fundraiser
Old July 21st, 2006, 02:31 PM   #1 (permalink)
Just got a new neck, but frets are sharp...what do I do?
Just got a new allparts neck that's really nice, but the frets are sharp on the sides...
what must I do to correct this?
Thanks
SB
SinnerBoy61 is offline   Reply With Quote
Old July 21st, 2006, 02:44 PM   #2 (permalink)
bagpipe's Avatar
I had the same problem on the Allparts neck which I got. I took it to my tech and he filed them down while he was doing a set-up on my guitar. I guess you could do it yourself if you knew what you were doing and had the right tools.
"Assistant to the Travelling Secretary"
bagpipe is offline   Reply With Quote
Old July 21st, 2006, 02:46 PM   #3 (permalink)
Mark Davis's Avatar
Take a hot shower leave the neck on the bathroom counter be sure it doesnt get wet. The humidity created by the hot water should cause the wood to swell back up to where it was before it dried out from not being humid enough.
Might take a few showers before it works. LOL
Old July 21st, 2006, 03:13 PM   #4 (permalink)
eryque's Avatar
Mark, I like the way you think! But I think that the wood will shrink back when he's not in the shower, won't it?
Unless the frets really stick out, you may find that filing that close to the wood is tough to do without damaging it. You might have better luck with sandpaper and a sanding block. 3M 320 grit from the auto supply store will do you nicely. If there's a lot of fret to remove, use 220, then 320 and maybe 600 to smooth the ends.
If the guitar wasn't finished already you should be ready to seal and finish. If it was, then you might have to touch up the finish. If you're lucky you'll just need to wet sand a little bit and polish.
eryque is online now   Reply With Quote
Old July 21st, 2006, 03:19 PM   #5 (permalink)
shakedancer's Avatar
In your case, I would have a tech do it.
"If you don't like the Blues, you got to have a Hole in your Soul." Luther Allison
JOE
shakedancer is offline   Reply With Quote
Old July 21st, 2006, 03:49 PM   #6 (permalink)
Mark Davis's Avatar
The last Strat I got used was like that sharp edges. I just left it on a stand in the bathroom and after 2 days of being in there it was fixed. Still feels fine 3 months later. If I left it out in the sun all day it might dry back up and expose the sharp edges but so far its stayed fixed inside my air conditioned apt.
Old July 21st, 2006, 03:58 PM   #7 (permalink)
0le FUZZY's Avatar
  • I yewz a rubber block sander with a fine paper (400 or finer) and go up and down the neck at a +/- 45 degree angle tew the fret ends.
    MY KIND OF MUSIC !(click)
    SMORE !!(click)
    Please visit my page
  • 0le FUZZY is offline   Reply With Quote
    Old July 21st, 2006, 05:01 PM   #8 (permalink)
    Thanks all for the replies. Good advice mark, but I'd like to get them filed down some so they're smooth, and more player friendly. I really think that's what they need.. It's just on the sides of the neck, and I think I have a good file sitting around, so that may be in order.
    Thanks guys
    Old July 21st, 2006, 06:04 PM   #9 (permalink)
    Nvr2Many's Avatar
    I had the same problem, and it is due to dry wood. You have 2 options:
    Take the neck to a belt sander and have at it (LOL) or the method I used which as to buy a small sanding stone. To be safe I put masking tape between the frets so as not to scuff anything. Then using the block I touched up the sharp ends. Same method Fuzzy is recommending, I just happend to have the sanding stone because I use it to tune snow skis.
    It don't mean a thang if it ain't got that twang!
    Nvr2Many is offline   Reply With Quote
    Old July 21st, 2006, 06:04 PM   #10 (permalink)
    Thanks
    SB
    If it's a new neck, then fixing faults is not your problem. I'd complain.
    chickenpicker is offline   Reply With Quote
    Old July 21st, 2006, 07:20 PM   #11 (permalink)
    Rob DiStefano's Avatar
    In the best of all worlds, dress the fret ends with a safe edged fret dressing file, followed by an abrassive buffing from 600 grit through maybe 2400 grit. Or just do what OF suggests.
    All AP unfinished Fender Japan necks will require fret end dressing. Your neck supplier should take care of that for you, gratis.
    Old July 22nd, 2006, 12:14 AM   #12 (permalink)
    I agree with chickenpicker. If you're paying US$ 250+ for a neck you should not have to deal with sharp frets. That's just sloppy.
    teleman65 is offline   Reply With Quote
    Old July 22nd, 2006, 06:34 AM   #13 (permalink)
    If the neck is finished, absolutely yes.
    If the neck is unfinished, I think it's acceptable to not have fret end dressing in order to keep pricing as low as possible. Dressing fret ends is well within the realm of most players, and something that should be learned - just like doing a setup.
    Old July 23rd, 2006, 02:30 AM   #14 (permalink)
    Yes, the neck was unfinished, and in fact, I got it through an allparts dealer, for about 96 bucks...I ain't complainin..haha
    Old July 23rd, 2006, 06:01 AM   #15 (permalink)
    Do companies like Allparts offer necks in a range of completeness then? I didn't know.
    If that's the case, it's your job to get it finished, but for $96 I wouldn't complain either.
    Old July 23rd, 2006, 09:06 AM   #16 (permalink)
    After you get them filed, always leave it in the case when not in use and you will not have that problem again.
    JOE
    Old July 23rd, 2006, 09:14 AM   #17 (permalink)
    ... along with a humidification film canister.
    Old July 23rd, 2006, 10:57 AM   #18 (permalink)
    I managed to cure a case of fret sprout with two slices of bread. On the advice of a guitar tech, I put one piece of bread in my case, closed it up and left it overnight, until the bread dried out. I repeated this, and those two pieces of bread contained enough moisture to fix my problem.
    I was told to do this before resorting to files etc.
    Chris Browne is offline   Reply With Quote
    Old July 23rd, 2006, 12:40 PM   #19 (permalink)
    jwells393's Avatar
    I live in a pretty dry climate. Sooner or later every guitar I own may need the ends of the frets filed depending on where the neck originated. The frets on the Allparts neck were probably flush with the wood originally.
    Old July 23rd, 2006, 03:06 PM   #20 (permalink)
    Didn't Fuzzy conduct an experiment on curing fret-sprout recently, involving a swimming pool?
    Old July 23rd, 2006, 07:01 PM   #21 (permalink)
    Just file and/or sand them now while they are sticking out, and you'll likely never have to deal with them again.
    Otherwise, every time your guitar dries out from the weather, or travel etc. you are going to be battling this.
    sidneystreet is offline   Reply With Quote
