glueing a covering on a tele
i'm thinking of glueing a covering,maybe newspaper/newsprint all over a body.
its got a poly coat on it at the moment and i dont really want to strip it,any ideas on the glue? also how to seal it,i've got some clear nitro would this be enough or would i have to go down the thick poly route.(like the "wallpaper paisley's)
"hanging on in quiet desperation is the english way" paul |
| Sponsored Links |
I like Barge contact cement (Ace Hardware carries it).
It's rubbery, so you can roll off the excess, and it helps in later removal some, however once it's been there awhile it's plenty tough. My brother the wholesale leather goods elf turned me onto Barge decades ago. |
Nitro, poly and whatever glue you use may or may not be compatible. I would check the lables. Likely a poly over the top is going to be the way to go. You don't put it on super thick.
Also, I wouldn't strip the guitar first. |
#4 (permalink) | |
www.projectguitar.com/tut/mat.htm hope it helps ya |
Wow - that tutorial sure looks complicated to me!
I've been thinking about trying something similar on a Tele top, but I would simply digitally print the image on to self adhesive vinyl, overlaminate it with clear vinyl (for protection), peel off the release paper, and stick it onto the guitar. It would LOVE the poly finish, and would adhere perfectly. This is the same sort of thing that you see on trucks & cars. We have already tried this on pickguards, and the one on my son's Strat is still as good as the day we put it on (even with his heavy metal thrashing!). ![]() To be fair, it helps if you know someone with a Sign Shop. We run our own, so we can play around with this kinda stuff anytime. Good thing is... when you get sick of the design you can peel it off reasonably easily and fit a new one!
. . ![]() . "Behind every argument is someone's ignorance." |
Tacky...
We saw the "Facelift" launched at the London Guitar Show this year. They sold a few (mostly to kids), but most people just looked, smiled, and said "Erm.. yeah... right..."
I have to be honest, they were pretty ill-fitting, and looked exactly what they were - novelty gimmicks. You could see straight away that they were just stickers fitted over the front of a guitar. No attempt made to disguise the fact. And they are not cheap.... I was referring to a real job, properly fitting and made to look like it belonged on the guitar.
#10 (permalink) | |
I meant something like the 'Paisley' finish rather than something like this: ![]() I mean, you would NEVER know that this was just slapped over the top of a Tele, would you?
I don't know if it is available in the UK, but craft stores in USA sell a product called "Mod Podge", for decoupage. It is water soluble, and hardens clear. Once it has cured, you can spray any type of clear protective finish you want over it. It can be applied with a brush or sprayed (if you have a sprayer). You will want to seal it when you are finished, as it remains a bit tacky. I've used poly and nitro over it with good results. Nice to work with, and water cleanup. Good luck!
Please visit my website! If you are driven to play, you will find a way. |
