the body, and it is now at 3 lbs., 6 oz. It is starting to "ring" when I knock on it, I'll bet it's going to be very lively.
#25 (permalink) |
Is that a granite top router table? That could be crossing the line on your Caveman Guild membership.
#26 (permalink) | |
I think the countertop cost me $17.00.
#27 (permalink) |
I decided to clean up the chambers a bit more, and thin out the back.. I'm just over 1/8" thickness now. It really opened up the tone when I knock on it. Better.
![]() Here is the top I chose for this project. I bought some flame maple a couple of months ago, and sawed it up into tops (resawed on the band saw). I glued them up, clamped them, and let them settle down (they were very thin and wanted to warp). Now that they have stabilized, I looked through them (there were four) and decided that I like this one for this guitar. I bookmatched the others, this one is not. So much the better, as I think this is in keeping with the spirit of this instrument. I did offset the pieces to get a cool grain orientation, though. It will show much better when I do some finish. ![]() I placed the top upside down on the counter, and put the body (face down) on top of it. Then checked to make sure the center lines of both pieces lined up properly. ![]()
#30 (permalink) |
Once in position, I traced around the body to get an idea of where everything will fall when it's assembled.
![]() Once the outline was on, I have several points of reference as far as control location, bridge, etc. ![]() My concern here is that I don't want to dampen vibration, but need the top to be stronger where the control plate is ultimately mounted. Since the top is only 1/8" thick, I need to reinforce the area in the interest of durability, and provide some wood for the mounting screws. I cut out a 1/4" thick piece of mahogany, slightly bigger than the control plate ![]() I like to dampen the areas to be glued, as it helps open the pores of the wood and creates a better bond.
If you are driven to play, you will find a way. Last edited by Rich Rice; October 10th, 2007 at 09:50 AM. Reason: goofed up the order of pics.. oops. Distractions suck. |
#35 (permalink) |
Looking great , keep it coming, One day I would like to try it and these threads are very helpfull, Thx.
1973 Fender Tele. 1997 Fender Tele Squire Pro Series 2000 Partscaster Tele ------------------------------- 40 Watt Fender Hot Rod Amp |
#37 (permalink) |
Thanks guys. Glad you visited. It really is interesting to see how others do this. It has taken years to develop my style, (good or bad) and hopefully seeing my way will help you avoid some of the pitfalls. I've really only had to put one body in the fireplace- I modded it to death...
I pulled the clamps, and tried to seat the top- no bueno. One corner of my cleat was too close to the inner rim of the body. A sharp chisel and a dull mind fixed it right up. ![]() I then assembled all the clamps I thought I would need, and my trusty birch plywood. It's a good idea to have all your stuff handy before you start gluing things together... I applied some wood glue, and spread it with my finger. Again, many use a stick or a brush, I like to get my fingers in the glue to massage it into the (pre-dampened) wood. This way I can feel if I accidentally got wood chips, dirt, etc. in the glue and can take steps to have the joints immaculate. ![]() All set. Just the way I like it. Just enough glue for good coverage, but not a horrible mess to clean up afterward. ![]() At this stage, I had to move quickly, and couldn't stop to take a pic. I placed the top on the body, and flipped the whole thing over. Then I adjusted the top and bottom center seams, and visually placed the body inside my pencil outline. This isn't real scientific, but it is very effective. Once I was satisfied with the placement, I put a second piece of 3/4" birch plywood on top, and started clamping it together. ![]() I want to see a small amount of glue squeeze out all around the joint, and make sure there is solid pressure all the way down the center. I don't want any loose spots, as they could resonate or rattle.
#38 (permalink) |
The solution? MORE CLAMPS!!
![]() Here's what I like to see. Just a little bit of glue. ![]() Good thing I'm not superstitious, it ended up with 13 clamps to get it where I wanted. Now outside to dry for a while...
#40 (permalink) |
Rich, thanks for the pics it has already answered some of my questions. Here are a few pic's of the build I have started. The body wood is swamp ash I've been carrying around for 32 yrs. The neck is flamed maple. Keep your build coming with pics. Like they say a picture is worth a thousand words and as slow as I am they are are worth 10,000 words to me.
