wire guage for rewiring tele
am rewiring my mesquite body tele to a 5 way switch apparently the wire that was used at the factory is 20 guage multi strand. Will it hurt to use 18 guage multi strand for my rewire. that is what i have readily available
Twang With a Bang |
| Sponsored Links |
Here is a post about wire gauge from a while back.
Electrically, the wire gauge does not matter at all. The current in the wire is in the nanoamp range. Solid wire is non preferable in this application because it breaks easy with flexure and vibration. Stranded wire is the only way to go. Regarding size, you will have great difficulty trying to work with 18AWG stranded wire in the control cavity. It can probably be done, but it will be more difficult that smaller gauges. 24AWG is my favorite for guitars.
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
Is 26 guage from Guitar Fetish too thin???
Practice make permanent!!!!....Perfect practice makes perfect!!! Chris B. Current Band www.productoffaith.net Last band as a bass player www.neonjones.com |
just order the vintage cotton covered wire from allparts, inexpensive and easy to work with,
Ron Kirn
A government big enough to give you everything you want, is strong enough to take everything you have. – Thomas Jefferson Just because you do not take an interest in politics doesn't mean politics won't take an interest in you! -Pericles (430 B.C.) |
Thanks!
#9 (permalink) | |
The smaller the guage, the easier to get up to hot enough temperature to solder. I've tried some 18 or 20 guage and some solid, and all of those required a lot more heat to solder. I had one tone pot I must have worn out from heat after a couple of years, with several pickup swaps. I replaced that one but the adjacent volume pots doesn't seem to work as well as it used to. None of my Teles are vintage, and the couple that are vintage-looking (MIM Classic Series) didn't come with cloth wiring. I've been content with the more affordable / generic wiring from electronic shops too. |
#11 (permalink) | |
"I'm gonna toss my telecaster through the television screen cause I don't like what's goin on!" - Radiators From Space |
#12 (permalink) | |
-k |
