question about thin tele bodies (1.5")
I really like the feel of the Squier Affinity Tele bodies and it looks like they're about 1.5" as opposed to 1.75" thick. It makes a big difference to me in terms of comfort. I was thinking of ordering an aftermarket body and either having them make it thinner or doing it myself with a handheld router.
my question is this: what do you think is better--- a)thinner on the top so that the neck sticks up 1/4" more out of the pocket b)thinner on the bottom, so that the neck pocket is 1/4" more shallow c) 1/8 off the top, 1/8 off the bottom |
| Sponsored Links |
B.
Except, it would make the body wood behind the neck pocket thinner, not the neck pocket shallower. If you did (A) or (C) the neck would be high in relation to the top surface of the body, making it difficult to align the bridge saddles and neck... You'll need shorter body/neck screws as well....
http://www.myspace.com/jameswilsey |
It would be easier to get a butterscotch Squier affinity tele and change the other bits.
I'm not sure, but aren't some of the Mighty Mite bodies 1.5"? I like my Squier 51 'creation' for that reason. It's my stay-at-home messing around guitar and it's wonderfully lightweight and comfortable with its thin body. |
I've got one!
I have a partscaster with a 1.5" body. The body is 1 piece pine and was bought from Glendale. It was made by Brian Poe, who posts on here regularly. Being thinner makes it slightly more comfortable, but it is also light weight, and the guitar weighs only 6lbs. I've got a fat Allparts neck on it, Glendale bridge and compensated saddles, and Lollar pups.
The neck pocket is normal depth, and the neck doesn't sit high. Normal neck screws are fine too. I didn't have to use shorter ones.http://www.tdpri.com/telephoto/showp...00/ppuser/2276 |
#6 (permalink) | |
Re: I've got one!
"It would be easier to get a butterscotch Squier affinity tele and change the other bits. " I was tempted to buy a used one the other day for $100, but 2 things: 1) I would have to drill new neck holes in the pocket. (the holes aren't lined up with standard necks) 2) the one I tried was made of plywood (not like the newer ones). But, I might make this a toploader eventually. I loved the tone of the affinity I used to have... |
Control cavities run shallow...
On those butterscotch Affinity guitars. I'm not sure whether to bring it down another 1/8 with a router, or just shave under where the new switch is trying to live with a wood chisel. Any advice? Just thought I'd throw that in because if you do use one of those Squiers, you'll probably want to be rid of the toy switch as quickly as possible. It was quite possibly the flimsiest part of the guitar (maybe tied with the black plastic output jack mounting plate)
Whatever you do, post pics.
"...You don't need faith if you know it's gonna work!" "The views expressed here are mine and do not reflect the official opinion of my employer or the organization through which the Internet was accessed." |
I did this a month ago on my BSB affinty tele.
Put a musikraft neck, vintage top loader bridge, lollar 52 pickups, and acme wired control plate, with CTS pots, and fender 3 way switch.
The neck sits a little higher than the old neck did. The saddles still raised up enough, it was not a problem. The upgraded pots, and switches fit right in no need to route any wood. Playablity is excellent. This is my number one tele right now. The neck is a monster, one inch thick, with no taper, and jumbo frets. affinity upgrade affinity upgrade2
opinions expressed are the view of the author, and are not necesarily correct. |
#9 (permalink) | |
but not all are too shallow...
