Old March 19th, 2006, 10:36 PM   #1 (permalink)
Having a problem with new 72 telecaster deluxe-rattle
Hi everyone, I went today to switch guitars, from the hwy1 to the humbucker Deluxe. The only one they had was in black..:(. So I took it. The store was so loud, that I missed a problem went I opened the case, I hear this rattle.Not the tuners, string trees, but coming from inside the neck--the truss rod. even at the 12th fret to the nut, I can hear soemthing is loose. I attempted to tighten the exposed nut for the truss rod, 1&1/2 turns with no change. Any other ideas what to do? It will take GC 2 to 3 weeks to get another one, I was told today.....:((((
Jesus is my Lord, Saviour and Friend..always!
Major is offline   Reply With Quote
Old March 20th, 2006, 12:36 AM   #2 (permalink)
OutlawSteph1975's Avatar
I've got the same problem with my '72 Custom. It's only the g-string. I've tried everything to get rid of it. I've put a new bridge and saddles, which I would have upgraded anyway, and it's had a pro set up. It might be the nut slot is cut wrong. Basically, I just live with it.
OutlawSteph1975 is offline   Reply With Quote
Old March 20th, 2006, 03:44 AM   #3 (permalink)
winny pooh's Avatar
dont worry
It goes away eventually as the wood settles.
It does help to tweak the rod a bit but a seasonal change will get rid of it, and you wont hear it through an amp so if you dig the guitar then keep it.
my afro ambient side project:
http://www.myspace.com/theswyambusessions
winny pooh is offline   Reply With Quote
Old March 20th, 2006, 09:06 AM   #4 (permalink)
jimbobfingernails's Avatar
I found on my Squier Custom II that the pickup selector switch was ever so slightly loose, this caused a rattle that at first sounded like something in the neck pickup area was vibrating. Just an idea anyway
jimbobfingernails is offline   Reply With Quote
Old March 20th, 2006, 09:42 AM   #5 (permalink)
saunders.jesse's Avatar
Try adjusting the truss rod and make sure it works properly. My MIM Tele Custom had a completely frozen truss rod when I purchased it. I purhcased the guitar while on vacation, so I had to wait just over a year for Fender to send the replacement neck to my local authorized repair shop for warranty replacment.
As others have said, it may be no problem; but definetly give it a decent workout & checkup before your return period expires.
'72 Tele Custom RI & a Taylor 110 and I'm a happy guy!
saunders.jesse is offline   Reply With Quote
Old March 20th, 2006, 04:03 PM   #6 (permalink)
Seanycaster's Avatar
I'd be inclined to think it may be the nut. If raising the height of the saddles helps that would also suggest that it's the nut.
(\__/)
(")__(")
Seanycaster is offline   Reply With Quote
Old March 21st, 2006, 01:18 AM   #7 (permalink)
:) I have good news!, No, not that insurance Co, but I found what was the rattle in the neck. It was the high E string>tuner head, where the tuner slips thru the headstock, where a washer and nut are then set, well the nut was missing and the washer was claning against the string. Fortunately, I did't damage the truss rod by my attempt to tighten what sounded like a loose rod. So after coming home from GC in Austin and the manager who has been there, for me, fixed the problem-with new strings installed-free, the deluxe came home with me. I rechecked the truss rod, still a little bow, due to my lossening the bullet nut, the night before(I wasn't about to leave it over tighten) It took 1/2 a turn to bring the neck to that low action sweet spot. Plays like a champ, still not completely hum free, like my other electrics, but I knew that going in. The deluxe sounds sweet in all postions-clean and no hum. Its only when I am using alot of gain/distortion that the slight hum comes in, and its only slight. I can get alot of tones, from the stones to Led Zeppelin to overdriven blues. I can hear the twang of the single coil tele here at the bridge pick up. This is a guitar I will grow into, enjoying the diverse tones it can produce. This Telecaster isn't a Les Paul nor is it a Strat, and this is why I like it, kind of the best of both worlds
