Old January 1st, 2006, 11:16 PM   #1 (permalink)
JoeyV's Avatar
Springs vs. surgical tubing
I was wondering what the difference is between using springs for your pickups or using rubber tubing? Some say rubber tube robs some tone away however , Duncan who has wound a pickup or two uses them...what is the difference and is it really noticable? I can't hear it.
J.
"I just love hearing them guitars go zing, zang , zoom"
JoeyV is offline   Reply With Quote
Old January 2nd, 2006, 01:15 AM   #2 (permalink)
guitar_ed's Avatar
My luthier says tubing when pickguard mounting a SC, and springs when body mounting. Has to do with ease of installation. Since I don't know any better, I do it his way.
Guitar Ed
Piss off a politician, register to vote.
When you complain about the government, remember that you ARE the government.
Voting is the ultimate act of civil dis-obediance.
AIM - guitar_edg
Skype - guitar_edg (had to change on 5/16/06)
guitar_ed is offline   Reply With Quote
Old January 2nd, 2006, 01:38 AM   #3 (permalink)
Mike Rice's Avatar
From the Seymour Duncan website Q&A
Springs for height adjustment. What are the problems?
If a compression spring is used for height adjustment there can be several problems associated with them. If the springs are loose especially when the pickups are adjusted lower as in the neck position on typical Stratocasters the springs can vibrate and cause a howling feedback. When playing at higher volumes or in close quarters with other instruments, various parts of the guitar can vibrate and produce unwanted sounds or uncontrollable feedback in your instrument. I’d replace all the compression springs with amber surgical tubing 1/4” OD x 1/8” ID x desired length. It will help keep the pickups firm within the pickup slots.
Sure I like country music and I like mandolins, but right now I need a Telecaster through a Vibrolux turned up to 10...John Hiatt
Mike Rice is offline   Reply With Quote
