Old July 2nd, 2003, 06:51 AM   #1 (permalink)
Vunz's Avatar
Split neck
Hi
in the process of building a guitar i attached a neck to the body. While doing so one of the screws didnt went in straight (and thanks to the speed with which an eletric power tool goes) and the neckwood split.
First the split was inly running between two screws but now it starts growing a little.
How to repair the neck, any ideas?
Vincent
- Mostly harmless -
Vunz is offline   Reply With Quote
Old July 2nd, 2003, 07:56 AM   #2 (permalink)
Sorry
DonŽt use an electric power drill on your guitar (a good advice, just a little late I guess). Those tools are much to powerfull. There is no screws on the guitar that needs that kind of force, you will just cause damage. Now that IŽve been a real wise guy IŽll leave the advice on repairing that crack to others whith more experience than me. God luck!
Steven is offline   Reply With Quote
Old July 3rd, 2003, 05:04 AM   #3 (permalink)
Vunz's Avatar
I was just being lazy.
Next time i wont use those tools (i think... 8) )
Vincent
- Mostly harmless -
Old July 3rd, 2003, 06:48 AM   #4 (permalink)
rebelern's Avatar
hard way to learn.
I really know how you must feel about this mistake the only answer is to obtain another neck.
To look at a split a split each day and imagine??? it is growing is just not my idea of enjoying my guitar.
Your not the only one to make an error, I have made many and learnt from each,and no doubt make more.
Just bad luck mate!.
ernie.
rebelern is offline   Reply With Quote
Old July 3rd, 2003, 07:57 AM   #5 (permalink)
Gosh...
Trial and error is one of the most effective ways to learn something. I guess it can also be one of the most expensive to... I hope you can fix it without buying a new neck. Good luck!
Old July 3rd, 2003, 10:20 AM   #6 (permalink)
gtrman911's Avatar
OUCH!
GET wood glue, like Elmers(white or wood).
get a clamp and squeeze the neck at the end of the split so it doesn't split any more while fixing!! don't forget to use pads or spacers so your clamps don't mar the neck
next.... *gently* re-install the screw until the wood starts to split/open.
get the wood glue and ooze inside the split, even push it in...maybe use a toothpick or a pin. DO NOT DISTURB THE WOOD GRAINS OR FIBERS. you want it to go back exactly the way it split!!!!
then remove the screw and clamp the neck together tightly. if done right, the glue should ooze out as you squeeze/clamp.
after wiping away the excess glue completely, let it set for 24 hours
then maybe get some .00000 steel wool and lightly sand
KEYWORDS ARE; GENTLY, SLOWLY, CLAMP PADS
My opinion is worth what you paid for it.
gtrman911 is offline   Reply With Quote
Old July 3rd, 2003, 11:10 AM   #7 (permalink)
Vunz's Avatar
As long as none of the: GENTLY, SLOWLY, CLAMP PADS are electrically powered i should be able to do this.
Thanks Vincent
- Mostly harmless -
Old July 3rd, 2003, 11:31 AM   #8 (permalink)
Kevin's Avatar
Another option
Another option would be either the medium (preferable) or thin viscosity Hot Stuff glues....
The super glues may be easier to get down into the cracks, as they're thinner, and will hold as well as the wood glue.
You do not have to throw the neck away....
I had a 22 fret maple neck once (had the extension for the 22nd fret) and bumped the end getting it out of the box. It broke the extension off cleanly at the 22nd fret -- wood was very thin there.... Anyway, I took some Hot Stuff and coated both sides of the break, stuck them together, stuck the fret back in, and held them together for a couple of minutes with finger pressure. I had to level that fret with the others, but the extension was as solid (more, I suppose) as it had ever been....
Old July 3rd, 2003, 07:26 PM   #9 (permalink)
rebelern's Avatar
Vincent sorry .....
if my earlier post misled you?,and thanks guys for the info about the types and application of Glues to use,I will check around and see if they are available here for future reference,this forum is sure great .
ernie.
