R.I.P.
1meg pots w/bleeder caps are great!
I put this Tele together with a 250K volume pot, just to give the 250K pots a shot because so many Telecaster were built with them.
Trouble is, it lacked dynamics. And the overwound GFS bridge PU sounded too much like a humbucker. Not that I don't like humbuckers, but that's not what I was going for. So last night, I removed the 250K volume pot, and installed a 1meg pot with a bleeder cap, because that's what my '69 Tele has. NOW it's a Telecaster! Before, it only looked like one. Now it has a mean streak, and good dynamics. Good bite to it's sound now. Before, it might as well have had an on/off switch instead of a volume pot. This is more of what I was looking for when I put this Tele together. This rocking chair seems to work well for guitar pictures:
| Sponsored Links |
Thanks for the advice.
Good lookin' gitar there. 8)
"I'm gonna toss my telecaster through the television screen cause I don't like what's goin on!" - Radiators From Space |
R.I.P.
Thanks.
Ole Fuzzy tipped me off about my '69 having 1meg pots. All I knew is that it has a treble bleed cap, but I can't read the markings on those pots to save my life through all the solder globs. Now the new Tele's close enough to the '69's sound that it's a suitable replacement. Pete |
#4 (permalink) | |
Re: 1meg pots w/bleeder caps are great!
The only negative you get with a 1meg pot is that the cable capacitane will vary tone more. A longer cable will make the tuned resonance more observable. Here is an article I wrote a while back about 1 meg pots and cables. PSPICE Modeling of Guitar Circuits with Effects of the Instrument Cable YMMV.
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
#7 (permalink) | ||||
R.I.P.
But this is the type of Tele I started out with. This one just wasn't happening for me until I installed the 1meg pot & bleeder cap. Quote:
Pete |
#8 (permalink) | |
Pete--When you use this setup, do you usually roll off some highs on the tone knob? I've never tried a 1 meg volume pot. Tried a 500k once and that seemed too bright to me, but maybe there is some magic that happens when you keep the highs in check. Is that the case in your experience?
Like I said...some can't handle the high end. This is all subjective.
The beauty about the Tele is the wide range of use. A 1meg pot isn't for everybody. I'm just an old timer stuck in the Don Rich era, where a Tele cuts through a country mix.
#11 (permalink) | |||
R.I.P.
Pete |
R.I.P.
I've been using a 1meg tone pot all along. I'd heard that Bill Nash used that, so even when I wired it up at first with a 250K vol pot, I had a 1meg tone pot. .047uf cap on that.
I don't think I mentioned that in this thread. I think I mentioned that in the thread about the "only woodwork" etc... which is probably a couple forum pages buried by now. Pete |
#15 (permalink) | |
As you wind a pickup hotter, it gets darker sounding. So pairing up a Hot pickup with 1 megs is a good way to bring the sparkle back. I hated texas specials until i heard them in a guitar w/ 1 megs, then they're not half bad. With a bright pickup often times 1 meg is too much. What i'm saying is "it all relative". It depends on your situation. Johnny Atomic |
#16 (permalink) | |
R.I.P.
Although, I didn't like the 1meg tone pot when I had the 250K volume pot. It was too muddy then, now it's just fine. I'll probably eventually switch the tone cap from the .047uf Mallory cap I'm using now, to a .047uf ceramic cap. Pete |
#18 (permalink) |
R.I.P.
I haven't done much experimenting with cap values at all. In that last Tele I put together with the GFS Filtertron knockoff in the bridge position, (that has two 500K pots fwiw) I found the Fender value of .047uf to be very muddy, so I switched it to the Gibson value of .022uf, and that was a lot better.
You may put your your project together, and find you need to experiment with other caps, which fortunately is sort of easy to do with a Tele. Claude was mentioning that what some people do is connect caps in with alligator clips to try them out. I haven't tried that, but I like the idea. Pete |
#20 (permalink) |
Thanks Pete, I think i'm going to go for that myself. I had a thread about my tone being too dark no matter how I wound the pickup in my Sammick POS. It has 250K pots, volume and tone. I think i'm going to mess around with that idea some. Thanks!!!
Benny Trevillian. 90% of it is in the hands.. |
#21 (permalink) | |
R.I.P.
That stands for... Piece Of Samick... right? I just pretty much did a remove & replace operation myself, but Terry Downs seems to understand guitar electronics a whole lot better than I do. I'm going to have to read and try to understand what he wrote on his webpage about the subject: http://terrydownsmusic.com/technotes...itarcables.htm Pete |
#22 (permalink) | |
Taking this a bit further...when folks say that the 1M tone reminds them of what a Tele is supposed to ound like...and quote players like Don Rich who had that tone in the early 60's ... Seems like again...this was a modded vintage Tele tone ...not stock. It's just confusing when this super treble tone is quoted as being vintage sounding when it's seems doubtful that 1M pots were stock in vintage years. Was this always a common and well-known modification for Tele's? |
#23 (permalink) | ||
1M: tone '69-'81, volume '69-'87
#24 (permalink) |
R.I.P.
I didn't realize that they used 1meg pots for that long. I always thought it was for only a few years. You'd think they'd be easier to buy considering how long they were used. Not like I've done an exhaustive search for 1meg pot suppliers or anything, but the only place I've noticed selling them is Stewmac, which is where I got the ones I use |
